Question about Epson Stylus Photo R1800 InkJet Printer
I wish to print several of the same file on the same sheet of paper. how can i do this.
    Brigadier General:
  • 3,917 Answers
Well , print one file on the page. Next reuse the same page to print other files on this page. You need to manually feed the page in your printer. But be very careful to check the print area while giving the print command.
Also you can paste the files in a MS word file and then print the MS word file. For example if you want to print multiple photos in the same page insert the pictures on the same page of the word file. Then print the page.
Thanks
Posted on Apr 16, 2009
  • 61 Answers
SOURCE: No paper
If you have turned off the printer, with a job pending, and you turn on again, the job is partially lost, and the first part of a print job have the initial commands for formatting the print, so some printers just print loose characters, other react like yours, and keep waiting. What you can do, is: first: turn off the printer; second: cancel the job (wait several minutes till the cancelling is complete, and the printer window in your pc is completely empty, so turn on the printer again, and try to prnt.
Posted on Apr 19, 2008
xptareq2000
  • 1447 Answers
SOURCE: roller drags several sheets of paper and results in a paper jam
Open your printer and release jam paper then solve problem.
Posted on Sep 28, 2009
komguy
  • 2306 Answers
SOURCE: I can only print one sheet, then the paper stucks.
Samsung is a reliable brand, but they have had problems with the vendor for the exit sensor. When it goes bad the paper comes part way out of the exit and jams. The part is less than a dollar, and you might find it at www.precisionroller.com
Posted on Jan 22, 2010
  • 20 Answers
SOURCE: My praftically brand new Canon Pixma MP620 printer
check the printer's printing preferences on properties option.should be set to normal then check the printer rollers if its dirty where the papers pass thru, if the problem persists load only 1 paper every time you print for the printer not to grab more papers.i think it is in the feeder and the sensor maybe its dirty need to be cleaned up.
Posted on Feb 22, 2010
puertobori
  • 7733 Answers
SOURCE: Paper feeder prints one sheet
HP designed a quick and easy tool that diagnoses and resolves many printing problems: The HP Print Diagnostic Utility. HP recommends that you download and install the Print Diagnostic Utility any time you need to troubleshoot a printing problem.
Posted on Nov 04, 2010
How do I reset my SX215 to factory settings
When you are in the application that you are going to print from. Go to the menu bar, click on File - Page Setup. Here you should be able to change the paper size you wish to print out in. If you want to set the paper size by default to A4, then you will need to (Windows7) click on the Start button - Devices and Printers, select the printer that you want to change the paper size, right click on the printer - Printer Preferences, a dialog box appears, select the paper size you want in the paper size drop down list, click - Apply - OK. This should then have set the paper size to A4 by default.
Feb 26, 2015 | Office Equipment & Supplies
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Single paper sheet not printed, multiple yes
Try few steps as given below...
1. poor quality printer may reduce printer quality & causes paper jams and other printer problems. If you encounter problem , switch to a higher grade of printer.
2. Do not load curled and paper folder.
I hope, it helps.
Feel free to get instant printer help at http://www.vtechsquad.com/printer-support/ to fix any printer issues.
Jan 21, 2013 | Epson Stylus Photo R800 InkJet Printer
Paper feeder prints one sheet and sends several blank sheets out. It is also prone to develop a paper jam and envelopes do not feed properly
Nov 04, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My praftically brand new Canon Pixma MP620 printer grabs more than one sheet of photo paper and stops printing picture on first sheet then garbles several pictures on a portion of the next sheet. I just...
Feb 22, 2010 | Office Equipment & Supplies
I can only print one sheet, then the paper stucks. What do I have to do? I have to open the front door, get rid of the paper and start over. So one more sheet is printed and the paper stucks again. This...
Jan 22, 2010 | Samsung ML 2010 Laser Printer
I want to print on photo paper I have no idea how to start,printer is a photosmart 7450
OK, Assuming you have Photo paper loaded in your printer and your photos from your camera downloaded to a photo software program. eg Adobe Photoshop/ Serif Photoplus etc.
Bring up the photo/photos you wish to print on your photo software. eg click on the open yellow folder top left and open the fotos you want.Click 'Browse' if you don't see the ones you want. ( Open as many as you want to print.)
In order to make your prints economical you can print two or three fotos on one sheet. Click 'File', 'Print multiple' and you will see format sheets in the right pane. If you only want to print two pics on one sheet click in the right pane on the two 7 x 5 sheet or, to print three pics of the same or different pics click the sheet with three frames on it. You will now see your pictures in the right hand frame and the format sheet in the right hand frame.
Left click and hold on the pic you want and drag it into one of the boxes in the right hand frame - let go.
That pic will now appear in the box selected. you can now size it to the box it is in. If it is the right way up eg portrait in top left of a three frame page click on fit to frame to maximise picture. Click and drag another pic from the left side frame to another box in the right frame. If you have chosen the three option sheet click and drag your next foto into the bottom box on the sheet. This is a Landscape box but don't worry.
After dragging your pic into it look for an icon in the function bar along the top where, when you hover your cursor over it, says - 'rotate and fit'.(It's a square with funny corner bits!) Your pic will the be realigned to fit the the box. Having all the pics you want on the sheet click the print icon. (Picture of a printer on the tool bar.) when the print box appears click on 'Properties' and open the 'Paper/quality' tab. click the drop down box for paper and select HP Photo paper - gloss or whatever you are using. The quality will automatically set to 'Best'. Click OK and OK and the files will be transferred to your printer and it will shortly start printing your pictures.
Bset of luck.
Any problems at all, just get back to me.
Cheers.
Ian
Dec 01, 2009 | HP Photosmart 7450 InkJet Printer
My D7460 will not feed paper The screen says load paper face down in main tray.
Usually this occurs when a printer has had fairly excessive use. This causes the rubber paper feed rollers to become shiny and then they are unable to grab the paper, or it grabs several sheets at the same time. Newer laser printers have now have grooved belt tracks to help prevent this problem.
The easiest way I have found is to BUFF the shiny tracks... Here´s how... Using a ladies nail file (sand paper type) Press the paper feed button to cause the rollers to slowly rotate and buff the rubber as it turns. Making sure no sand enters the rollers. If several sheets of paper feed at the same time. Pull them out and a trick to stop this happening is... to fan the paper before loading into the paper tray. The trapped air will allow the sheets to glide easier.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
John P Bradley
Tinteiros (Ebay)
Oct 28, 2009 | HP Photosmart D7460 Printer
Roller drags several sheets of paper and results in a paper jam
Apr 09, 2009 | Lexmark E322 Laser Printer
Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Feb 02, 2009 | Epson Stylus Pro 9800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
24 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
