Question about Car Audio & Video
I want to install a second monitor into my Nissan Titan crew cap. It will be located on the passengers sunvisor. If I tap into the existing system, I only need power and video. Power is a no brainer, but finding the correct video wires brings me to a full stop. Utilizing my factorey system, I do not need audio, nor do I need a remote control. I already have them. Probably sounds quite easy for you, but although I do alot of electrical work on rehabing cars, I never really got into the electronics too much. Can you help me out with a schematic, or just identify the wire(s) that I need to splice into ? Thanks in advance, Phil Pace
  • pmpace1966 Apr 17, 2009
    Sorry, 2005 Titan crew cab. Also, it came with the rockport audio system upgrade. Phil
    Thank you so much for helping me out. Let's see what info you have and as you suggested, if I am in need of further assistance, I'll go to the website you have recommended. My e-mail is pmpace1966@comcast.net
    Thanks again, Phil
  • 10,594 Answers
Thank you and good luck!
Posted on Apr 17, 2009
    Brigadier General:
  • 5,158 Answers
What year is that ?
Posted on Apr 16, 2009
  • Roberta Smith
    Roberta Smith Apr 17, 2009
    if you could provide me your email address i have a document with pretty much all the audio and video wiring combinations you would need
  • Roberta Smith
    as this doesn't specifically address the video part of the wiring i may still require your email address to send you the document.... but here is a webpage that may help http://www.the12volt.com/installbay/foru...
2011 Nissan Titan Crew Cab - Heater only works on 90 degrees, what needs to be fixed?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
2011 Nissan Titan Service Repair Workshop Manual Instant DOWNLOAD
Dec 01, 2016 | 2011 Nissan Titan Crew
2011 Nissan Titan heater/ac fan blows on high we replaced the VBC it did not fix it, now what?
What is VBC? Ah, probably Variable Blower Control? my guess you got wires crossed, or a short around the control or even direct short to hot (12vdc) wire. Double check your work, wire connections. Instructions? with the new? double check.
Feb 27, 2015 | 2011 Nissan Titan Crew
Water temp sensor on 2005 nissan titan
Here's a link to your coolant temp. sensor,you may have a coolant temp. sender too,they are by each other, Duralast Coolant Temperature Sensor SU4072 2005 Nissan Datsun Titan 2WD... Here's a part list. Part Detail There's no way to test it,just have to replace and see if it solves the problem.I have a 85 nissan 720,mine has both sensor and sender,the sender operates the gauge on dash,the sensor sends signal to the brain.
Jul 19, 2014 | 2005 Nissan Titan Crew
2005 Nissan Titan AC compressor not energizing
proberly needs regassing as are belt driven if this is all ok does the heater/a.c switch work?
Apr 22, 2014 | 2005 Nissan Titan Crew
2010 Nissan Titan goes full hot
Take back To Nissan dealer,warranty will cover.
Dec 02, 2013 | 2010 Nissan Titan Crew
Nissan Titan power window not working
1. check n replace p/w crane cable assembly.2.p/w motor switch,fuses etc
Feb 26, 2012 | 2005 Nissan Titan Crew
My drivers side air bag deployed and the Nissan Service Manual indicates the Spiral Cable assembly must be replaced with the air bag module. Niether I nor my local dealer can locate any part called the...
What kind of dealer can not locate spiral cable?
The name of that spiral cable is CLOCK SPRING ,
it's under steering wheel , connecting air bag at wheel to main harness.
I would recommend to change the dealer before your air bag shoot you in the face.
May 05, 2010 | 2004 Nissan Titan
Trying to change the cabin air filter
1. Open glove box
2. Unhook elastic retainer on right side
3. Locate the two "stop tabs", one on the upper left and the other on the right side. Push both to the left to clear their stops and the glove box will swing down, allowing access to the filter cover.
May 06, 2009 | 2004 Nissan Titan
Car Audio & Video Logo
48 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
