Question about Samsung SP-R4232 42 in. Plasma HDTV
Intermitten remote sensor issue
I have a 42" SP-R4232 Plasma. For some reason the TV stops reading the remote. When it works the blue light blinks, but when the TV stops reading the remotes for some reason the blue light stays solid. There is no other equipment in the room that could be causing interference. Tried several remotes and none of them work. Not sure what the issue is and I cant afford the service right now, honestly dont want to waste my money if there is a simple solution. Also I am using Comcast HDTV box with the tv.
    Sergeant:
  • 261 Answers
Sounds like to me the comcast HDTV box is the issue if you are using that to change channels. Let me know.
Posted on Feb 01, 2008
Inverter
The blinking blue light are fault indications. From the number of blinks that occurs at one time switch ON, you can get an idea about the faulty circuit section inside it. Even though you've got this idea, service to Plasma TVs are somewhat difficult one for a user, who do not have any knowledge in electronics. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong. Blinking codes to Samsung Plasma Displays are described in detail by one among the posts. Pull up older posts.
May 05, 2013 | Samsung SP-R4232 42 in. Plasma HDTV
My Samsung SP-R4232 has some type of power supply issue. I called a tech who came out and verified it. He thought it was the main power board, but wanted $400 to fix it when I found the part online for...
U replaced the tv power supply board,the board u replaced,that is the board where the power a/c cord plug into it?Check ur old power supply board,examines all parts,see if u have any capactors parts are bulging or puffing up on it tops.Yes,than it is power supply board issue.But by replacing the power supply board only get 50/50 chances for the tv to work.Might be the problems,might not be the power supply board issue alone some times.The chances are tv Tuner signal board is dead also.That the board,where the tv incomming broadcasting signal cable plug into it.Try website like Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 04, 2010 | Samsung SP-R4232 42 in. Plasma HDTV
SSP-R4232 Plasma TV, blue light on, but tv wont turn on.
At this point it appears that your main board is probably bad. You most likely have a 5 volt scource going to the main board but its not powering up the set. The main board is part number BN94-00796A.
You might want to have a technician look at the TV to verify this as the issue before purchasing it. Please take a few moments to rate my answer. Thank you.
Nov 18, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung sp-r4232 power button blinks 4 times but tv wont turn on
I have this TV. My father in law tried to turn it on one day and it started making a clicking sound and never came on. So he went out and bought a new tv and gave it to me. It came on when I brought it home and worked for a couple weeks. Then just the other day it stopped working. When you hit the power button the light around it blinks four times and then you here a clicking sound. TV does not come on. Took the back panel off and I don't see any damaged caps or fuses. b435b80e-6d09-419f-a021-9b8a430e0a74.jpg
May 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung SP-R4232 Plasma TV
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung Plasma 42 in SP-R4232
How do you have the set hooked up? Component or composite?
Does the menu look red as well when you hit the "Menu" button?
Jan 19, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Evidently 2 good remotes point at the problem being the remote sensor on the TV itself. I have about 4 remotes I can adjust volume w/ including the remote that came w/ my samsung. The TV exhibits the same behavior w/ all of them.
Per the samsung site, the "test" for this (remote vs sensor) is to us a digital camera, (including the kind that's on most cell phones) to "see" if the remote lights up. Just point it at the camera/phone, and press any button. You should see a bright flashing light on the camera/phone's LCD screen. If not, REJOICE! All you need to replace is the remote or batteries in it. If you do see the light, good luck if you're not in warranty. I've been unable to find any procedures for replacing this kind of item.
Nov 13, 2007 | Samsung DLP HL-P5663W 56" TV
Electricity went out in town, tv won't turn back on.
On this type of problem, the first thing I check is the AC line fuse on the power supply. Follow the Ac plug wire to the power supply board and where it plugs in, you will find the fuse. If: Then: It checks bad. Replace it. It goes out again. Call a Servicer. It is good. Check for the five volts that goes to the Main PCB. No five volts, change the power suppy (SMPS) Five volts is there, more than likely the Main needs replaced and SMPS. For a Samsung Servicer in your area: 1-800-SAMSUNG
Aug 18, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung SP-R4232 42 in. Plasma HDTV Logo
152 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
