Question about Malber WD1000 Front Load Washer/Dryer
Spacer and balance
When I received my machine, it was already out of the box and the four hexnut screws were tampered. How do I know whether the spacers were removed? Were they an internal items or external. THanks. Next, what is the best way to balance the machine, I am not having much luck especially when the unit is tightly in a closet space and hard to reach the back levering machinism.
  • Anonymous Sep 08, 2008
    How can i balance the machine ,wen do the spin make to moch vibration
    Problem Solver:
  • 13 Answers
The Malber has spacers but does not have a lever in the back so I am not sure what brand of machine you have. If it is the Malber, the spacers in the back are internal and need to be removed. They can be accessed by removing the hex screws and then removing the back panel. The spacers should fall to the bottom of the machine when the hex screws are removed. They can then be retrieved easily with the back panel removed. Be careful reaching into the back of the machine as there are many sharp edges in there.
Posted on Jan 07, 2008
SOURCE:
We got a figidaire washer for a gift (the front loader model). We are having issues with the balancing of the washer... we know the feet turn on the bottom but after adjusting them it still was out of...
hello on some machines there are load senors. you already may have done this get spirit level set the feet of the washer again. also with power off check inside the machine make sure the 2 large bricks are not loose the 1 at the bottom is usually bolted on the 1 at the top is attach by 2 large springs hope it helps
regards
shaun
Apr 23, 2011 | Frigidaire ATF6000ES Front Load Washer
MCS 730 error - tamper open. Although tamper is closed.
Bit late I'm afraid but I'm guessing you didn't use the fifth (centre) screw when you fastened the box to the wall. The centre screw is an anti-tamper device and unless you use it you'll get a tamper open error. I know because I've just been there ("it can't possibly need five screws")!
Dec 11, 2010 | Visonic MCS-730 Outdoor Siren
The handle is loose and the screw seems to be as tight as possible. It is a Moen single handle tub set.
might be that the spacer is missing. there is a small brass spacer located between the handle and the stem. if this is missing, your handle will feel like it's loose.
Jul 24, 2010 | Moen 3189 Legend One Handle Tub And Shower...
I have a whirlpool cabrio. The wash drum has dropped down. Please advise on how to fix
First check whether the cabinet is in good condition If it is ok means you are suppose to change the four springs since these four springs balance the unit one might have got loosen so it is advicable to replace the four sprins
Jan 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have misplaced the manual for my receiver. I need to know how to balance my speakers. I can only do it at the receiver itself.
You haven't told me what make nor model of receiver you have. That would help A LOT. Anyway, most systems have a power amplifier and a pre-amplifier. Receivers have both, but they are in the same box and to the average user are in-distinguishable. The amplifier it's self (for all practical purposes) has no "balance" control. Any gain adjustments including balance, are done at the pre-amplifier level, and in the case of a receiver, that's probably the only place you will have to do any balancing. Beyond that, you may have an L-PAD or some kind of volume adjustment at the back of your speaker cabinets. If that is the case, you could do some additional balancing there, but if you're looking for symetry in your sound, there should be no need for balance adjustment. If you find that one of the channels is noticably quieter than the other, and yet your balance adjustment is set to the middle, then we need to investigate to find out why, but I don't think that is the problem that you are describing. If you already know how to set the balance at the receiver, then you probably know just about all there is to know about setting the balance on that system. Again, I am not familiar with the system, as you have not given me the make nor model.
Oct 24, 2009 | Audio Players & Recorders
Set the timing
take off the bottom cover by removing 4 20 trox screws and 2 or 4 small phillips screws, the bottom part of the hook has two allen screws on it that can come loose causing you to lose timing, lower the needle all the way and then raise it a little bit putting the tip of the hook just above the eye of the needle and then tighten the allen screws and add some lock tight
Jun 16, 2009 | Brother PE-150V Computerized Sewing...
No detailed maps available on my garmon nuvi 205W
You don't provide very much information to work with, so I'll assume your device is new and has NOT been tampered with. If that is the case, then you should burrow into the "Tools > Settings > Map > Map Info" page to see if any detail maps are listed and, if so, whether or not they are enabled. (There should be a little box to the left of the map name and a check in the box. If not, touch the box to make a check mark appear, at which point you've enabled your detail map.)
If your device has been tampered with, you're in a tight spot. Either send it back to Garmin or purchase the full mapset you want installed on the unit -- NOT the map update set -- and follow the instructions for installation.
Jan 13, 2009 | Garmin nuvi 205W GPS Receiver
How to fix excessive vibration during spine cycle?
if your machine is new, and you self installed it, you forgot to remove the shipping bolt, for front load-check the back there are four long screw sometime three depending on the brand , for top load tilt ur unit take a look on the bottom- in the middle again depending on the brand they use a single bolt to hold the tub during transporting- remove it, slide out the spacer it will be ok. now if your unit is some years back already you have your problem with its transmission or gearcase for top loader-quite difficult to fix it sir, or suspension mechanism and bearing on front loader sir- u have to replace it or call a qualified service tech - happy washing soon sir
Apr 06, 2008 | Washing Machines
Asko d1706 dish washer
Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so.
Jan 27, 2008 | Asko D1706 Built-in Dishwasher
Spacers and Balance
take the lid off the spacers should be at the back but when u undue the big hex screws at the back they usually fall out anyway now easiest way to balance is by just using the front adjusters and not the back make slight adjustment on each leg just so you stop swaying from side to side you dont make the washer level level you need it to sloop slightly backwards anyway to stop water from coming out of the soap drawer another thing i do when leveling a washer is once u turn 1 leg with 1 hand hold the washer by the top so u stop it from rocking now adjust the other leg up until that 1 hits the floor and turn once more now try and rock it if it doesnt move from side to side now your done dont adjust the back legs more than likely it doesnt have legs at the back most have wheels on the back now anyway m8
Sep 16, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
66 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Android Man
Android Man
Jason Harris
Jason Harris
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
