Question about Kodak Easyshare C813 Digital Camera
Downloading photos How do I download the photos on my camera to the computer?
  • 4 more comments
  • phoenix16 Dec 31, 2007
    my computer has the software and the camera displays the letters "FL" however, when i initiate the download the computer states "NO PHOTOS FOUND." I also have the PIX Click software installed on my computer for my son that works jsut fine. HELP!!!!! My daughter is getting upset!!!
  • ateist33 Jan 02, 2008
    When I conect my camera (Olympus FE-190) to PC thru USB port, the PC recently don`t recognize it as a disc. I can get the pictures from camera to PC only if I chuse Custom Print function on camerat an then pick Microsoft Scaner and Camera Wizard. What can I do to get back this function (camera as disc)?
    Thanks, Arpi
  • Irmi Jan 04, 2008
    The Downloader software that comes with the camera refuses to open after installing. We have re-installed already once, same result. Windows recognizes it as a camera but can't find the photos on it and therefore will not download them either.
  • SISSY 2 Feb 07, 2008
    how do i get photos of this camera,where do i go to fix whatever it is? HELP!
  • Anonymous Apr 17, 2008
    I also can't get the software to download
  • joshuaabrams Sep 28, 2008
    Connecting the camera is not the issue, I think it's the SD. I have a SanDisk Ultra II 2.0 GB that will not upload via my SanDisk 8-1 Card Reader. Nor can I copy the photos to my Epson P-2000 photo viewer. My Mac just doesn't pick up the card (over 700 photos) from either peripheral. However, my SanDisk 1.0 GB, used in a Canon SD20, has no problem loading to either device.
    The point is, I do not want to have to connect my camera via USB cable to my Mac to upload photos (that DOES work), as I have limited USB ports; I want to use the Reader. Suggestions are welcomed heartily. Thanks, Josh
What you can do is you can take out the memory card and put it in to the pc it works for me Also my camera doesnt work anymore it doesnt turn on i even put in new batterys and it still doesnt turn on someone help me please
Posted on Mar 20, 2009
I canot get my pictures on my computer I have a Kodak Easy Share C813 and a Dell Computer
Posted on Oct 09, 2008
    Brigadier General:
  • 6,966 Answers
Hi, Most present day digital cameras are recognizable by a Windows PC as an external removable drive. You have to connect the camera using a USB cable (in some case, a firewire cable) to any of the USB ports of your computer. Give your machine a second or two to recognize and auto-install the needed drivers/software. The PC normally auto displays content of the camera (now recognized as possibly drive "E" or something). Thereafter it is a matter of copy/paste or drag-0n-drop to your preferred folder in your PC (more often My Pictures inside My Documents). Hope this be of some help/idea. Post back how things turnedout or should you need furtherinformation. Good luck and kind regards.
Posted on Sep 16, 2007
I cannot download pictures to my computer. When I connect camera to computer the camera shuts off. Have installed all the software that was suggested and still nothing.
Help & thanks
Posted on Oct 05, 2008
3 Suggested Answers
SOURCE:
SOURCE: wont download onto my computer
I had to fix a similar problem with a friends camera. If the lens dosn't come out when you turn it on, You will have to, or get some one, to open the camera up. there are lots of tiny screws to remove. You will find one of the ribbon cables has popped the retaining clip, and you will have to snap it back into place. Note: put a piece of tape over the Flash wire inside or you get a good zap from it.
Atari1
Posted on Feb 01, 2008
  • 11967 Answers
SOURCE: Can't download from camera to computer. I put in
Try using a card reader instead of the camera.
Posted on Jun 07, 2010
While downloading to computer it loads all photos everytime
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Aug 30, 2012 | Canon PowerShot SX130 IS Digital Camera
My Pentax S40 will no longer download photos onto my computer
Consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Since you didn't say what program(s) you're using I can't tell you anything about where it/they may have downloaded your photos to.
Jul 31, 2012 | Pentax Optio S40 Digital Camera
How do i rename pictures so that my computer won't think they are duplicates?
Rename the photos on the computer before you download the new photos.
OR
Create a new folder (say Photos1) in another area away from where the existing photos are located in your computer and move all the existing existing into the new Photo1 folder.
Then when you download the new photos from your camera then there will be no conflict or the need to rename the existing photos.
Later, you will need to create another folder and move the current photos into this folder before you download the next lot of photos from your camera.
May 15, 2012 | Kodak Cameras
How do i only download NEW photos on to my pc? it keeps downloading 300 photos.....
Connect your data cable with computer to camera.If the computer needs the camera driver install it .Then you can find the camera is detected ,Now you can download your photos to your computer.Or you can take the memory card out from camera and connect it with memory card reader to computer then you can download your photos
Sep 05, 2010 | Canon PowerShot S500 IXUS 500 Digital...
Purchased camera in March and working great until yesterday. Took a batch of pictures yesterday but was not able to download most of them to my computer. Got computer message "there are no images in the...
Sounds like you're switching the same card between cameras. Rule #1...one card per camera. Format the card in the camera it is to be used in. There is no Rule #2.
Aug 21, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Can't download photos to computer
did you turn of the camera?
the camera need to be on for the PC to detected the memory card.
you also going to need the Arcsoft PhotoImpression software. However, the software is going to cost you $40. if you lost the CD that came with the camera.
you should be view the photo with any of teh photo software you have on the machine.
Nov 10, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Nikon D40X problem with downloading photo's to computer
Does the computer see the camera when you plug it in?
Jan 09, 2008 | Nikon D40x Digital Camera
Where does PhotoMAX store photos on my computer?
Photos downloaded from a Polaroid digital camera are automatically stored within special PhotoMAX folders on your computer's C: drive. The exact location depends upon your camera model. Click Here to find where PhotoMAX stores photos on your computer. NOTE: PhotoMAX automatically saves photos in the JPEG compressed format and names them according to when they were downloaded to your computer.
Sep 14, 2005 | Polaroid PhotoMax PDC 3035 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
277 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
