Question about Panasonic KX-T7731 Corded Phone
Programe my phone KX-T7730
Hai there, i have five lines and 6 extensions, i would like to block some lines for some extensions wats the programe code to block and unblock lines to teh extensions. how should i do it. regards Sebastian
  • Anonymous Mar 12, 2014
    we are using 5 lines here in the office,i have programmed each line with different extension numbers of 5 people..How can I remove the saved extension numbers?please help
    Novelist:
  • 201 Answers
The phone you have (KX-T7730) requires a phone system to operate. This phone can be installed on a few different Panasonic phone systems. You need a "programming" manual for the phone system to do what you want (not a user guide) so you will first need to determine which system you have. Look for a part number on the system itself, it should start with "KXT" just like the phone.
Posted on Sep 16, 2007
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    How can i program an outside co line i added an expansion card for a kx-te824 andwe have six lines how can i access the other the other 3 lines with a kx-t7730
    In program 400, you tell the box you have 6 lines and enable them. On the phone, press PROGRAM and the positions where lines 4,5 and 6 appear and read the display. If it doesn't say CO4-6, then dial 04 STORE 05 STORE etc on each position.
    Carl
    Feb 03, 2011 | Panasonic KX-T7730 Corded Phone
    Hi I have panasonic kx-t7730 and I have a problem. We have two lines but only rings on switchboard. We also Use cordless panasonic phone but it does not ring unles i transfer to it. I have already done...
    In a TA series, the ringing is programmed in system programs 408-410. You go to the main phone, enter system programming, and select those options and turn on ringing per line and per extension.
    Carl
    Sep 03, 2010 | Panasonic KX-T7730 Corded Phone
    Panasonic kx-t7730
    Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
    PLEASE vote if this was helpful
    Mar 23, 2010 | Panasonic KX-T7730 Corded Phone
    How do I change the extention names on KX-T7730?
    If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
    From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
    1. Press PROGRAM * # followed by the system password ( default is 1234).
    2. Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ).
    3. Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change.
    4. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered.
    5. Press PROGRAM to exit program mode and you are done.
    How do you program a Panasonic KX-T7730?
    I assume that you want to program the extension names.
    If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the hook/cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
    PLEASE rate / vote this answer if it was helpful.
    Thank you.
    May 18, 2009 | Panasonic KX-T7730 Corded Phone
    I want to Reprogram a KX T7730 phone to allow outside lines
    Doorphone ringing is programmed in 607 and 608.
    With luck, flip the manual back a couple of pages and hope that the extensions are restricted via outgoing line access in 605 and 606. It's the easiest way, but there may be some COS restrictions taken care of in 601.
    Carl
    Apr 08, 2009 | Panasonic KX-T7730 Corded Phone
    Seems to be locked into a program - do not have a manual
    If using the KX-T7730 phone on a Panasonic 308/616/824 system press Program 11 and then AUTO DIAL / STORE . Press Program to exit programming mode.
    If this answer was helpfull please vote
    Thank you.
    Oct 15, 2008 | Panasonic KX-T7730 Corded Phone
    Need to program pf buttons on kx-t7730
    Press Program Button
    Press Button to be Programmed
    Dial 1 - Plus extention number to be stored on button
    Press button directly under 'ENTER'
    Feb 12, 2008 | Panasonic KX-T7730 Corded Phone
    Program manual
    Your phone will work on a few different Panasonic phone systems. If you are looking for manuals on KX-T7720 and KX-T7720 all you will find is a user guide for the phone. You need to determine the model number of your phone system before starting to look for a programming manual.
    Jul 17, 2007 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-T7731 Corded Phone Logo
    559 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
