Question about E-Machines eMachines Desktop PC
Usb 2.0 ports... which ones are they?
On my wireless receiver that i plug in to any of my 7, windows promts "this is a high speed divice. plug into a 2.0 instead of this 1.1"
  • wwwmotsmag Apr 16, 2009
    the usb ports are not labled their speed.............
  • 52 Answers
Yes i it is better to stay away from 1.1 usb i recommend to use 2.0 1.1 it is still good but it slow transfer. pretty much
Posted on Apr 16, 2009
  • Nasser Abou Agena
    Nasser Abou Agena Apr 16, 2009
    it is fine no need both are the same
  • Nasser Abou Agena
    did you get it working?
How do i use a Samsung external DVD writer model SE-s084 without using the main USB cable. There are 2 USB plugs and i recently broke the main one. is there anyway i can use it with the other plug?
I don't quite understand what you mean with "the other plug", but if you connect your external DVD writer to any USB port, the computer must recognize it and for Windows there is no need to install driver for optical drives.
Probably if you don't want to be left with no free USB ports, you can purchase a USB hub, preferable if you invest in one with external power source like this one: USB 2 0 HUB Powered 7 Port High Speed free AC Adapter
Hope it helps!
Dec 18, 2014 | Samsung USB 2.0 Slim External DVD Writer...
What are the different types of usb plugs and ports .
there are 4.
USB 1.1 - the usb port with white central piece.. very slow.
USB 2.0- white central piece.. normally used in desktops and older model laptops.
USB 3.0 - blue colored port with high speed data transfer.
WI USB -wireless USB connection for wireless mouse, keyboard and other devices.
Jun 09, 2014 | Computers & Internet
Why my siyoteam 4 port usb 2.0 high speed hub not working in windows 8 hp laptop. i plug the port into the laptop but it cannot been seen in my pc, is there any thing can i do inorder this usb hub to work...
Perhaps the laptop port is designed for a usb 3.0 insert instead of a usb 2.0? Also try using compressed air to clean both connections. The hub male end and the laptop female end.
Oct 31, 2013 | Universal Genuine SIYOTEAM 4-Port USB 2.0...
Divice not reconiged
plug it again and if it doesn't work at all try other USB port. A USB flash drive nowadays supports only 2.0 and above USB ports. It all about signal speed a USB 2.0 and above were backward compatible with USB 1.1 .
May 27, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have (2) 1.1 USB ports that says they do not reconise the divice when i plug a divice in , and (1) 2.0 USB port that does nothing but when i go into device managment and check the USB controllers it...
I would suggest two things:
1) Get a different USB device and make sure it works in the ports.
2) Make sure the USB device you want to use is recongnized on another computer. (If possible)
If you have the Vista OS that came on a USB then it is not designed to work on 1.1 USB ports but it should work on the 2.0 port.
Apr 12, 2011 | Microsoft Windows Vista Home Premium with...
How do i connect my wireless i.t.works optical mouse model MWO03 to my eee laptop windows 7?
Follow these steps :
1.
Check to see if your laptop supports wireless technology (Bluetooth, 802.11 or other). If it doesn't, you will need a wireless receiver. If it does, verify that your laptop is compatible with your wireless mouse, which could use either Bluetooth technology or a radio signal.
2.
Unpack your mouse and open its battery compartment. The wireless mouse won't receive any power from the laptop, making batteries necessary.
3.
Add new batteries to the compartment. Make sure that the + battery end is inserted into the + niche in the compartment.
4.
Place the mouse where it is easy to use and least stressful on your fingers.
5.
Place your wireless receiver appropriately if your laptop doesn't support wireless technology. The receiver should be kept at least 8 inches away from the laptop or any other object that would cause any interference.
6.
Place the wireless receiver anywhere from 8 inches to 6 feet from the mouse.
7.
Insert the driver CD into your laptop and follow the instructions to install the software for running the mouse.
8.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop. If you do not have a free USB port, simply use an external USB hub for more ports.
Nov 07, 2010 | Computers & Internet
My videocan not function at usb port
control panel
add hard ware
hit next
install hardware that I manually select
network adapters
find the one you are looking for
Apr 12, 2009 | Intel Motherboard
How do i have a usb port run a high speed device
The USB port in your computer is not the new high-speed USB 2.0 version, and when you plug a USB 2.0 device in you will get that message. Most USB devices will still work but not give best performance. Just close the message window.
The network cable unplugged message can be disabled through the network settings. Normally Windows is set to display that message when there is no network cable connected. You can just ignore the message.
Dec 09, 2008 | Compaq Presario 700 470024-192 Notebook
Wireless keyboard
wireless keyboards and in wireless mouse devices, use the following methods in the order that they appear in.
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Mar 02, 2008 | Sakar 62150 Keyboard
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
