I'm getting a squealing noise on the spin cycle (sounds like a bad bearing). Everything else works fine
    Problem Solver:
  • 9 Answers
Yes, your bearings will need replacing if it is on every spin cycle the machine completes
Posted on Apr 16, 2009
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
Loud noises during spin cycles
Hello, If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
Thanks
Jun 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
99 Altima with 190k miles warbling noise
It sounds like your water pump is going it usually vibrates throughout everything if it was your alternator it would show signs with your power the easiest way would to take your belt off remembering the belt route and spin the alternator pulley and the water pump pulley to see if they spin freely without noise
Jan 26, 2010 | 1999 Nissan Altima
Washer squeals during wash & rinse cycles.
It sounds like you're brake stator & rotor is worn and merit replacement, it would also be prudent to replace the thrust bearing as well since you'll be in the same area for the repair. The way to verify is to place the unit in spin & allow it to reach speed then open the lid. If it squeals then the repair would need to performed, if it does not then further troubleshooting would be needed. Hope this helps... Bill
May 29, 2009 | Maytag PAV2300 Top Load Washer
Makes loud noise on spin cycle
May 03, 2009 | Washing Machines
Kenmore 110.86874100 Motor (?) Squealing
I don't think they can be, but, also take a look at the fan bearing assembly too. You should be able to isolate if the noise is from the motor bearings or blower bearings.
Jan 26, 2009 | Dryers
Loud spin cycle
OTHER THEN CHECKING THE WATER PUMP I THINK YOUR RIGHT THE BEARING ARE GOING,IT WILL WORK FINE TILL THEY LOCKUP THEN THE BELT WILL BURN OFF,BUT I WOULD CHECK THE WATER PUMP ALOT OF TIMES IT JUST THAT,LET ME KNOW -MIKE
Nov 03, 2008 | Frigidaire FTF530ES
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Washing Machines Logo
109 people viewed this question
Top Washing Machines Experts
