Question about GE (PSS26MSRSS) Side by Side Refrigerator
Need a wiring diagram for a Hotpoint fridge freezer
I urgently need to find a wiring diagram for a Hotpoint Ultima FF200M Fridge Freezer
  • 1 more comment
  • ebell152 Apr 18, 2009
    Hi I have checked the model number and it is a FF200M
  • John Tripp
    John Tripp May 11, 2010
    I have not been able to find a wiring diagram for your Model FF200M. I did see two models like yours in the UK sales market. I am restricted to search deeper by the limited information I could find. But if your refrigerator is like most that have control boards, that is where I would focus my attention. GE and Hotpoint make many of the same Brand names, but here in the USA the model
    PSS26MRSS side by side has a weakness in the control boards. I believe your model is also designed similar to our model only your electrical voltage and style are different. I do think you may get answers locally. I also can show you some of my later post with circuit board burn out. I am really sorry I cannot give you a solution. Other that examine the boards with the power disconnected front and back side. Most likely your control board is on back behind a square panel.
    UK: 0870 6092094
    Republic of Ireland: 01 230 0800
    www.hotpointservice.co.uk
    Possibly the best area for you to get answers.
    I am putting this down as a clarification request because I came up empty with a solution.
    If it's not too much trouble let me know what you find. Sea Breeze
  • John Tripp
    Hotpoint Ultima (FF200M), check model again can't find that model. Let me know, Thanks, Sea Breeze
    Genius:
  • 1,198 Answers
Check Repairclinic.com, it's a good site.
Posted on Apr 27, 2009
Hi guys I have hotpoint ff200m fridge freezer. I want to refill gas. But im not too sure which kit i need to buy to do it myself. Can some one help me please thanks
If you mean the refrigerant, I would not recommend it. If the refrigerant has leaked out, there is a leak. The system is contaminated with moisture, and the leak needs to be repaired, filter drier replaced, a vacuum pulled on the system, and a proper charge amount put back in.
Jun 23, 2016 | Hotpoint Refrigerators
Hii m habing problem with hotpoint ff200m Fridge is workng gfin but freezer not working. I have removed the panel to check. the fan and fan is working. Im still getting warning triangle light on
The freezer is the important side- if the unit can maintain fridge temps, but not freezer temps- you have a sealed system leak and are losing the refrigerant volume needed to create sufficient cooling. When you remove the freezer panel, there should be a fine layer of white frost across the entire length of evaporator tubing... GE Compressor WR87X20798
Jun 19, 2016 | Hotpoint Refrigerators
Need complete wiring diagram for hotpoint fridge freezer model STF175WP
Hallo
The wiring diagram should be on the back of the fridge or beneath in the plant.
Let me know if not I'll get it.
Regards
May 21, 2016 | Hotpoint Refrigerators
Where is the thermostat located on the Hotpoint fridge/freezer RSAV21
Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer
? 3:27
www.youtube.com/watch?v=YPglk963cXM
Sep 7, 2012 - Uploaded by Ezee-Fix Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer. Ezee-Fix .... Refrigerator Repair- Replacing ...Missing: rsav21
Free Hotpoint Refrigerator User Manuals ' ManualsOnline.com
kitchen.manualsonline.com > ... > Hotpoint > Kitchen Appliance Hotpoin
Products 1 - 50 of 299 - Hotpoint Top-Freezer Refrigerators Owner's Manual and Installation Instructions 18, 19 .... Hotpoint BL31 Larder Fridge Instructions for Use.
Oct 29, 2015 | Heating & Cooling
Wiring diagram for a Hotpoint FF73P
I am having a problem Fridge Freezer hotpoint ff73p
my fridge temperature is +23 need help
Oct 25, 2008 | Refrigerators
Hotpoint Ultima Fridge/Freezer keeps leaking underneath
yes this is probably the source of the problem - the defrost water doesn't flow down the drain.
melt the blockage with hot water till you get free flow down the drain - takes a bit of patience
tresilla
Aug 28, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint ultima fridge freezer
It's just simple.Keep the refrigerator open for few days with power on.After when the electricity bill comes,eveerything will be cooled.
May 28, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Nov 04, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Oct 03, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Aug 02, 2007 | Hotpoint FFM70 Bottom Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
2,051 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
