Question about HP Compaq Presario V2000 Notebook
DVD Drive won't recognise blank dvd
I have just installed a new DVD drive in my computer. It was sent from overseas with no instructions, works great reading DVD's but won't recognise a blank DVD. I can't remember where to look on my computer to see what type of DVD i should be buying. I am assuming I have bought the wrong one This is not letting me write the type of Computer I have which is a HP Pavillion a450a
    President:
  • 2,961 Answers
It sounds as if you have purchased a DVDROM drive and not a DVDRW, or the drive if it is a rewritable is faulty.
Posted on Sep 16, 2007
6ya staff
SOURCE:
I installed a sata dvd drive in my dc5100 sff the boot order recognises it as an ide drive
i dont think it matter if your system detects it as sata or ide, both interface will work in installing OS, the important thing is you changed your boot order. originally it was supposed to boot in 1st drive whichever it is hard drive or dvd drive. go to bios then follow the instruction in how to move the order of boot sequence, mine is SHIFT key then PLUS.
Feb 28, 2014 | HP Compaq dc5100 Small Form Factor PC...
DVD drive recognised but disc not recognised
not sure how its recognised on control panel
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Apr 05, 2012 | NEC MultiSpin ND-1300A (ND-1300A)...
My TSST Corp DVD+RW does not recognize MAXELL DVD+RW single sided 4x4.7gb 120 min disk(s) WHY?
Does it recognise other make disks?
A DVD reader/writer may not recognise a blank disk for two main reasons;
The disk is not "prepared" or formatted for use,
or
The computer has been instructed not to "auto run" new disks.
Either way, there is no other reason why it won't see a blank disk.
If the disks have been written on by another computer and not "finalised" your drive might not be able to utilise anything that is on it.
I hope that answers your question.
Nov 28, 2010 | HP Computers & Internet
Cannot replace corrupted bios, wont recognise hard drive. no windows installed, blank hd. how can i install a new bios direct to the mb using dvd drive?
A motherboard must have a working BIOS, because the BIOS (Basic Input-output system) contains the instructions that get the computer started enough to be able to turn on the hard drive and the CD drive (and the floppy). A search online should yield a service that can install a bios, or yield a place where you could buy a pre-flashed bios chip for your motherboard. This is step one. Once you have this, you can do all other installs, assuming that the motherboard is ok. Good luck.
Nov 26, 2009 | ASUS A8V-E SE Motherboard
DVD-RW not recognising blank disk
Usually HPs are good with +R DVDs unless things have change over the last year or two.
Whats the model number on your computer?
Aug 09, 2008 | Tablets & eReaders
My DVD burner is not recognising blank DVD
i had that problem and turned out ot be defective drive. if u cant boot a known good cd like memtest.org (extract them burn .iso image with imgburn.com)
Jun 16, 2008 | Pioneer DVR-110D DVD RW Dual Layer Burner
Dvd rw
Is this drive new, or new to you and has it worked before on your system with DVD's. Has your System been reloaded lately or been recovered from a System Crash? What Operating system is on your computer? Are the DVD's Blank, Movies or Software???
The drive is in your computer? What Brand? any Idea?
How long since you put a cleaning disc through the Drive?
Answer these Questions and maybe we can help... C
May 24, 2008 | Computers & Internet
ATAPI DVD A DH16A1L not reading blank dvd's
This is a firmware issue that I am also having the same problem with. The only real solution is to purchase a new drive temporarily, since the DH16A1L firmware update is precariously a "Vista Only" update. If you have XP or Windows 7, you are SOL, thanks to the lovely folks at HP.
This was my business' last purchase of any HP hardware, we have had enough of the fried laptop mobos and issues as such. I hope everyone follows suit
Feb 10, 2008 | Computers & Internet
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
