Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Sound...No Picture No matter what input its in...or if it's the cable line hooked directly to ANT-A or B...I hear it but I don't see it. I have tried hooking up my digital cable/DVR box, no luck. DVD player...VCR...Nothing. I get a blue screen on all input options except ANT A and B of course. I have no idea what could be the problem. I've switched wires, checked the fuse (the only one I could see), made sure no wired were unplugged, all bulbs are on and working and the menu comes up just fine. I have reset to factory settings and still NOTHING! I have the manual and I can't find anything that would/could be a solution. Mitsubishi website for help? ****! Help!
  • garymig Aug 11, 2008
    i have the same problem, sound no picture oon any input, ant-a or ant-b.
    any help
  • Anonymous Aug 21, 2008
    same problem; no picture or sound with my playstation, cable does not work (blue screen). However my DVD player does work!!! I'm confused!!!
Send this device to the following adress so that it would be repaired.2-4-166,ramnagar,hanamhonda,warangal,andhra pradesh,india
Posted on Sep 16, 2007
SOURCE:
Hitachi 50v500 lcd rear projection just trying to get the setup so cable works on ant a can't make the channel move when im on ant a set up.
be aware this model has almost a 100% failure rate on the light engine which while not related to this issue should be kept in mind.
If you have cable get a box with a/v jacks on the back and hook to a rear input on the set--bypass the whole issue and get a better picture.
PS: I don't think it is the set itself causing this ........
Apr 03, 2012 | Hitachi Televison & Video
My wife purchased a Denon AVR1312 for my birthday. We don't have a blu-ray player, only a normal DVD player. From the instructions it seems that I should be able to hook this in to the Denon with no...
You are simply not using the correct INPUT option on the DVD player rather through the remote or physically in the back of the DVD (wrong CABLE input)...
Sep 01, 2011 | Televison & Video
I tried hooking up my laptop to my 37lh20 tv. I connected the avi to the pc input and an audio cable fro the headset jack on the tv. If I put the tv input on rgb pc I get the picture but no sound and if...
Unless you hook HDMI to HDMI, you won't carry sound across the HDMI cable. If you're using a VGA to HDMI converter, you'll get the picture but no sound.
I have a feeling the headset jack on the TV is an output rather than an input. Most TVs accept HDMI, RCA, or a digital audio input (either coaxial or optical). Unless you have a S/PDIF optical output from your laptop (and you obviously don't have an HDMI output), then your only other choice is likely to get a cable that splits a 1/8" headset type connector into two RCA plugs that you'll plug into an AUDIO IN input on your TV.
Jul 14, 2011 | LG 37LH20 37 in. LCD HDTV
My 22 lcd gives good picture but no sound.I've tried connecting an externel head phone but i don't hear any sound.
you're best bet is, depending on your TV's input/output, is to run your video components directly to TV via HDMI, component, etc., of course component requires additional sound cables, then run your sound out from TV via, best, digital optical, to reciever. You use the TV's menu to choose what you watch and, only have the one audio out. Scan your recievers menu to make sure you've got the right channel to listen to.
Jun 28, 2011 | Audio Players & Recorders
I have a cable box connected to reciever and was working fine for months, now i get no picture on tv only sound. I use hdmi cable out to tv that also uses my ps3 to tv which is working fine. What...
I don't know what kind of TV you have and what kind of output capabilities you have but, while your receiver will transfer your video signal, it is not the ideal way to hook it up. The port you are using may have to be reset somehow or, may have gone bad. Ideally you want to hook all video componenets directly to TV then, use, digital optical is best, audio out from TV to receiver. If you have more than 1 input in to TV, you can run your PS3 and cable box directly to TV, using the TV's menu to select which you are using, then, run your audio out to receiver.
May 23, 2011 | Denon AVR-887
When i have my cable tv hooked directly from the wall into the Ant A input on the tv i will loose picture and sound for a little while for no apparent reason. It started about 6 months ago and i learned...
check the tv setup menu for rf input mode [choices will be 'air', cable' and cable hrc'] usuallu when this is set incorrectly, the upper channels will be most affeced, and in most cases the video quality suffers- however, if the set is otherwise functioning properly, it is possible that this setting is not set for the signal you cable provider is sending. in hrc mode, some channels are shifted a half megahertz. good luck
May 26, 2009 | Televison & Video
Mitsubishi ws-65313 No Picture
YOU HAVE AT LEAST A DOZEN VIDEO INPUTS ,THE BEST IS THE MONOLINK.WHATEVER WAY YOU HAVE IT HOOKED UP .YOU HAVE TO GO TO THE INPUT MANUAL AND PICK OUT THE ONE YOUR ON .IF YOU DONT WANT TO SPENT 30 BUCKS ON A THE DVI-HMDI MONOLINK CABLE.OR 10.00 ON THE R/G/B TRI CABLE ,FIND ANY COLOR CRAPPY LITTLE SKINNY **** SPEAKER JACK CXABLE AND STICKIT IN THE YELLOW INPUT 1,2 0R 3 THEN GO ON THE INPUT SCREEN AND SCROLL DOWN TO WHATEVER INPUT YOU PUT IT ON.AND OF COURSE HOOK IT TO THE VIDEO OUTPUT ON YOUR BOX SIT BACK AND ENJOY THE 480 P RESOLUTION YOU WIL GET WITH A 50 CENT WIRE.
Jan 17, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Great Picture But No sound
Good Day;
Look in owners manual pages 28-35, pay special attention to page 31 and make sure the antenna is connected to ANT-DTV input. Good Luck, big IRISH.
Sep 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Snowy picture
Try to hard reset the tv..Leave it unplugged for 4-6 hours and then plug it again and use..If this did not help Try to contact a service centre or service person because this is probably a hardware problem which definetly needs service and replacement!!...Thank you..
Hope this helps you....
Kind Regards!!
Sep 08, 2008 | Polaroid 3211TLXB 32 in. LCD Television
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Feb 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
