Question about HP Photosmart C5180 All-In-One InkJet Printer
Hp Printer CD ROM Problem
When the computer is first started windows installer appearsautomatically on the desktop. It says, ''windows installer preparing toinstall'' and then something about a document viewer. This all loads fora few second and a new message appears saying,
''The feature you are trying to use is on a CD ROM or other removabledisc that is not available. Insert the document viewer and click ok''.
When clicking the red cross to close this window this message appears,
''error 1706 no valid source could be found for product Document viewer. The window installer cannot continue''.
''Microsoft.Net Framework
An unhandled exception has occurred in a component in your application.Click continue and application will ignore this error and attempt tocontinue. Object reference not set to an instance of object''.
Clicking on continue or the red cross to close does nothing the windowjust remains the same. The only way to get rid of it is ctrl, alt,delete and then select end programme for the document viewer.
How can this be stopped?
I have the CD Rom to fix it and it does fix it for a week then it happens again and keeps happenin,
would really appreciate the help
Thanx
  • 1 more comment
  • darrenmkemp Apr 18, 2009
    Seems to be good only been 2 days though but thank you very much for your help. Will let you know if anything changes but so far so good!
  • darrenmkemp Apr 25, 2009
    Im now getting similar thing but this time it asks for a scan disk so don't think it has solved it.
  • darrenmkemp Apr 26, 2009
    Windows XP
    President:
  • HP Master
  • 1,996 Answers
Unfortunately, this is a frustrating and widely reported issue. Apparantly the HP software is not compatible with Office.
If you have reinstalled the document viewer.msi file from your cd repeated times and you keep getting popups indicating its failure, you will need to uninstall the document viewer.
Here are the instrucitons, courtesy of Jasdev Singh:
">> If you have installed any all-in-one printer driver software then put the disc in
else follow Step 2:
Step 1:
>> Put the printer disc in and goto Setup folder and search for Document viewer folder.
You will find two files under that. Double click on DocumentViewer.msi and install that. if you right click you will get repair also.
Step 2:
>> if you dont have any disc then goto Control panel and select Add/Remove Program.
>> Remove DocumentViewer entry. "
If you can't uninstall from Add/Remove programs or don't find an entry for the document viewer there, go to this link and download the Windows Installer Clean Up utility Download, Install, and Run this application...
>> I am sure you can select DocumentViewer now and hit Remove button.
This will clear DocumentViewer from you computer."
Please also refer to this KB article for additional information about clearing your temp files, etc.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 16, 2009
  • 3 more comments
  • efs_perpends
    efs_perpends Apr 19, 2009
    Glad to hear it! That's progress, at least...
  • efs_perpends
    efs_perpends Apr 26, 2009
    What operating system are you running, xp or vista?
  • efs_perpends
    Can you report back with the exact error message you are getting, and what is bringing it about?
  • efs_perpends
    Try this:
    Follow the steps outlined in this Microsoft article to run chkdsk from My Computer or Explorer, select auto fix file system errors, then restart your computer, and let chkdsk run. It may take an hour or more, depending on how many files you have. You will need to just let it run without interruption.
    Then reply with the results...
  • efs_perpends
    Here's the missing link (click here) from that last comment
Hp 1402 fatal error and MSI.scan
Hi Ihan,
You are facing terrible problem with that error message.. However we can try to fix it. There are few methods you can do..
Solution 1.
  1. Insert the product software CD into the CD-ROM drive on the computer.
  2. Right-click Start and then click Explore . Windows Explorer opens.
  3. Locate and select the CD-ROM drive that contains the product software CD.
  4. Locate and double-click the Setup and then the Scan folders to open them.
  5. Double-click Data1.cab or Scan.cab to open the contents of that file.
Extract, rename, and save the filesLocate the following files, right-click them, select Extract , and save them to the Windows Desktop. Leave Windows Explorer open after extracting the files.
  • F1922_TWUNK_16.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the Desktop, right-click it and rename it to TWUNK_16.EXE .
  • F1923_TWUNK_32.EXE.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWUNK_32.EXE .
  • F1928_TWAIN.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWAIN.DLL .
  • F1939_TWAIN_32.DLL.096CD9AA_35CA_455C_ADCB_36EF6B7F7892After extracting this file to the desktop, right-click it and rename it to TWAIN_32.DLL .
Then you have to copy these files to C:\windows\system32 folder ( this means overwrite the files ) and try to install the software. it should work.
for better understanding check the link below.
MSI.SCAN Solution
Solution 2.
you need to remove all the HP Printer entry from Add/remove or Programs and features under Control panel.
Then download the latest software from HP website by clicking on the link below.
HP PSC 1402 Printer Drivers
Regards,
Suhail
Oct 19, 2011 | Office Equipment & Supplies
How can i install windows xp on hp compac dc 7900. blue screen error shown during installation
Restart the process again...insert the cd in to the cd rom..restart the computer then you will see a screen which says press ant key to boot from cd...press space bar..the installation will start from the point where it was left when you received the blue screen...
If the blue screen is coming again and again then contact any local tech there might be some hardware issue.
Also make sure while installatng the windows there is no extra peripheral attached with the computer like printer,webcam,mass storage device etc.
Aug 18, 2011 | HP Compaq DC7900 PC Desktop
How to format and instal windows xp to hp compaq d530 desktop pc???????
Hello, just start the computer an while starting (bios post) touch the del or esc or f2 or f4 just try one of theese when you can enter the bios menu then you go to start order and you choose first dvd/cd rom and second hdd0 always go to save it and exit, the computer wil restart then put in the cd/dvd rom drive the windows cd, restart the pc and when it says some thing like push enter to boot from cd/dvd rom then you push on enter and follow the instrucction till the end!
success!
Apr 03, 2011 | HP Compaq d530 SFF PC Desktop
Color printed pages are too light.
  • Troubleshooting Setup and Install If your device is not recognized:
    • Verify that your cable is USB 2.0 high-speed compliant.
    • Ensure that your cable is connected correctly. Remove the USB cable, look at the end of the cable, and then match it to the pattern on the USB port. Make sure that it is not upside down. Insert one end of the USB cable completely into the USB port on the HP device and the other end into the back of the computer.
    • Check that the peripheral is turned on. Peripherals will not be recognized if the power is off.
    • Ensure that your USB cable is no more than 15 feet or 5 meters in length.
    • Check that the USB port is enabled. Some computers ship with disabled USB ports.
III. INSTALLATION INSTRUCTIONS When operating in a Windows environment, the CD-ROM setup or installation software detects the version of the operating system that you are running. The software is installed in the language that you have selected. For example, if you are running an English version of Windows and have the language preference set to Spanish, the installation utility will install the Spanish version of the printing software for the appropriate Windows version. INSTALLATION OPTIONS Two methods are available for installing printer drivers and software components for the printer.
  • Full (Recommended) . Installs everything that your device needs to work plus HP Solution Center:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL6 driver
    • HP Toolbox FX . Allows you to change some printer settings and contains documentation and self-help tools.
    • Screen Fonts . Printer-matching TrueType fonts help ensure WYSIWYG printing.
    • HP Color LaserJet 2605 series printer documentation. A list of documentation, which includes information about product operation, troubleshooting, warranty and specifications, supplies, and support.
    • HP Solution Center . Use HP Solution Center to gain access to product-specific software and on-screen help. By using HP Solution Center, you can access the HP Shopping Web site and update your HP software. If you have the HP Color LaserJet 2605dtn, you can also transfer images from a photo memory card. To start HP Solution Center, click Start, Programs, choose the HP program group, and then click HP Solution Center.
    • HP Photosmart Transfer . Software for transferring images from photo memory cards to your computer (HP Color LaserJet 2605dtn only).
    • HP Product Assistant . This software detects problems that occur with your HP products and can offer solutions to help you resolve those problems.
    • HP Software Tour . Use this for an overview of the software features.
    • HP Software Update . Use this software to check for software updates for your HP products.
  • Minimum . Installs everything that your device needs to work. The following is a list of available components:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL 6 driver.
INSTALLING SOFTWARE ON WINDOWS 2000 and XP Printing system installation from CD-ROM, Internet download
  1. Close all programs.
  2. Insert the CD-ROM.
  3. If the HP printing system installer program has not started after 30 seconds, complete steps 4 through 7.
  4. From the Start menu on the taskbar, select Run.
  5. Browse to the root directory for the CD-ROM drive.
  6. Select the SETUP.EXE file, click Open, and then click OK.
  7. Click Install.
  8. Follow the onscreen instructions.
USB Installation for Windows 98 Second Edition, Windows Me and Windows Server 2003 (Plug and Play Install)
  1. Turn on the printer and computer.
  2. Verify that the printer displays “Ready.�?
  3. Attach the USB cable to the printer and computer.
  4. When the Add New Hardware Wizard appears, click Next to install the USB Printing Support.
  5. In the following dialog, select option Search for the best driver for your device, and click Next.
  6. Make sure the HP Color LaserJet 2605 series CD-ROM is in the CD_ROM drive, select Specify a location, browse to your CD_ROM drive, and select the Drivers folder, then either Win98_Me( for Windows 98 and Windows Me) or Win2000_XP (for Windows Server 2003). For example, CD ROM drive:\Drivers\Operating System\Language. Choose OK, and then click Next.
  7. For Windows 98 SE, in the USB Printing Support dialog, you should see the path and file name. Click Next. For Windows Me and 2003 Server, this step may not apply.
  8. Once the files are copied, click Finish.
  9. Steps 4-9 will repeat to install the printer driver. File names will change. At step 9, you have the option to rename the printer. Click Finish. After files have installed, click Finish to close the dialog.
Network Installation for Windows 98 Second Edition, Windows Me, and Windows Server 2003
  1. Download HP's Install Network Printer Wizard.
  2. Run Install Network Printer Wizard and follow the on-screen instructions.
INSTALLING SOFTWARE ON MACINTOSH OS 10.2.X, 10.3X, and 10.4.X USB installation instructions
  1. Insert the CD-ROM.
  2. Run the installation utility.
  3. After the software installation is complete, attach the USB cable to the printer and the computer and then restart the computer.
  4. After the computer has restarted, open the Print Center or Printer Setup Utility to see if the printer name appears in the Printer List.
  5. If the printer name displays in the Printer List, the setup is complete. If the printer name does not display in the Printer List, go to the next step.
  6. Click the Add button, and then select USB from the drop-down list. 7. Select HP Color LaserJet 2605 and then click Add. The printer name displays in the Printer List. Setup is complete.
Jan 27, 2010 | HP LaserJet 2605DTN Color Printer
When I install the D7260 printer using the CD-Rom supplied it works fine. Then after a few days only the top two or three lines of the first page are printed and, after a long pause, the sheet comes out....
Many issues are caused when the HP Photosmart is connected to computer using a USB cable before the HP Photosmart software is installed on the computer. IF you connected the HP Photo smart to your computer before the software installation screen prompts you to do so, you must follow these steps.
Troubleshooting common setup issues :
1) Discoonect the USB cable from the computer.
2) Uninstall the software (if you have already installed it.)
3) Restart you computer.
4) Turn off the HP Photosmartm wait one minute then turn it on.
5) Reinstall the HP Photosmart software.
If your installation is incomplete, or if you connected the USB cable to the computer before prompted by the software installation screen, you might need to uninstall and reinstall the software. Do not simply delete the Hp Photosmart application files from your computer. Make sure to remove them properly using the uninstall utility provided when you installed the software that came with the HP Photosmart.
To uninstall from a Window computer and then reinstall
1) On the Windows taskbar, click Start, Settings, Control Panel (or just Control Panel).
2) Double-click Add/Remove Programs (or click Uninstall a program).
3) Select HP Photosmart Driver Software, and then click Change/ Remove.
4) Disconnect the HP Photosmart from your computer.
5) Restart your computer.
Note : It is important to that you disconnect the HP Photosmart before restaring your computer. Do not connect the HP Photosmart to your computer untill after you have reinstalled the software.
6) Insert the HP Photosmart CD-ROM into your computer's CD-ROM drive and then start the Setup program,
7) Follow the onscreen instructions and the instructions provided in the Setup Guide that came with the HP Photosmart.
Nov 09, 2009 | HP Photosmart D7260 Printer
How can I install my printer without using an CD rom installer
you should windows will recognise it and install the drivers,however hp website contains the cd rom you want it will take some time to download though,go to the support page input your model and operating system.
good luck
Sep 11, 2009 | HP DeskJet F380 All-In-One Printer
Downloaded drver for my printer. the add new printer wizard can't
Hi ...
If you have the driver CD that you recieved with your printer, follow the below steps to install the saftware:
  1. Turn on your computer.
  2. On your computer quit any open applications, including virus checkers.
  3. Insert the MultiPASS MP730/700 Setup CD-ROM into your CD drive. The [MP Setup] splash screen will appear automatically.
    1. If MP Setup does not start automatically, on the Windows desktop, double-click My Computer (on Windows XP, click Start then click My Computer).
    2. Double-click the CD-ROM icon. If MP Setup does not start, double-click 'Setup.exe' (on Windows XP, 'Setup').
  4. In the MP Setup splash screen, click 'Install MP Drivers'.
    Note: For Windows 2000 users, if Service Pack 1 or later is not installed, MP Setup will display a message and installation will be aborted.
  5. Follow the on-screen instructions, clicking the appropriate button to move from one screen to the next.
  6. MP Setup will install some system files and may prompt you to restart your computer. If you are not prompted to restart, click 'Finish' in the MP Drivers Setup window and then proceed to step 7.
    1. If you are prompted, make sure radio button 'Yes, I want to restart my computer now.' is selected in the MP Drivers Setup window and then click 'Finish'. DO NOT remove the CD-ROM at this stage. MP Setup splash screen will open after Windows has restarted.
    2. If you had to restart your computer and the MP Setup screen is not displayed or you closed it, on the Windows desktop, double-click My Computer (on Windows XP, click Start then click My Computer).
    3. Double-click the CD-ROM icon. If MP Setup does not start, double-click 'Setup.exe' (on Windows XP, 'Setup').
  7. In the MP Setup splash screen, click 'Install MP Toolbox.'
  8. Follow the on-screen instructions, clicking the appropriate button to move from one screen to the next.
  9. At the MP Toolbox Setup dialog box, click 'Finish'.
  10. Confirm the MultiPASS is turned on.
  11. Connect the USB cable to the MP730 and computer USB ports. Windows will detect the printer and proceed to install the driver files.
  12. Your MultiPASS includes additional software applications that you can install now or at a later date. To install the software, click 'Install Utility Software' and then proceed through each installation.
You can also download the drivers by visiting the below link and selecting your operating system.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=9035#DownloadDetailAct
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Computer can not find bluetooth device printer HP Photosmart C
Step one: Install the softwareRe-install the software so that the appropriate choices can be made during the installation to resolve the issue.
  1. Insert the printer software CD in the CD-ROM drive of the computer. The software installation starts automatically.
    NOTE: If the software installation does not start automatically, click theStart (c00845897.gif ) icon. In the Start Search text box located above theStart (c00845897.gif ) icon, type D:\setup.exe , where D is the letter of the CD-ROM drive, and then press Enter .
  2. On the User Account Control window, click Continue .
  3. Follow the instructions that display on the screen to install the software.
    NOTE: If the User Account Control window displays during the installation, click Continue .
  4. When prompted to choose the connection type, select Directly to this computer using a USB cable and then click Next .
  5. On the Connect Your Device Now window, select If you are unable to connect your device now, click this box and then click Next to finish installing the software. You can connect your device later.
  6. Click Next .
  7. Follow the instructions that display on the screen to complete the software installation.
Step two
AND STEP THREE
GO TO URL
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00845953&lc=en&dlc=en&cc=us&product=447858
Dec 13, 2008 | HP Photosmart C5180 All-In-One InkJet...
All my hardware is HP. I am on my laptop (Vista). My desktop (XP)will not boot up properly after I installed a new HP Monitor & Printer (Printer works OK). The monitorgive the following message: ...
ok..sounds like an operating system mismatch...you may need to remove the software entirely, go to www.hp.com and get a fresh edition of the print manager..sometimes that file gets corrupted..
Oct 14, 2008 | HP Computers & Internet
Hp computer
You can repair that by booting your system using the CD ROM and the select to repair windows.
If ever this will not solve then;
You should backup your files and reinstall the windows operating system.
In installing operating system you need the following:
1 windows bootable disc/ Operating System REcovery Disc
2.Cd /DVD rom
Boot your system any of this CD/DVD disc and then follow the on screen instruction.
After installation, don,t forget to install the drivers of your system that was enlosed in your system.
If ever there problem arising this solution please notify me for further support.
Jan 22, 2008 | HP Pavilion Media Center a1330n - AMD...
HP Photosmart C5180 All-In-One InkJet Printer Logo
436 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
