Question about Refrigerators
Machine oil in my ice
My freezer ice maker is throwing machine oil into the ice. I am afraid this might have been going on for several years and that we ingested the oil, because when I smelled the frank green oil that is now coming into my ice, it smelled just like the off smell my ice has always had. I once had the machine serviced and complained about the off smell of the ice and was told that the smell had to do with the water supply in my municipality. I hope this oil is not cancerous. I also wonder what to do about this problem.
  • 2 more comments
  • jgagepalmer Apr 16, 2009
    Kitchenaid KSSP48QFS05
    SG,
    I have installed a water filter, but that is not the problem.  The machine oil is coming into the ice container from the side of the machine that sits to the left of the built-in ice tray.  I can see little globs of green oil on the ledge next to the container, directly below the wires and moving parts.  The oil is not embedded in the ice - it is mixed in with the ice, in the container where the ice waits to be dispensed.
    Thanks,
    JG
  • jgagepalmer Apr 17, 2009
    SG,
    Thank you!  I will call and report the problem.
    JG
  • Tracy Farrell
    Tracy Farrell May 11, 2010
    JG,
    YUCK!!!!
    OK, that's out of my system... can you provide a model number for your fridge? That way I'd be able to pull up detailed info for you.
    SG
    President:
  • 331 Answers
JG,
The reason I wanted your model number is to see if your fridge has a built in filter. It doesn't. Have you considered connecting one to your incoming water line? You can find one here or at any local hardware store (Home Depot, Lowes, Ace, etc...).
Your ice maker won't introduce oil into your ice. Neither will your water inlet valve. So the source of you contaminant must be coming from your incoming water supply.
SG
Posted on Apr 16, 2009
  • Tracy Farrell
    Tracy Farrell Apr 17, 2009
    OK then, JG. There must be a leak from the unit above that is seeping into the freezer compartment.
    You mentioned the color "green". This sounds like it's coming from the unit compartment. There is NO WAY that this should be happening. Period. If, as you say, the gunk is coming through the liner and dripping into the ice bin then you have a serious issue. The interior liner is compromised.
    You should call KitchenAid and request service (have your Model and serial number handy)... 1-800-422-1230. Seriously... you should NOT hesitate to resolve this.
    SG
Freezer works ice maker leaks water into freezer compartment. Refridgerator cranked up all the way cold and throws warm air not cooling food it is 5 years old
sounds like its set to high on the cold selection, and it needs to actually defrost , setting the freezer to colder much of the time will worsen the problem, if you can unplug it for a day and let the machine defrost ( deice) then it will be able to actually function better, Ice causes the functions to not be able to work properly. the ice maker leak could be caused by the limit switch being frozen , remove the tray and make sure that the unit isn't clogged with ice, if it is,, leave the tray out while you have it unplugged, and it too will fix itself once the ice is removed
Jul 20, 2011 | Maytag 25.6 cu. ft. Wide-By-Side...
Our ED5SHAXM ice maker is intermitant. It will make ice for several weeks and then suddenly stop making ice, the water flow to the ice maker stopes and the bin empties it's final time. Then weeks later it...
Either the freezer temperature is too high or the internal thermostat inside the ice maker is faulty.
The freezer temp must be 5 degrees or less for the ice maker to work correctly.
If the freezer checks out OK you will need to replace the ice maker.
Apr 10, 2011 | Whirlpool ED5SHAXM Side by Side...
I have a GE refrigerator model # GSH25KGMB WW. It is a side by side with an ice maker and water dispenser. We have had it for about 9 years now. The ice maker hasn't been working right for about 6 or 7...
you could have several problems.
Since you mentioned your ice maker not working right - first check to see if your ice maker is hot (be carefull it can burn you if it is hot) - it is possible for an ice maker to hang in the heat cycle of the cycle producing excessive heat in the freezer. If this is the case unplug the ice maker and/ or just replace it.
The refrigerator gets it cold from the freezer so if the freezer is not working right, you'll soon notice it in the refrigerator side.
You can also check to make sure the evaporator fan motor is running(in the freezer) and the condenser motor(at the compressor) as well.
Also check the back panel of the freezer for excessive frost build up.
Jun 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker makes noise like it is working but turned off
If you want to have a working ice maker it will need to be replaced. You can buy the whole unit part # 1129316 for almost the same price as any of the individual parts. Behind the unit on the back wall is a plug with several wires unplug this plug to disable the icemaker.
If I can be of further assistance please let me know.
Apr 15, 2010 | Kenmore 53642 / 53644 Side by Side...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
My freezer isnt working
this may sound stupid but is the ice maker turned on? Does it say "ice" in the display? If it does, check to see if the ice level arm is jammed into the upper position also make sure that the ice bin is in place (it actuates the ice maker switch) make sure there is no ice stuck to the top of the ice maker
Jun 16, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
Frisdge/freezer and ice smell
I had a side by side refrigerator with an Ice maker from Sears. The ice it makes smell fishy so bad that I could not use to drink with anything else but throw away to the plants. So I unscrewed the ice maker . It is not that bad, but quite simple to take it out. I noticed rusted pieces of metal generating strong fishy smell. I could not get rid of rust with soap, detergent, oil so I wrap it in plastic bag then screw it back into the refrigerator. Screwing back the ice maker. Voila. The smell is going away. The ice is good. Pina Colada and Daiquiri here we go .
Jan 24, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Hoshizaki Ice Maker
check condenser condition can be dirty, cleaning the coils with coil cleaner for ice machines(i suggest you take all the ice out of bin first) i'd go with that first. check if it works for you.
Mar 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker doesn't work
I have the same problem. I've had the freezer for 2 years & ice maker just stopped making ice this week. Freezer works O.K.
Jan 11, 2008 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerators Logo
187 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
