Question about Ahead Software Nero 6.0 (60045) for PC
Incomplete burning process
I use Nero 7 . I have the mess sage MPEG $ c;losed Than the burning process starts and stops abruptli before the end of the movie I am burning after AVI tarnscoding PLEASE HELP ME> I LOST SO MANY DVD COZ OF HAT
  • 59 Answers
Hiya, ronrib Calm Down. As i have said to many people on here Nero Is not the correct program to use for Movies Unless they are your own, Home-Made If your one of those meny people i have told already To make a real looking movie on to dvd with It's own Menu That you can custom To your own likeings Download this free Trial and take a bash (This program does not put a logo over the movie when compressed It give's you the full version for 3 burns) Heres the link Direct download http://tinyurl.com/2pctld
Posted on Sep 16, 2007
Hello Friends,
It seems nero still has a lock on the drive have you tried to Uninstall/Reinstall Nero.
Putting the drive in another pc will confirm if Nero has done something nasty windows wise to stop the drive working. If it repeats in another pc or if you cannot test this way it may be worth flashing the drive. Samsung has a live update program and some great FAQs on flashing here,
http://www.samsungodd.com/eng/Firmware/FAQ/Faq.asp
There are also links to correctly identify the exact model as you can manually update with the program by entering model number.
Oct 22, 2012 | Samsung SpeedPlus DVD-Writer 20x, Black ...
Tip
Nero 7 Ultra Advance-to-Time Index Problem Work-around
Posted under Nero 6 Ultra because there is no Nero 7 Ultra listing here on Fixya...
OK, I am going to tell you how I managed to work around this problem. I am posting this in the hopes it will save someone else the aggravation I had in stumbling around trying to find a procedure that would fix the problem. I found a work-around I can live with, so here's the problem and the solution follows. If it applies to you, I hope it makes your DVD-burning life livable again! Oh yeah, looks like Nero 8 is ready to come out soon. Just when you though it was safe.... anyway, here goes:
The Problem:
Burning DVDs using Nero 6.2 on Win ME was successful, and it allowed for advancing via time index. For example, I would burn a DVD and be able to go to any time point in the scene. However using Vista and Nero 7 Ultra, while DVDs burn successfully, the advance-by-time index is no longer available in DVDs burned under Vista with Nero 7. Details:
DVD burner: Buslink DBW1647-U2
O/S: Vista Home Basic
S/w: Nero, Ver. 7 Ultra, registered
DVD media: 16X Starlogic DVD-R
DVD player: Goldstar VM681M
The scenario is this:
1. Begin playing a chapter on the DVD
2. Click the chapter menu button on the remote.
3. Use up-down arrow keys on remote to try to get to timed index setting (ie, the one where if you select it and type "10:00" it will jump the scene to the 10:00 mark).
4. Can't select that option.
The Work-around:
1. Open Nero Vision and choose to create a DVD.
2. Access the Options by clicking More>> and make sure Nero SmartEncode is set to 'Disabled'. I think since Nero wants to convert everything to MPEG-4 that that might be a factor. Also, you may need to get some codecs, too. I am using the K-lite full pack available here: http://www.digital-digest.com/software/k-lite_codec_pack.html (Note that K-lite doesn't like other codec packs being on the same PC as it-- it nagged me to uninstall the DivX and Vista Codec Packs, and I did. I have discovered no problems so far since.)
3. Add your video files and step through the rest of the process. Settings to look out for: Automatically create chapters: NOT checked, Enable Forward/Backward Jumping: checked.
4. On the last screen, choose to Write to Disk instead of burning to the CD drive-- select a place to save the DVD-compatible files. Click "Burn" and off you go.
5. After your DVD files are written to disk (they will be in a folder called TS_VIDEO in the place you chose to save them to), fire up a copy of ImgBurn (http://www.imgburn.com/). [Maybe Nero's image burner will work too, I just haven't tried it. In any case this is known to work so I am using it here.]
6. Switch Mode to Build -- you need to build an .iso image file in order to burn it to DVD -- and select the TS_VIDEO folder holding your Nero-ed files. Indicate a name for the output file and run it. This should not take nearly as long as Nero took in creating the raw DVD files. The .iso file you created will be close to the same size as the raw DVD files are in the TS_VIDEO folder Nero created.
7. Now switch mode to Write and indicate the .iso file you built as the input and select the target DVD drive you are using, then run it. The burn process should not take long, either, compared with the other steps.
8. Test it in your DVD player-- you should be able to jump to time indexes now.
I have no idea why this works as opposed to the transcode-then-burn process that worked for me under Nero 6.2. There may well be other ways to deal with this problem, I just don't know what they are. Downside to this approach of course is that you need about 33% more disk space as compared with that required for transcode-and-burn (t-and-b: need space for the original files and Nero temp files; the .iso approach: need space for the original files, the DVD-compatible files Nero creates, and the .iso file created from that). However this is an alternate procedure, not a fix, and the only approach so far I have found.
Plenty of good DVD discs gave their lives to discover this process. I hope I can save you some misery and trips to the store for more blank DVDs by posting it here.
on Feb 22, 2008 | Ahead Software Nero 6 Ultra Edition...
Dvd write error
uninstall nero and restart computer . then reinstall nero
May 13, 2009 | Ahead Software Nero 7 Essentials Suite...
To play mpeg4 with philip dvp5960
I resisted this conclusion for years before I finally got smart and purchased Nero - it will convert your mpeg files to VOB format, at which point you can burn a DVD-video that the Philips player will recognize.
Now, there are other options. If the files are either MPEG-1 or MPEG-2, you can burn them as a Video CD, if the files are smaller than 800MB.
What you cannot do is burn the files as a Data DVD or Data CD - the player just isn't capable of recognizing data discs.
You can try downloading several free programs to convert the MPEG's to VOB format, but, in the end, you will probably just end up infesting your computer with malware/spyware/etc.
My professional opinion is to go ahead and purchase Nero or Roxio to do the job.
-Tha Mp3 Doctor
Dec 28, 2008 | Philips DVP5960
Dvd burning problems with the dvd writer
You may try other dvd burning software such as avs video tools, I always use it to convert and burn DVD, it works pretty well for me, and here is a guide about how to use it
http://www.freedvdripper.net/guides/burn-avi-divx-xvid-mpeg-mp4-to-dvd.html
Hope it helps. Contact me if you have any other question.
Sep 04, 2008 | Computers & Internet
Photo explosion deluxe 3.0 -memories on tv
use nero 7 i have full verison if u have yahoo msg works way bbeter slide shows dvd menus videos u did if your talking about burning dvdv u rent u need dvd fab i have that also for 10 bucks
Jan 24, 2008 | Nova Development Photo Explosion Deluxe...
Incomplete video files
best bet use nero 7 crops takes full video in any formatt and pushes it to dvd with music cool effects relly easy to do
u dont wann make data dvd gonna mpeg 2 formatt for dvd player they make all ok sofwtare to convert your mov videos to mpeg 2 in right formatt for that program uuse if not use nero 7 8 way nicer
Jan 22, 2008 | Roxio Easy CD & DVD Creator 6...
Nero dvd
Hiya, No No No! Nero Don't know any differance If the movies you have downloaded NEW OR OLD are illegal or not Nero is just a program that burns data to a dvd or cd disc Try Unistalling the full program Vir - START - Settings - Control Panel - Add & remove programs and then Re-Installing it Or better still Download a cracked version of Nero Premium 7 from any of these links http://isohunt.com/torrents/?ihq=nero premium 7 Enjoy!!
Sep 08, 2007 | Ahead Software Nero 6.0 (60045) for PC
Ahead Software Nero 6.0 (60045) for PC Logo
193 people viewed this question
Top Ahead Software Computers & Internet Experts
Alun Cox
skyocean
Level 1 Expert
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
