Question about Whirlpool LER5636P Electric Dryer
Dryer making funny noise
The dryer heats and spins but it makes a horrible noise while it is spinning, like it came off its track.
  • 77 Answers
If your dryer is old, your probably right. Your drum rolls on 3 rollers and they tend to get "out of round" after years of use. If you want to change them, you will have to remove the drum from the front of the dryer (after removing the door) and they will be attached to the rear wall. Good luck. Your fix it cost is around....$50.
Posted on Apr 17, 2009
Doesn't want to go onto spin cycle just makes funny noises
Possible that there is slippage when the program comes to the spin mode. Please check the drive and see if the belt is slipping or the drive is jammed. If not check the motor drive.
Jan 21, 2013 | Beko Washing Machines
Dryer won't spin
If you have kids and they over fill the dryer it strains all systems including the heater because it cannot get rid of excess heat. Solution*** Possibly needs a new belt
Dec 07, 2012 | Maytag Dryers
My washing machine will not spin. It sounds like its off track or off gear or something. It just makes a horribly loud noise.
Most important in such a case is a perfect observation. So remove power and look for the motor drive. Manually check for the drive turning the pulley of the motor , check if there is any jamming or mechanical fault in the drive shaft , if so you will need to reset - over haul - this section.
Feb 19, 2011 | Frigidaire FEX831CS Top Load Stacked...
Washer doesn't spin, just makes funny noise.
i would change the coupler between the motor and transmission.... whirlpoolpartssurplus.com
Jun 23, 2009 | Whirlpool Washing Machines
The spin cylcle does not work . It makes a funny noise and does not spin
the drain is probably clogged you'd be surprised home much is in there
Apr 26, 2009 | Washing Machines
Gas Dryer LDG7304AAE making horribly loud noise while drying
Solution for the Maytag model is most likely to replace the blower wheel. Remove the two screws on the front panel (just a couple inches off the floor) and swing the front panel up to allow you to unhook the top side of the panel from the clips at the very top of the front panel. You do not have to remove the wires, just set the front panel to the side. Blower wheel is at the lower left. The old wheel most likely no longer has a D shaped hole to match the motor shaft, and spins freely. Remove cover. Replace the wheel part number Y303836 for a LDG7304AAE which is held on the shaft with a spring type clamp. Reassemble. Not really very hard to do. On a difficulty scale or 1 - 10, I'd rate it a 3.
Dec 06, 2008 | Dryers
Groaning sounds when dryer spins
yes it is, its the rear tub bearing. pain in the butt to change but that will solve it
Nov 20, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
641 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
