Question about Dryers
Dryer has electrical power, but won't start with start-button
  • 77 Answers
You may have a bad start switch. But possibly more likely a bad door switch.
Good luck.
Posted on Apr 17, 2009
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
Bosch Nexxt WTMC 6300 Electric Dryer won't start/ no light, No power
check and see if the outlit it is plugged in to works with somthing simple like a light somthing may have triped the breaker in your house
Jun 05, 2012 | Bosch Nexxt WTMC 6300 Electric Dryer
Does not respond to button press and won"t turn
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 31, 2011 | Kenmore Elite HE4 Electric Dryer
Is there a reset button on a Maytag electric dryer purchased in 2000? Power is coming into the dryer, pushing the start button has no effect.
check the switch itself ,, you can do this with a meter and checking for continuity when the button is depressed, also check the door safety switch,, it won't run if this switch is defective,, you can check this one the same way , or just locate the connection, and add a jumper wire, to see if the machine starts
Aug 10, 2011 | Maytag Dryers
Power button stays depressed and does not start power menu. power is on, drum light is lit.
You will need to replace the control panel. The button is pressed in the down position and won't allow you to do anything else till this part is replaced.
Jun 12, 2011 | LG DLE2514 Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
