Question about Jura Capresso Impressa X90 Espresso Machine
The grinder turns, but the grounds are not entering the machine
I have removed the cover, vacuumed out the beans, and see the grinder spinning. For one reason or another, the grounds are not dispensing into the machine. Any ideas for me? Thanks, Chris
  • cmgs20037 Apr 16, 2009
    The grinder unfortunately has nothing to do with the cleaning process and the machine is not telling me that another cleaning cycle is necessary. Any other ideas? Thanks
    Thanx, I'll give it a try
    Problem Solver:
  • 12 Answers
Go to a coffee store were they sell the machines or ground coffee. (coffee warehouse), and get machine cleaner tablets.
Posted on Apr 16, 2009
I can't brew coffee, when machine is turned on it makes a loud noise like endless spinning. sounds like it is coming from the brew/tamping area
foreign element perhaps the grinder is bad though. First try using a small vacuum that will allow adequate control of vacumming up the bean container. remove all the beans etc. the bean container must be emptied. then look at what the vacuum removed, any foreign objects? if you see 1 or more it's likely fixed. otherwise remove any inside cover/guides in the bean container you should now look directly at the grinder wheels with flashlight, as there may instead be a foreign substance or a defect preventing the grinder from processing the beans. if a defect then it may require factory service. gl
May 28, 2015 | Jura Capresso Impressa Z5 Espresso/Coffee...
HOW DO I CHANGE THE GRINDING MECHANISM ON MY SPIDEM TREVI EXCLUSSIVE ESPRESSO MACHINE. I HEAR THE MACHINE GRINDING BUT IT'S REALLY NOT DOING ANYTHING. ANY SUGGESTIONS
When the grinder spins free and fast it only means that fresh beans are not feeding into the burrs. This happens when:
1- Grind setting is too fine and beans cannot enter the grinder mechanism.
2- Use of oily dark roast beans can clog the ground coffee chamber and preven the fresh beans entering the grinder.
3- The ground coffee chamber outlet is clogged due to oily beans or too fine coffee setting.
When you cleaned the grinder you may not have cleaned the coffee outlet to the doser on the left. You can clean the outlet to open the passage of coffee grounds to collect in the dosing device..
After cleaning the outlet, you should next make sure that coffee grounds are not packed in the doser. The doser is inside the door right above the brew group.
To access the doser:
1- Remove water tank.
2- Remove the brew group.
3- Lay the machine on its back for full view of the doser.
4- Pull the doser door open (it is like an Attic door.
5- Keep the doser door open and clean the inside with a brush. The outlet from the grinder is on the right side with a wire wiper cleaner that moves across the grinder outlet fills from the grinder. This opening.
Use a brush to clean the doser.
On the left of the doser space there is a plastic flap that is pushed to the left when coffee grounds fill the doser.
At certain distance push back (1/4") the notch on top of the flap pushes the doser micro switch pin to stop the grinder. Push the flap gently to the left to make sure that it is moving well. With each push back of the flap, one can hear the feeble click sound from the micro switch.
When the above cleaning is done, try the grinding.
If the conical burrs have not been replaced for over 2500 grinds, it is time to do so.
The above grinder and grinder doser cleaning instructions are available as download files on the following page link:
One can find many useful maintenance guides on one page.
Good luck.
http://www.partsguru.com/MaintenanceofEspressomachines.htm
Feb 10, 2015 | Spidem Coffee Makers & Espresso Machines
The bean does not grind anymore it just makes the noice but does not grind. My mum accidentally poured a little water in that compartment. What shall I do?
Unplug the machine.
Remove all the sticky beans and grounds from the grinder (use a vacuum and a small brush) you might need a flashlight.
AFTER YOU ARE DONE.
Plug the machine and turn it on
Pay attention to the number were the grinder is set at(you need to set it back at that number after you are done with the next step)
turn the graduated knob when the coffee grinder is working; TO THE COARSER setting.
After grounds come out OK. set it back to normal.
If the ground coffee is too fine, turn the knob toward higher
settings; if the ground coffee is too coarse, turn the knob toward lower settings.
I hope this helps.
Jan 14, 2011 | Gaggia Titanium Espresso Machine
I have cleaned my machine and put the grinder back inside its housing but it says the grinder is blocked and won't operate. I cannot understand where it can be blocked.
You removed the grinder? Or you removed the outer burr from the grinder? It can be tricky to get back in place with the correct lineup. If you don't do it just right, it won't sit down in place like it is supposed to. Here are the full instructions, you may just need the last little bit about lining the burr up on reassembly.
From wholelattelove website:
You do not need to clean the grinder as often as you may think. Usually we do not recommend cleaning the grinder unless there is a problem with calibration or a clog. Avoiding oily beans, flavored beans, and beans stored in the fridge or freezer will typically prevent issues.
If you do experience issues with your grinder, cleaning it is the most common solution. To clean your grinder, follow these directions:
1. Remove the water reservoir, turn off and unplug the machine.
2. Take the cover off of the bean hopper and vacuum out the beans.
3. Remove the 3 Phillips head screws that are in the bean hopper.
4. Lift up the bean hopper and set it aside.
5. Open the machine's service door and remove the drip tray and the brew group.
6. Remove the rubber gasket from the top of the grinder area.
7. The grinder is made up of 2 pieces. The inner piece has 4 tabs that the rubber gasket sits on. The outer piece has teeth in a ring on the exterior covering ½ the circumference.
8. Rotate the outer ring 180 degrees counterclockwise. You should be able to lift off the inner ring. There is a red spot on the outer collar which should now be facing the 9 0'clock position when you are at the front of the machine.
9. Vacuum out all of the beans and ground coffee.
10. If possible, use a small pipe cleaner to get grounds out of the "pathway" going to the front of the machine. It is located on the floor of the grinder at about the 5 0'clock position.
11. Above where the brew group would be located, there is a gray triangular tab attached to a door on a hinge. Pull down on the triangle - coffee grounds may come out.
12. Look above the trap door and you will see the other end of the chute. Vacuum out the chute and clean with a pipe cleaner.
Reinstalling
1. Drop the inner burr onto the grinder with the tab that has the red and blue marks facing the right hand side of the machine at approximately the three-o'clock position.
2. Rotate the outer collar so that the red mark lines up the red/blue marks on the inner burr.
3. Reinstall the rubber gasket that goes over the grinder. The slots in the gasket line up with the four tabs of the outer burr.
4. There is a straight piece located directly to the right of the grinder. This is your dosage control. There is a piece that can slide backwards and forwards on this dosage arm. Push this arm all the way to the back of the machine.
5. Set the knobs in the bean hopper to #0 on the grind setting knob. Set the doser knob all the way to the plus setting. Now place the hopper back into the machine.
Note: You may have to rotate one or both of the knobs, a small amount, to get the bean hopper to set down on its supports.
6. Install the 3 screws.
7. Replace the water reservoir.
8. Fill the bean hopper with a cup of beans.
9. Plug in and turn on the machine.
10. Reinstall the brew group and the drip tray.
11. Once the machine warms up, press the small coffee button. When the grinder comes on set the grind setting to 6.
Note: You may have to press the small coffee button twice or 3 times before the machine will make a cup of espresso.
Oct 09, 2010 | Gaggia Titanium Espresso Machine
How do i reset my gaggia titanium, the gears are in the wrong position
Are you talking about the coffee brewing system? Or the coffee grinding system? You said "gears" so it sounds like you took the coffee bean hopper out and the adjustment knobs come out with it. So if you are trying to line those gear teeth back up correctly, Here is the complete instructions for cleaning the grinder (from wholelattelove.com). You only need the last few steps for lining up the gears.
Reinstalling
Sep 24, 2010 | Gaggia Titanium Espresso Machine
The grinder spins but no beans get grided. sometimes if i push them down it will work for a while.
Remove all beans from grinder and with the remain beans adjust the grinder to more gross grinding and the make 3 to 4 coffees.
Then Use a vacum cleaner and absorve as much from the grinder. Wash also the Beans hopper with soap and hot water so all oil remianing go away. Dry it very well and put back in place.
Now add new add some new beans and try to make an espresso and when the grinder spins then rotate back to the original grinding position. Remeber that you must go back to fine one step at a time not at once since this will blocked the grinder blades with grounded coffe and grinder will not rotate.
You should to this often is you use oily dark roated beans beans. I sugest to find also a better quality beans which are more light color thus less oily.
Aug 25, 2010 | Saeco Vienna Espresso Machine
All of sudden my grinder plugs up. coffee settles in around the base of the burr and does not seem to fall into the grind bucket, so the machine still runs but grinding basically stops as no more more...
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Nov 03, 2009 | Solis Maestro Electric Burr Grinder
I have a gaggia syncrony logic.The coffee beans are not going to the grinder so the grinder is just spinning,we have cleaned the machine and cant tell if something is stuck in it or what. cand you help?
Oct 27, 2009 | Coffee Makers & Espresso Machines
I have a Divina Deluxe and the coffee grinder is moving but it does not appear to be grinding it justs runs until the cycle stops. The machine turns on and gets ready but not grind. I have opened it up and...
Remove brew unit and check the grounds chute from the grinder, if that is clear, then re-insert unit, then when the grinder is grinding adjust to a coarser grind.
May 31, 2009 | Spidem Divina De Luxe Espresso & Coffee...
Jura Capresso Impressa X90 Espresso Machine Logo
225 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
