Question about Mtd 22" Yard Machine Push Mower
Mower only starts when keeping pumping gas from compressor
I have a yardman self propelled 6.5 lawnmower. It's not starting with the automatic starter, just the pull. It will star†, but won't keep going unless you pump the gas from the side . It sound like gas isn't going thru the fuel line so i got some ''Seafoam'' fuel injector cleaner and it's still only starts up and if you keep pressing the pump, it keeps it up for a little bit. Any suggestions? Thanks, Erin
  • Erin Wenzig
    Erin Wenzig Apr 18, 2009
    there was one small hole and we fixed it.  Got rid of the old gas and now it works.  Thanks for the help.
  • logandiez May 11, 2010
    Have you checked for holes in your fuel line? Sucking air will cause it to not get enough fuel.
  • 109 Answers
SOURCE: Can't keep mower running without consistently pushing the primer.
It sounds like there is water in the gas. The only way to remedy this is to take the carb off of the gas tank and replace the diaphragm, there is a small reservoir between the tank and carb...clean with WD-40 to remove water
Posted on Apr 21, 2009
  • 40 Answers
SOURCE: Little spark
check the gap on your plug. .030 is what it should be. also make sure that your
kill cable is working properly and not grounding the engine out.
the gap for you magneto should be set to .010 to .012
loosen up the magneto insert a standard business card or 3x5 card
then turn the flywheel so that the magnet on the flywheel pulls the magneto into it. then tight the magneto mounting screws down. try spark now. always use fresh gas. -no-water- if in doubt throw it out.
gas is BAD after only 30 days.
Posted on Apr 27, 2009
  • 7 Answers
SOURCE: yardman push mower self propell not working
check to see if it is belt or gear driven
Posted on May 02, 2009
  • 30 Answers
SOURCE: won;t start
Hi, it is possible that even if you changed gas, assuming water was in the tank as your original problem, that some stayed in the bottom. If you pump the primer while it fires up and it helps to keep it running, you still have some water.
Posted on Sep 09, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Well my yardman has fuel to the carb and will
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Sep 26, 2010
Lawnmower Makes Squealing Sound when Self-Propell is Used
if you take it apart there will be no warranty . take it to where purchased and get it repaired
Jul 21, 2015 | Troy Bilt 5.5hp Self Propelled Mower
Hi I have an mtd yardman ym 6021 sms Self starter, self propelled lawnmower. It starts reluctantly and then runs ok except it runs on full throttle all the time and you have to walk really fast behind it...
your primer is the choke the primer bulb pushes air in ti the bowl then it forces gas to inter the engine to make it start try spraying above the carburetor some wd 40 sounds like your throttle is stuck not letting your governor work ,happens alot
Apr 30, 2014 | Garden
Yardman 6.5 HP. Intek / 21" 6speed self propelled
its probably a tecuseh engine no fix for that other than put new primer ball on
Apr 28, 2013 | Garden
My Troy Bilt Self Prop. Z-start won't keep running. I clean All, replace Filter and Plug, have clean gas and lubed all. It Starts for 2 seconds and then cuts off. What do you think it could be? Thanks....
I had the same problem, Tilt the lawnmower on it's side air filter facing up and remove air filter cover and air filter then remove the fuel bowl underneath the carb; then clean the fuel bowl with some gas and a clean rag. For the next step be sure to aim blower tip at target then look away before pressing trigger, this will prevent gasoline form getting into your eyes.Take an air compressor and carefully clean out the carb where the flap is and the tube where the fuel float that would rest inside fuel bowl is. Leave on side install everything back except for air filter and cover. Then pour a little gas in the carb to prime it, lay the lawnmower back on all 4 wheels and try to start.
Aug 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Self propelled Yardman won't engage - cable problem I think???
are you in vero beach if so you can email me and i can fix it tj_gunter@comcast.net
May 21, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Starts, runs, and dies...starts, runs and dies...starts, runs, an
Sounds like a common fuel problem you need to remove carb & fuel tank and unless you can get a compressor they need a good blast out you may even take carb apart & check diaghram they have very small jets in fact most lawnmower shops have a sonic bath for this
Apr 25, 2009 | Poulan Pro " Pro" Self Propelled Mower
Mtd 22" Yard Machine Push Mower Logo
394 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
