Question about Microsoft Xbox 360 Controller
Right Joystick. . .
The right joystick of my sister's 360 controller sticks. When I move it to the left, it stays to the left. I disassembled the controller. Then I tested the joystick without the cover, and it worked just fine. I put the cover back on and then it started sticking again. So, I took the cover back off, then started comparing the left and right joysticks. I discovered that the crappy one is raised about 1 cm higher than the working one. When I push down on it (with the face off), it acts like it was functional. Just up a little higher. So what I would like to know is how can I lower the right joystick. Thanks in advance.
    Problem Solver:
  • 14 Answers
I had this same problem with my 360 controller (after modding it, but the solution should be the same..) If you pull up on any 360 joystick it will stick the same way.
The quickest fix would be to take some sandpaper on the inside of where the joystick touches the controller shell, sand it down just enough so the joystick is moving smoothly.
More professional ways would be to cut the little piece of metal that sticks out and goes into the joystick. Just a very small amount, too much will make it hard to press the right thumbstick button.
You could also try some old fashioned grease, just a little bit on the inside, nothing noticeable from the outside.
Also make sure the controller is put back together right, I've taken apart many 360 controllers and sometimes joysticks stick when there's a wire in the wrong place and the shell won't close all the way. (The rumble motors particularly).
Hope this helped!
Posted on Oct 23, 2007
My Xbox one controller left joystick is always moving to the right.
sounds like the microswitch is stuck. The return spring won't help resolving this. more than likely replacing the controller will be your most efficient means to resolve the issue.
Oct 31, 2014 | Microsoft Xbox Video Game Consoles & Games
The right joystick on my 360 controller wont give me full range of motion even though the stick moves prfectly fine
Well, it may be because the XBOX has a de-sync, making the controller delayed when you give it orders.
I suggest using another controller. If that doesn't work, contact Microsoft support.
Nov 27, 2017 | Microsoft Xbox 360 Controller
My left joystick keeps moving things down without me moving it
Sometimes your joystick on xbox controllers can become stuck. To fix this you can do one of two things. you can ether buy a can of air used to clean out computer keyboards and spray it inside the analog stick. Sometimes if that does not work you can also disassemble your controller with a t8 torc screwdriver. Ones disassembled use hot water on and below the analog stick to get rid of unwanted grim. This should fix the problem.
May 30, 2011 | Microsoft Xbox 360 Wireless Controller
Damages joy stick, cannot move up, down, left and right
Most of the time joystick problem can be corrected by :-
-put some servicing liquid like petrol on joystick area and move your joystick up dpwn left right
then dry your board .
- most of the time this problem will be solved by this process. if not then change your joystick
Oct 20, 2010 | Sony Ericsson K700
MASTER RESET CODES FOR SONY ERICSSON
Here are the Master Reset codes for your phone.
Master Reset / Codes
Accessing the Service Menu - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key.
Checking Firmware Version - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key, press 1 key twice.
Show IMEI # - press * key, press # key, press 0 key, press 6 key, press # key
Manual brightness adjustment - While in camera mode, press and hold * key and move joystick to lower brightness, press and hold 0 key and move joystick to increase brightness
Quick ScreenSaver - Pressing # and * at the same time
Show screensaver and lock keypad - press * and lock keys
*#0000# - Reset language back to english
Hard Reset -Hold power for 10 seconds
May 28, 2009 | Samsung SGH-D500 Cellular Phone
Left joystick broke
hi its better to replace a new joystick
Jan 21, 2009 | Microsoft Xbox 360 Controller
Left Joystick off
remove batteries. just one hold down buttons 6 & 8 reinstall battery this resets the analog sticks
Dec 19, 2007 | Logitech Rumblepad 2 Game Pad
Microsoft Xbox 360 Controller Logo
903 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
