I can't find the manaul. and I don't know what kind of air fillter for this unit.
I am looking for service manaul for my york roof top air conditioner . model no: D2CE048A25B. and I want to find out what kind of air fillter for this unit?
  • Anonymous Apr 17, 2009
    how can i get a manaul for roof top air conditioner. model #:D2CE048A25B
  • 24 Answers
If you know what size filter you have and the location of it, I recommend a pleated filter. They catch more dirt then your standard filter.
Posted on Apr 17, 2009
Can you recharge. a dometic a/c rooftop unit serial number 991762724
No service ports on the unit. It needs to have a service port soldered to it and the system breached before you can check / charge.
Aug 29, 2014 | Brisk Air Dometic A/C Roof Top Air...
I have coleman air conditioning units on my 1991 Georgie Boy. They both leak... water from rain and also when units are shut off, lots of water comes back in. I bought gaskets but it looks like someone...
I'm thinking that motorhome has a rubber roof, so you don't want to cut at roof, or you'll likely end up cutting rubber roof which is certainly not a good idea. It may take some work but try prying and scraping with a plastic scraper while someone lifts up ******* upper unit. Quite often whatever sealant they've used to seal between roof and gasket will start to let go with constant upward pressure.(lifting) If you have fiberglass type roof and not rubber, scrape and pry where gasket meets roof.
Oct 05, 2011 | Dometic Rooftop RV Air Conditioner
Our penquin dometic air conditioner in the bedroom pours leaks lots of water when the unit is on during rain storms. Water leaks into the ceiling and also out the unit.
Sounds like base gasket at roof is loose or defective to start with. Try removing ceiling assembly enough to tighten 4 bolts that secure roof unit to inside bracket. Do not compress too much, just snug them all evenly and see if water slows or stops. If not, you will have to remove upper unit (roof) and replace gasket and re-secure but don't tighten to excessive, only compress gasket approx half of original thickness. Also make sure upper unit is aligned properly with opening of roof.
Sep 23, 2011 | Dometic Rooftop RV Air Conditioner
Can't find parts on a ten year old york roof top unit help please
You might call Johnstone Supply in Wichita, Kansas.
316-267-3629 ask for Kieth Rhea.
Apr 13, 2010 | Heating & Cooling
Have roof top air conditioner that blows air but soon trips breaker. any suggestions? Henry
check the condensor fan in the rooof unit. It's the fan blowing on the cpil on the roof.. If it failed, the head preasures can becme excessive andwork the compressor hard causing the breaker to trip. Let me know and good luck, Ned_
Sep 13, 2009 | Dometic Rooftop RV Air Conditioner
I dont know what kind of roof top ac is on my camper but i would like to know if anyone knows are the blowers belt driven?
Most of those types of units are not belt driven. that are direct drive, and some even have just one double-shaft motor which drives both the evaporator and condenser fans
Aug 11, 2009 | Dometic Rooftop RV Air Conditioner
My roof top RV air conditioner is dripping water inside my RV
Check run-of on roof & see if it's been reduced lately, it may just be a plugged drain at base of unit on roof.
Jul 29, 2009 | Dometic Rooftop RV Air Conditioner
Unable to turn on aircon with remote control and no manaul on button on the air con unit
I recommend putting new batteries in the remote. If that alone solves your problem great. If not, get back and let me know
May 25, 2009 | Heating & Cooling
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
