Question about Kenmore Elite HE4 Electric Dryer
Samsung front load dryer had a burning smell-it stopped drying by itself. Dryer power will come on but will not run when start button is pressed. Do you think my dryer can be repaired? It is only a 1 1/2 old. Warrenty is expired. Thanks!
  • 1 more comment
  • mechelle4you May 21, 2009
    The dryer has a faint burnt smell, it also has a little heat coming from it. When I press the start button, the lighting is operating correctly, but it will not start. On the normal drying selection, it makes a humming sound, but will not start.
  • Jerome Barbin May 11, 2010
    It can be repaired. My best guess is you have a burnt wire because of a loose connection. Or a burnt limit switch. I would suggest a pro..good luck.
  • joe accardo
    joe accardo May 11, 2010
    sounds like the motor quit working but need more info could also be a belt
  • 103 Answers
Ck recalls on this issue.
there may be one.
under warranty??
do not buy samsung they are notorious for having problems.
sounds like the heating element and relay may have went out.
however if it does not start up at all it could be the motor itself.
Posted on May 14, 2009
I have a Kenmore H2E dryer model 110.87562602. I don't know what happen but smell burn. the panel control is working well but dont start
burning smell good be a lot thing wrong with your dry .if u know how to take front panel off are the dryer may have a bottom access panel be fore u do any thing unplug dry are turn the power be safe are call a appliance repair tech to fix the dryer for u ok .
Jun 13, 2017 | Kenmore Dryers
Press button dryer clicks but doesn't start
then it means motor is got jammed..
Mar 12, 2008 | Kenmore 63942 Dryer
I have the LG Model# DLE1101W dryer. The dryer will power up but when I go to start the dryer after I put a second load in, I get a series of dinging sounds when pressing the start button and the drye
Id like to see if I could help you so you will have to use more definitive terms, "Start" I'm guessing that you mean that the drum doesn't turn? (the lights come on and you push the start button and the drum does not turn) If that's the case I would start with the door switch, Best to start with the most obvious first. Try jumping it to over ride wait your response
Sep 17, 2014 | LG DLE1101W 7.3 cu. ft. Ultra Large...
Kenmore dryer model 86880100: Start button would just buzz when pressed, sometimes actually start the machine, then the machine would run for a few minutes and turn itself off with a burning smell. Now...
Sounds like a over heated motor which starts when the motor is cool but not after it runs and stop. Burning smell comes from the heated windings on the motor coils.
Make sure that the pully is not binding...which i doubt.
Oct 15, 2013 | Dryers
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Burning smell after hitting the reset button
the lint may have moved into the motor/ or other areas, clean the unit again and have another inspection, checking for burn't wire etc.
Jan 25, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Maytag Legacy Series Dryer will not start
Welcome,
Your temperature is to high and running wild . So the system has shut it down for safety reasons.
You need to call service for a diagnoses
if you do get it running, do not leave it unattended or better yet do not use it as is!
Send me the model number and I can send you the schematics!
Thank You for trusting us with your questions.
Huum
Please remember to leave a solved rating before you sign off!
Dec 22, 2008 | Dryers
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
Dry cycle
Try setting the washer dial to the stop setting at the end of setting number 4 then set the dryer timer and turn on the machine.  This works for mine to get the dryer to run by itself.  It should begin about 30 seconds later, when the door locks.  Hope this helps.
May 13, 2008 | Malber WD1000 Front Load Washer/Dryer
Kenmore Elite HE4 Electric Dryer Logo
1,398 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
