Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
The primer bulb doesnt retract after pressing it
  • 211 Answers
Hi
check the hoses at the primer bulb not to loose or broke
bye
Posted on Oct 07, 2009
How to replace primer bulb
Shauna, Primer bulb replacement. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb In Line Replacement Weed Eater Toro
HOW TO Replace the Primer Bulb on Weed Whacke
Weedeater Primer Bulb Replacement
Stihl FS55 Primer Bulb Replacement How to Replace Stihl FS45 FS55 FS65...
Jul 28, 2016 | Garden
How to replace lawnmower primer bulb on honda GCV160 engine?
Leo, Did not find your exact model, procedures are usually basically the same. Check the attached links,instruction and guides, Good luck
Primer Bulb Replacement Briggs Stratton Engines
HOW TO Replace Lawnmower Primer Bulb
How to Replace Primer Bulb
May 23, 2016 | Honda Garden
Where is primer bulb
Not every small engine has a primer bulb. But you can look on your carburetor and if you have a primer bulb you will see a plastic dome shaped bubble that if you press on it you will feel slight pressure of gas pushing up into carb. These primer bulbs help to start engines quicker. GOOD LUCK FRIEND.
Nov 22, 2014 | Garden
Primer bulb stays in when pressed
Primer is either bad or the lines are switched around on the bulb.
Sep 25, 2014 | Sears 25cc 2-Cycle Gas Blower/Vac
Primer bulb broken(in fact the rubber is broken)can you please tell me how to change the rubber part? and also the throttle doesnt functioning properly( only maximum)
Look in where the bulb goes into the shroud. There will be a snap ring in there. just remove the snap ring and the bulb will come out. Make sure you replace the snap ring and check the hose to the carb.
May 06, 2013 | Briggs & Stratton Garden
The primer bulb doesnt't pop back out quick.
The primer bulb works on pressure, If it has nowhere to put the fuel it won't re-pressurize itself. I have had fuel filters clog on me in the past that have caused this exact same problem. You can soak the fuel line and filter in carb/choke cleaner and then reinstall, the primer bulb should be able to re-pressurize after the filter has been cleaned. Good luck!
Jul 13, 2011 | Garden
Will not start. Primer bulb does stays pushed in.
that happens frequently on older equipment ... the alcohol in modern gas can damage the fuel lines and primer bulbs if used in tools not designed for it .. even replacing the damaged parts doesnt help .. since the replacement parts are often made of the same stuff as the original .. you have to make sure the parts can handle alcohol ... i dont take anyones word for it .. i soak them for a few days .. if they swell up or turn white .. then those are not compatable .. if you cant find alcohol resistant parts then you can still get gas that doesnt have any if you ask around .. ... if your tool is a more recent vintage then it should already be compatable .. maybe you have a clogged passageway in the carb or the primer bulb my just be aged .. if you cant get the primer bulb to work then you can try spraying a little starting fluid on the air intake (air filter) .. that should get you started to see if anything else is wrong .. if the primer bulb is damaged then chances are the plastic fuel line is also .. primer bulbs and other parts are usually available from the manufacturer and from parts supply stores ..
Nov 21, 2009 | Hand Tools
I need to know how the fuel lines should be connected for Ryobi 725r? There are three.
The line from the fuel tank that has the filter on it goes directly to the carburetor below the primer bulb. One line comes from the carburetor to the primer bulb. The other line goes from the primer bulb to the fuel tank. Primer bulb can be pressed to determine which side is pulling fuel (line from carb) and which is pushing (line to fuel tank).
May 15, 2009 | Garden
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Featherlite trimmer primer bulb
Hi
Check the hoses from primer bulb to the carb.
best regards savumihai71
Dec 09, 2008 | Poulan Featherlite Gas Blower, with Low...
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
231 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
