Question about Whirlpool LGR5636L Gas Dryer
No heat, How do check continuity with a multi-meter to see if is working properly?
How do you check resistance (continuity) with a mutli-meter to tell if a igniter part for a Whirlpool gas dryer is working correctly?
  • 659 Answers
You have to have this setting on the meter. It generally looks like an arrow on some meters. If you find it, then you remove the wires to the element and place one end to one wire and the other end to the other wire. Most meters will beep when there is continuity.
Posted on Apr 17, 2009
The fridge keeps freezing
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM
Apr 05, 2015 | Refrigerators
My food is starting to freeze in the fridge compartment
Fridge freezing up- and no fan or air circulation:
Apr 04, 2015 | Refrigerators
Bottom of freezer icing up
Apr 03, 2015 | Refrigerators
Freezing up at the back
Fridge freezing up and no fan or air circulation:
Apr 02, 2015 | Refrigerators
My fridge has started icing up turning everything to ice
Mar 31, 2015 | Refrigerators
My Samsung side by side refrigerator is not working , freezer side working and fa working
Mar 31, 2015 | Samsung Refrigerators
FROST OR ICE IS FORMING IN THE FREEZER
Mar 30, 2015 | Frost Refrigerators
Freezer is too cold
Feb 23, 2015 | Refrigerators
I have a whirlpool over an under freezer an
Dec 11, 2014 | Refrigerators
Trouble shooting Samsung REF. Model RS267LBSH
Aug 19, 2014 | Samsung Refrigerators
Whirlpool LGR5636L Gas Dryer Logo
360 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
