Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
We are trying to change projector lamb on a soy 42 inch LCD tv. we could not find the place where it should be plugged. thank you
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Please intimate exact model number of Sony TV to provide you info about lamp replacement.
    Novelist:
  • 159 Answers
The reason why this tv it doesn't looks as having a lamp cover is because has a front panel first to deal with. identify first this one to release it:
the front cover is easy to identify because is big and the power button at the center identify this big part. this big plastic 10 inches width and it is large as the tv all the way east to west in the bottom of the set. It is attach to the set with two screws. this two screws are find in the extreme of this front cover but in the back side. They looks as gray dimes (coins) actually you can use one dime to unscrew them. Ready!
  • when the screws are release (not all the way out just release) is not the only thing attaching it to the body
  • note: Sony Co. in this front cover thought to clip it with three 1 inch diameter clips you can locate them with great deal of imagination: The location of them is this: if you trace an imagine line: trace it starting on the power button as center but something as 30 inches left and another 30 inches right outside + another immediately down but this time vertical line down as 3 inches down,
  • "this is half of the job"
  • releasing this front cover is hard and kind of puzzle because you take the front cover from top side towards you (watch your fingers is really hard to make this operation you need a strong fingers) note: the bottom is trapped with another inner plastic obstruction. Now with this clips in your mind try to release this clips (this clips make a weird sound when are release something as you already broke the panel. don't panic)
  • Until here the panel was release and in your hands put a side.
the lamp is covered with little door 3 inches square left side of the power button called lamp cover. use again your dime to release this last screw holding the lamp cover. inside you find the lamp.
Posted on Apr 17, 2009
RCA 42 in Replaced the 42RE010C878LNA0-A1 Board now a good picture but upside down how do I fix it
from remote press menu and highlight contrast enter code 1950 and see the service menu comes up. if not try 9735 same way.and change product id in service menu. try different .ids. each time you change id unplug tv and plug in .see if picture change.or do same process each time until show good.
Jan 19, 2015 | RCA 42la45rq 42-inch 720p lcd tv
After around 1 minute the lamb goes off and the system goes to standby
the lamp is good one, it is ok .the mother board is ok
it seems like the fans is defective
pls check every fan in the projector
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 21, 2014 | NEC M260X LCD Projector
I have a 42 inch lcd tv. The tv will come on but the screen is blue Cant change channel or adjust volume. Any help would be greatly appreciated, thank you.
try to unplug it and a cable or sat box if used from power for a while to see if a reboot will help---also the fact you cannot change channel etc means the set experienced some kind of glitch.
Nov 04, 2012 | Sanyo 42 in. LCD TV
When i go to pc mode on my aquos 42 inch the background and screen is blue not the blue screen of death the set is 2 yrs old
That sounds like a resolution problem. If you have a PC attached to the TV, unplug the monitor cable, and plug a computer monitor to the computer. Change the resolution down to 1024x768, then try plugging back into the TV
Jan 12, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I am trying to hook up my computer to the insignia 42" tv but i can't get it to come up -- i it on VGA and it is saying mode not supported.
I know when you plug a computer into a projector, you have to not only set it up on the projector, but on the computer as well. Make sure the computer is set up for one of your multi-screen modes as well as the tv.
Oct 03, 2009 | Insignia 42" LCD Flat-Panel HDTV
The fuse in my plug keeps blowing ive checked all wires and thay seem fine i have a 42 inch rear projector samsung tv
Don't plug again.Your 42" rear projector has a short circuit inside. I think that it is in power supply. If you have some test experience . Easy fix.
Sep 26, 2009 | Televison & Video
I cant get the audio to work
it could be one of the cable is in the wrong place
Jan 28, 2009 | X2Gen HHE-MV42R 42 in. LCD HDTV
Vizio 42 inch tv Power Not working
It sound like the power supply problem. Replace the power supply will fix it. The power supply is located near the main board.
Dec 15, 2008 | Vizio GV42L 42 in. LCD Television
No picture
i have the same problem. i took my tv to radioshack, and they said that they dont tale tvs that are bigger that 27 inches. so i took to one of these places that fix tv, they are charging me $270, beacuse they have to change the power supply and sometranssitors,
Sep 20, 2008 | Polaroid FLM-4201 42 in. LCD Television
Philips bsure SV1 , LCD multimedia projector
Pl try M. R. nterprises Mumbai +91 22 23802513/23856204
Oct 29, 2007 | Philips bSure SV1 Multimedia Projector
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
89 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
