Question about Viking VSM700 Stand Mixer
Paddle attachment is stuck in Viking 7 Qt mixer
  • 2976 Answers
SOURCE: paddle beater won't push up and turn to release
When you are able to remove the paddle, feel the opposite side of the spindle. It should be smooth. The pin should not stick out the back at all. Carefully, tap it in until it is even with the spindle. That will fix you up, unless the pin itself is also damaged. If so, get a small file and remove any burrs from where the paddle mounts.
Posted on Feb 05, 2009
SOURCE: mixer bowl is stuck can not remove
I found a solution at kitchenaid.com. It says the bowl locks in the same direction as the rotating mixer moves, so slap the bowl with your hand a few times in the opposite direction, and then take vegetable oil and using a cotton swab line the groove of the bowl. Let it soak a bit, and then slap the bowl again and push it hard counterclockwise.
Posted on Nov 27, 2008
co7196
  • 3433 Answers
SOURCE: dough mixing paddle will not stay in
pour a little wesson oil into the attachment holes and work the release while inserting and removing the attachment. Make sure the unit is unpluged. The oil will lubricate the lock mechanism.
Posted on Oct 28, 2009
  • 10865 Answers
SOURCE: I cannot remove the attachment on the kitchenaid
Hello. I can assist you. I also have this mixer and I can tell you from experience. You have to lift it up about 1/4 inch and then twist it a small amount and pull it down and out. You can not hurt it so don't worry about using some force when you do this. Good luck with it.
Posted on Nov 16, 2009
  • 130 Answers
SOURCE: mixer blade is chipping
If it is a tilt head mixer then adjust the screw which can be seen by tipping the head back and looking into the pivot point. Turn the screw CCW to raise the head and prevent the paddle from hitting the bottom of the bowl.
If it is a lift bowl mixer there is an adjusting screw on the frame of the stand behind the bowl holder mechanism. It rurns a cam which adjusts the height of the mixer.
See pg. 13 of the owners manual for bowl height adjustment procedure:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209707917.pdf
clockwise to lower the head and counterclockwise to raise the head for more clearance for the beaters.
Posted on Apr 17, 2010
How do I change the gear oil in a food service mixer sp62
About 49 results (0.77 seconds) Search Results
    [PDF]Instruction Manual for Globe Mixers - Globe Equipment ...
    https://globeequipment.com/media/product.../Sp10_Owners_Manual.pdf
    Or call the Globe service department at 937-297-7247 and ask for contact .... Please remember that this manual or the warning labels do not replace the need to be alert, to properly train and .... gears or other parts and WILL void the warranty! 7. ... Lubricate the attachment shaft with a food quality grease or mineral oil. 4.
    SP62P 60 Quart Pizza Mixer - Globe
    www.globefoodequip.com/.../mixers/...mixers.../sp62p-60-quart-pizza-m...
    This mixer comes complete with an 60 quart stainless steel bowl, spiral dough hook and bowl ... High torque direct gear drive transmission; Oil bath transmission.
    Globe SP62P Gear Driven 60 qt. Commercial Planetary ...
    www.webstaurantstore.com > ... > Commercial Floor Mixers
    Commercial Planetary Floor Pizza Mixer - 3 HP. In stock ... What is White Glove service? ... Globe XXBOWL-62 60 Qt. Stainless Steel Mixing Bowl for SP62P Mixer.... Planetary grease fitting and gear oil meter. .... Globe SP62 and SP80PL MixerControls .... 2003-2016 WebstaurantStore Food Service Equipment and Supply .
Jan 30, 2016 | Globe Food Mixers
I own the 6 QT Stand mixer. Is there a Is there a 4 or 5 qt bowl that works with this mixer?
Kitchenaid does not make a 4 or 5 quart bowl that would fit your 6 quart mixer, but other 3rd party companies do!
You may be in luck.
I haven't seen this bowl in person, but it apparently will fit your 6qt mixer. Here is a link to a page selling the mentioned attachment. It comes in a set, with appropriate wire-whip attachments:
http://www.chefscatalog.com/product/25686-kitchenaid-3qt-stainless-bowl-and-whip-set.aspx
Jan 13, 2015 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
My Viking mixer stand bogs down and stops when it is under a serious load. I sent it to a Viking repair place and they adjusted it but it still bogs down and stops under a load. It is the 1000 watt 7 qt...
The best you can do is to send it right back and make them fix it right... there is nothing you can do with that motor to make it run better..
heatman101
Dec 24, 2010 | Viking VSM700 Stand Mixer
Dough mixing paddle will not stay in my wife's Viking mixer
Oct 28, 2009 | Viking VSM700 Stand Mixer
Whisk is stuck..can't be removed. what can i do? mixer is kitchen aid c 4. thanks for any suggestions!!
We had this same issue with our KitchenAid Mixer. Whether it is the whisk attachment or the paddle, the problem is that stuff (most likely sugar based) got into the attachment connection area and dried. It seems like a little sugar couldn't possibly glue the attachments to the stand mixer, but it does.
The solution is to turn the mixer on it's side and pour a kettle or two of boiling water on the section that joins the mixer to the attachments. Pour slowly to allow boiling water to penetrate grooves. Wiggle a little, pour more water, repeat... that should allow you to get it off.
In the future make sure to soak the attachments in boiling water every once and a while to allow all the gook to loose. And let it fully dry before reattaching to mixer.
Jul 13, 2009 | KitchenAid K45SS Classic Stand Mixer
It's completely dead - won't turn on. worked fine
You need to remove the motor and find the heat protection fuse on the side of the windings. The fuse is rated at 140 and has a red tip. You might be able to get one from Radio Shack but Viking sells them for $3. Solder into place and take care not to overheat while doing so.
Jun 30, 2009 | Viking VSM700 Stand Mixer
Paddle beater won't push up and turn to release
Feb 05, 2009 | KitchenAid K45SS Classic Stand Mixer
Flat blade stuck on KA stand mixer
Using one of the bowls, filled it with hot water up to the shaft and where the paddle is hooked up. Using a cotton cloth, wrap it around the paddle and shaft, let it soak for 30 to 40 min. After 30 min, twist the paddle back and forth to loosen up whatever got stuck inside the shaft and paddle. Put a little of mineral oil so that the paddle will be easily remove and it will just slide out from the shaft.
Jul 04, 2008 | Food Mixers
First and second gears seem stuck
You most likely broke a keyway on page 14, item 36.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
The unit is filled with grease, and is not as easy as it may seem. Being that a grease change is likely needed, it's about three hours work for a trained tech.
Jun 25, 2008 | Hobart A200 Stand Mixer
Viking VSM700 Stand Mixer Logo
63 people viewed this question
Top Viking Food Mixers Experts
Tom Chichester
Bill Boyd
Are you a Viking Food Mixer Expert? Answer questions, earn points and help others
