Smart Drive 701 w/machine not spinning
Something is caught in the pump of smart drive 701. Can't remember how to release water and clear it out from underneath.
  • chickeebabe Sep 19, 2007
    We were in the right bit, access from the front for us but the hose seems to be stuck fast and it is a hell of a job trying to get it off (the hose). Can you take off all the screws and take the whole pump off? Any more help appreciated please. Thank you.
  • chickeebabe Sep 24, 2007
    My Partner did that and put it all back together and found what was stuck in it. When trying it out now the agitator bit/roundy thing is making a noise like it isn't together tight (which it is). Any suggustions? Cheers, Nikki
  • 641 Answers
To access the pump, first bail and sponge out any water in the machine's tub. Then tip the washer over on its front, using a heavy blanket or pad to protect the washer's finish. Remove the back service panel. The pump is usually located along the right side of the bottom of the machine, but with the unit tipped on its front it's easier to remove it through the back than through the bottom of the washer. Locate the pump. It has two large hoses attached to it with spring or strap clips. If the clips are the spring type, pinch the ends of the clips together with pliers to release them, and slide the clips down the hoses. If the clips are the strap type, unscrew the metal collar to loosen the clamp. Disconnect the hoses by pulling them off the connections. If the hoses are kinked or crimped at these connections, straighten them as best you can and reconnect them. Good luck!
Posted on Sep 16, 2007
  • Dov Dror Sep 19, 2007
    Yes, you can take off all the screws and take the whole pump off.
SOURCE:
Fisher and Paykel Smart Drive Pride 5.5 washing machine will not pump water out...makes a beeping noise when trying to pump water out.
I own and have repaired my smart drive washer. The water pump is very simple to remove on these machines. Unplug the machine and drain as much water from it as possible. There's a small plastic locking tab on one side of the pump. Gently pry it away from the body of the pump and twist the housing until it comes free from the metal pump housing anchor plate. Unplug the pump from it's connection and remove it. Found a guide that should help you -
How to Drain Washing Machine That Won Empty Cares Appliances
Oct 12, 2018 | Fisher and Paykel Washing Machines
Hello I have a Fisher and paykel 7.5g smart drive excellence washing machine it doesn't spin and I can smell something burning.thanku Kelly
Has it drained the water out. It will not spin until completely empty. If it is not draining then Iwould say the burning smell is the drain pump overheating. Do not try to run it like that as the drain pump will short out the main control board eventually. Bail the water out by hand, tip the machine back against the wall and check the pump on the front right side of bowl. Replace the pump.
Jan 04, 2017 | Fisher and Paykel Washing Machines
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
Fisher paykel aqua smart fault 49
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
Apr 20, 2013 | Fisher and Paykel Aquasmart wl80t65c
701 smart drive washing machine leaking but working no error
is the leaking water brown if so with it being noisier on spin it will prob be the drum bearing are on there way out
May 28, 2012 | Fisher and Paykel Washing Machines
My smart drive model LW015-K top load washer won't
its easy if you know how hahahah the pump either has something jammed in it or its faulty
Jul 21, 2011 | Fisher and Paykel Washing Machines
I have a Fisher & Paykel 5.7kg GW711 smart drive which has become noisy when spining, what could this be.
usually it is the Motor bearing that goes, but not always, Smart drives are notorious, for these motor problems. But sometimes, it can be something caught, in the drum.
Mar 14, 2010 | Washing Machines
Fisher&Paykel Smart Drive 051 keeps beeping/not draining
Hi, I have the same problem and for my wahsing machine it is block pump, so I turn the machine on and advance it to spin and turn the pump fan to help clear the block, the pump locate at the buttom of the basket of the machine...
Mar 31, 2009 | Fisher Washing Machines
F&P smart drive
Yes you have issue with the pump most likely you have something stuck inside it you can try to remove the item yourself or see if it clears itself i recommend you try to remove the object. Good luck
Jan 08, 2009 | Fisher and Paykel IWL12 Top Load Washer
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
182 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
