Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Get a Professional
Find a Solution
Most Common Problems for:
Generic problem for all Remote Controls
Codes for my Philips universal tv remote con...
Kandyegirl on Sep 16, 2007
Hiya ~
I have a pretty generic looking Philips universal remote control. :) My nephew accidentally hit the "code search" button instead of power when he wanted to turn off the tv. Needless to say, I do not have the manual & code list since I've had this remote for months.
After spending a long time fruitlessly searching online, I'm hoping that you can help me reprogram this silly remote control. Even went to the Philip's official website ~ talk about no help! They kept asking for a model number which is no where to be found on mine. Or, maybe they don't care since this is the ultra cheapo model. hahahaha....
The only technical info I have is ~
Philips Universal
Silver w/blue & "clear" buttons
Code Search button at top left
Inside battery compartment - CL032 and 10/06
Orion Television
Does anyone have the codes (Orion brand tv) & instructions for entering them? Grateful for any help! :)
Thanx ~
Kandye
www.nola-blog.blogspot.com
Comments:
Sep 16, 2007
- Hey all ~
I finally found my remote code ~ YEA!!! Just thought I'd share the site in case it can help someone else too. :)
www.universal-remote.net/philipsmagnavox.html
XO ~
Kandye
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
May 25, 2009
-   I have a simphonic tv, my universal remote control philips what is the code for use -   iglemero
May 11, 2009
-   my battery fell out and i do not have the codes to reset my remote control.-   Guest
May 06, 2009
-   i went to the same website & found the codes but they wont work on my television. this happened because my batteries fell out of the remote. -   Guest
May 04, 2009
-   I have the same problem. I can't belieive the amount of time I'm having to spend online trying to find the code for my Sylvania TV so I can reteach my Philips Universal remote to work it! You're right, Philip's website is absolutely no help.-   Guest
Apr 13, 2009
-   i turned the power off on the remote to my tv the next morning it would not even work. i have tried to reprogram it but it doesn't work. i even switched batteries .my tv is a zenith-   Guest
Best Solution
posted on Sep 22, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
0713,0115,0105
Solution #2
posted on Feb 16, 2008
Very Helpful)
gent
Rank: Apprentice
Rating: 96%, 25 votes
here is a link for the complete code list www.lexrixa.com/remote-control.htm
Please give thenks to the firm that provided it.
THANKS
Was this helpful?
Yes
No
8 people thought this was helpful
Solution #3
posted on Sep 30, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hey all ~
XO ~
Kandye
http://nola-blog.blogspot.com
Solution #4
posted on Jan 02, 2008
Helpful)
tarra111111
Rank: Apprentice
Rating: 94%, 39 votes
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Was this helpful?
Yes
No
9 people thought this was helpful
Solution #5
posted on Oct 08, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have the same remote and I went to that site and looked for my sony VCR and they don't have it, please help!
Solution #6
posted on Jan 25, 2009
Very Helpful)
Momwit2
Rank: Apprentice
Rating: 100%, 3 votes
Okay so I have the same remote and after playing with the remote for 1 hour, I figured it out.
1. Turn on your TV manually.
2. Press and hold (Setup) until light stays lit.
3. Press (TV) button.
4. Press (Channel Up) until the TV changes. If you missed the channel, you can press (Channel Down) until the TV changes again.
5. Then just press (OK) and your done.
Other manuals say press (Mute) to keep the code, but for this remote, just press (OK) button.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #7
posted on Dec 13, 2008
Very Helpful)
jtw465
Rank: Apprentice
Rating: 100%, 1 votes
I have the same type of remote, and an Orion Television. The code for the Orion Television is 115.
Press the Codesearch button until light stays on
press the TV button
then hit 115
Your remote is now set up for the Orion Television
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #8
posted on Apr 13, 2009
Somewhat Helpful)
ervin507
Rank: Apprentice
Rating: 75%, 1 votes
well the first thing i would do is kill ur nephew >< thats about it
Was this helpful?
Yes
No
Solution #9
posted on Jun 20, 2009
Not Rated)
gypsygirl724
Rank: Apprentice
Rating: 0%, 0 votes
This law office's website has links to two .pdfs that have solve the problem: http://www.lexrixa.com/remote-control.htm
They offer it as a public service.
Click on the CODES .pdf and it has not only the instructions but all of the codes for TV, VCR, DVD, etc.
Solved my remote problem in no time!
Was this helpful?
Yes
No
Solution #10
posted on Jun 17, 2009
Not Rated)
shardulmehta
Rank: Apprentice
Rating: 0%, 0 votes
See if this helps:
http://wiki.answers.com/Q/What_are_the_codes_for_a_Phillips_Universal_Consolidator_Remote_code_cl015
Was this helpful?
Yes
No
Related Problems
my kids pushed something on our sylvania tv and now we can't...
can't figure out what the code search button is
tv is demonic shuts off all by it self without any warnings....
I have a RCA Guide plus gemstar remote and can not program...
Can you Help with these Remote Control problems?
Programming for Arrow Keys on...
Solve
Have a Samsung HD870 DVD player and old Millenium 4 universal remote. Successfully linked remote to... (More)
my rcr 4 in one remote does not work...
Solve
no code butten is on the remote what do i do to slove this problem
I am trying to program for a sharp...
Solve
The remote lost programmong somehow and I need to get it back for a sharp tv.
i am using an ir 123479171-aa remote...
Solve
i am using an ir 123479171-aa remote for my RCA universal television.I can control the volume of the... (More)
We have los tthe codes for our...
Solve
We have lost the codes for our Sentry Really Big Universal Remote Control and need to know them to... (More)
29 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Mar 22, 2009
i have the same philips remote.
i need the code for a sears roebuck LXI series xs stereo modedl #43728
thanx
Comment by JONES0104, posted on Mar 22, 2009
I also have a philips remote but for a JVC T.V. can you help me?
Comment by Guest, posted on Mar 09, 2009
i cant find a code for my philips universal remote
Comment by Guest, posted on Mar 07, 2009
i have a philips clo34 remote and the code how do i set it up
Comment by ngalla28, posted on Feb 21, 2009
universal remote codes for Samsung HL56A650?
Comment by gipson62, posted on Jan 30, 2009
I must not be following the programming instructions properly. Can you please explain to me exactly how to enter the codes. I have all the codes.
I have a philips universal remote. It has dark blue buttons and clear buttons. I have all the codes, but I can't seem to get them to program. I hold down the code/search butto and light stays on. When I hold and release the TV button, it will do mulitiple blinks but not stay on. If I do get it to stay on when i try to put in the second set of codes it blinks and goes out but nothing works. what am i doing wrong?
Comment by Guest, posted on Jan 08, 2009
I have an Apex digital tv and I can't find the code for the remote
Comment by ELITGALLERY, posted on Jan 06, 2009
I HAVE PHILIPS UNIVRSAL CONSOLIDATOR I NEED CODE FOR VESTEL TV PLEASE HELP TO FIND OUT THIS CODE
Comment by Guest, posted on Dec 14, 2008
i have a philips remote and cant find a code for a maxent tv.
Comment by Guest, posted on Dec 10, 2008
CODE TO TV ZENITH I AM HAVE REMOTE PHILIPS UNIVERSAL
Comment by superkillerk, posted on Nov 19, 2008
I can remember my pass code for my t.v. control
Comment by Guest, posted on Nov 15, 2008
lost codes
Comment by pennersthree, posted on Nov 05, 2008
I have a Philips Magnavox Universal Remote Silver with blue and clear buttons and an apex tv set. I cant seem to get the code to get it to work
The remote doesnt have a model number with it.
Thanks, pennersthree@yahoo.com
Comment by jeaniestop, posted on Sep 03, 2008
May I receive the remote codes for JVC?
Comment by weebows, posted on Aug 27, 2008
need code for remotecontrol
Comment by Guest, posted on Aug 13, 2008
entered all the steps including the code mentioned in booklet for my admiral tv/vcr to my phillips remote but still cannot get it to work. My dvd player accepted it just fine.
Comment by ROXYROCK01, posted on Jun 29, 2008
NEED TO PROGRAM REMOTE TO T.V
Comment by Guest, posted on Jun 01, 2008
lost the manual need codes for new tv
Comment by Guest, posted on May 25, 2008
HOW DO U SET A REMOTE CONTROL
Comment by Pattybbb, posted on May 08, 2008
I need a code for my philips universal remote control so I can program my Mitshubi tv.
Comment by juice 42, posted on Mar 01, 2008
i have the exact same type of remote as Kandyegirl,same problem ,only my t.v. is a Duraband model #DU1301. can you please help me find the code to my t.v.?
thanks a million dennispaulson42
Comment by cccecilia, posted on Jan 02, 2008
I have an older Sharp TV Set. Was using an RCA remote, but since changing the batteries have not been able to re-set remote to work. I am also trying a Phillips Universal remote, either one. Please help.
Comment by Guest, posted on Jan 01, 2008
I lost the list of codes for my Philips Universal Consolidator Remote. I have a Mitsubishi tv. Cannot find codes on the internet.
Sponsored Links
Describe your TV problem:
Select a Category:
Top Remote Control Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Remote Control Experts
Top Audio & Video Equ... Repair
(888) 737-1752
We can Fix 3 Red Light Errors,One Red Light...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
