Need to convert to LP from Natural Gas
I purchased a Dyna-Glo unvented gas heater several years ago and never used it. Now I may be able to use it if I can convert it to LP gas. It has been in storage all this time and I just now took it out of the box. I really can't afford to buy another one. Is there any way I can solve this dilema.
    New Friend:
  • 92 Answers
I do not think any propane type heater may be unvented but check with manufactorer
Posted on Apr 17, 2009
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
I need a thermocouple for a dyna glo heater model #RMC-40GT
I believe on your particular model , that you have to replace the entire pilot assembly. As the thermocouple is an intricate part of it. In which case any LP or Natural Gas heater's pilot assembly will fit it. You will have to secify either Natural Gas or LP Gas when ordering.
I have provided 2 links to where you can purchase the pilot assembly you need.
http://www.mrheater.com/OrderParts2.aspx?catid=57
http://www.aandbsales.com/index.html
I hope this helps you & thanks for choosing FixYa.
Jul 29, 2011 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
We have a dynna glo zero clearance for Natural Gas
Before you attempt to covert to lp. You need to check the flue. Black smoke is cause by incomplete combustion. So it may be now plug with black soot. Heat-exchanger may be damage Before you invest in a lp kit. Make sure it is worth it. To convert you need the main burner orifices and lp spring for gas value. Once you replace these parts you must adjust gas pressure, nat gas is measured at 3.2 - 3.5wc lp is measured 10.5 - 11.00 wc. In my honest opinion this is to dangerous for customer to attempt. Please a HVAC contractor inspect unit and install lp kit.
Nov 20, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Have Dyna-Glo Unvented Gas-Fired Room Heater,
I had the same issue. Iwent to the local harware store and bought heay duty mirror hangers. They work great for only a few bucks.
Oct 22, 2009 | Dyna-Glo Heating & Cooling
I have a RMI-70LP Dyna-Glo 18,000 btu unvented room heater. Can it be converted to natural gas?
These can be converted by changing the orface on the heater and also the regulator. Best to contact your gas company or Dyna Glo to obtain the correct orface for that particular heater.
Oct 08, 2009 | Dyna-Glo Heating & Cooling
Can i convert my dyna glo 75000 btu propane
I'm sure you can, contact the manufacturer and ask if they have a natural gas jet or orfice for your model heater, these are usually very easy to replace.
Feb 28, 2009 | Heating & Cooling
Convert from lp to natural gas
you need to go to the manuel and check if you can retrofit the heater to natural gas. there is a difference in the ORIFICE size. or check to see if there is a phone number to the manufacture and talk to them. THE BEST THING FOR YOU TO DO IS TO GET A CERTIFIED A/C PERSON TO DO IT, IT IS VERY DANGEROUS IF YOU GET THE WRONG ORIFICE SIZE !
Jan 05, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Dyna-Glo natural gas space heater to propane gas.
Yes it is possible and a good idea. You need to have a regulator installed to reduce the pressure to the heater and this is a simple procedure. Contact your local Propane distributor and they will probably do this free to get your business.
Ray
Dec 08, 2008 | Dyna-Glo Heating & Cooling
Yes and most larger hardware stores will carry the parts ( it should only be a connector and a small adjustment...cost...maybe $6.00 to do
Dyna glo ventless rmc50 ngt
All gas heaters can be converted from one type of gas to another, be it natural or propane. The problem is getting the orifice retrofit parts that fit that particular brand. If the manufacturer doesn't make them, then you are left with no choice.
Mar 12, 2008 | Heating & Cooling
Heating & Cooling Logo
165 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
