Question about Konica Revio KD-400Z Digital Camera
Konica kd-400z Hi, I have the Konica Digital Revio KD-400Z, The lens has stopped going in and out and is now stuck half out. It keeps coming up with system error s0042 and A00B, any ideas how i can get it working again or where i can take it?
  • 76 Answers
SOURCE: Instruction manual for Konica Revio KD 400z
It is available for you to download at this page
hope this helps :)
Posted on Dec 09, 2008
0 characters
1 Points
I have updated the firmware of my konica k-400z by the konica kd- 500z but it is not working now i want to go on previous version of my camera so please help to do that
It sounds from the way you worded your question that you used the firmware update from the 500Z to update your 400Z. The update (ver.3.38A) specifically says that it will not work in any other camera. If your camera is not working now, that is the problem. Konica went out of business in 2006 so you can't even contact their service techs to find out how to get your camera working again. Sorry.
Jan 11, 2011 | Konica Revio KD-400Z Digital Camera
Konica Revio KD-400Z. Internal battery appears to have expired meaning I have to reset date etc. each time I remove either the l-ion battery or the SD for downloading. Can I fit new internal battery and...
First the bad news. Konica got out of the camera business in 2006...all service is now handled by Sony. The internal battery is not user replaceable. It is a rechargeable battery that recharges itself from the regular battery. It takes about 3 hours to accomplish this. If you remove the main battery for 24 hours, the internal completely runs down and all date and time settings are lost. If after setting them again, you don't leave the fully charged main battery in the camera for at least 3 hours, they will disappear again.
Oct 12, 2010 | Konica Revio KD-400Z Digital Camera
Camera won't take photo frequently
It might be telling you the internal memory is full. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to format (erase) the internal memory. Then insert your card and see if things improve.
Jul 14, 2010 | Konica Revio KD-400Z Digital Camera
Kd 400z Konica Advocate errors0042 en errors400e
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem.
Jun 19, 2010 | Konica Revio KD-400Z Digital Camera
is it the fact you cant do it or it wont let you? if you dont know how,
turn on the camrea
press the menu/set key
press the right key on quality
then press up once to get to 1600x1200
press twice to get to 2304x1704
then press right to set
this will then save the setting and go back to the previous menu
hth mat
Sep 11, 2007 | Konica Revio KD-400Z Digital Camera
Konica Revio KD-400Z Digital Camera Logo
146 people viewed this question
Top Konica Digital Cameras Experts
Lawrence Oravetz
Are you a Konica Digital Camera Expert? Answer questions, earn points and help others
