Question about Lands Phones
Trying to replace regular phone mount with a wall mount
Connecting a new wall plate so regular phone can be mounted
  • 37 Answers
If your just changing the jack to a hanging type, the fix is easy. You remove the old jack, replace with new one connecting the original wiring...red/green or blue/white.
Posted on Apr 19, 2009
How do I replace an old obsolete wall air conditioner
Not really my thing but I'll have a go anyway. As far as I recall these units are wall mounted and are not connected to anything other than a power outlet. If I'm right then it should be fairly simple to remove it from its mountings. Disconnect the power lead and then (probably) remove the cover so that you can get at the mounting screws. If the mounting looks like the 'hook on' type just slacken the screws and lift the unit up and off the wall CARE it'll be heavy. If it's not the 'hook on' type you need to support it BEFORE removing the screws otherwise it'll drop like a ton of bricks. Once it's off the wall you should be able to find the ID plate which should have the BTU output and wattage which you need in finding a replacement. Just had a thought, it's possible that the ID plate is on the outside of the AC unit, in which case you've got the info before you remove the unit.
I have no idea where you would go to get a replacement, there's not much call for them in the UK. Good luck.
Jun 29, 2015 | Heating & Cooling
Measurements to replace R 1460 over the range microwave
Almost all over the range micros are 30 inches wide. They did make a few 36 inch models but most are 30. Top to bottom back measurement can be between 16 to 18 inches. Most makes are similar in size. Back wall mounting plate will have to be exchanged since each company has a slightly different design but the wall plate comes with the new unit along with mounting hardware.
Apr 14, 2015 | Sharp Microwave Ovens
I need to replace a wall mounted microwave oven. It needs to mount only to the back plate - there is no access to mounting holes in the top. I have replaced this oven once before, but now I cannot find a...
I just replaced one of those myself. New one had totally different back plate which had to be replaced. Both new and old ones were bolted to cabinet above.
Oct 29, 2013 | GE JEB1095 Electric Single Oven
Need instructions
Flat Panel TV WallMounting Instructions
Currenttrends Flat Panel LCD and Plasma HDTV's are making TV's thinner, lighter andmore powerful. Superior high definition viewing, affordable pricing with addedspace and energy savings are only just a few practical reasons for purchasing anew HDTV. With newer thinner designs, LCD and Plasma HDTV's are ideal for wallmounting. Wall mounting your television frees up space and adds a new elementof aesthetic appeal to your home theater. Positioning Before getting into any hardware mounting,find the best possible position to mount your television. Because wall mountingan HDTV is more of a permanent solution, careful planning is needed whenintegrating the television into your home design.
Furniture placement, overall themes, viewing angles, and the best audiopositioning are all factors that will help determine the placement of the LCDor Plasma TV.
Once you have decided the general positioning of the wall mount installation,cut out a piece of cardboard or wrapping paper in proportion the of theflat panel television. Next, approximate the placement by taping the piece ofcardboard or wrapping paper to the wall where the TV will be placed and mark itwith a pencil.
Preparing the TV Removethe stand from the television and lay the TV on its face. Locate the fourmounting holes on the back of the television and remove the bolts. Next, removethe mounting arms or mounting plate from the wall mount packaging.
To attach mounting arms, line up the arms vertically and parallel to each otherusing the mounting holes on the back of the television. Make sure that they arein perfect alignment and bolt the arms using the bolts and washer supplied withthe wall mount.
If you are using a mounting plate, simply line up the holes with the mountingholes on the television. Secure the mounting plate with the bolts and washersincluded with your wall mount.
Preparing the Wall Locatethe studs closest to the desired position using a stud finder and mark themwith a pencil. Remove the wall mount from the package. Line up the wall mountup to the studs within the center of the marked position you determinedearlier. If it is not perfectly centered, wall mounts can be adjustedhorizontally at a later time.
Using a level, line up the wall mount and mark the positioning of where hebolts will go. Drill holes into the stud about 1" deep, drill bit depends on the of bolts supplied with the wall mount. Bolt the wall mountto the wall with bolts and washers, but don't tighten down the boltscompletely. Adjust the position of the wall mount left or right to center it toyour desired position. When you are done, tighten the bolts the rest of theway. Mounting the Television Attachingthe television to the wall mount takes two people. Simply lift the televisionand hook it to the wall mount. At this point you can further adjust thepositioning horizontally to center it perfectly. Once the desired position isacquired, tighten down the screws that attach the mounting arms or plate to thewall mount.
mike_alozie.jpgWallMounted LCD
Apr 21, 2011 | Televison & Video
How do I wall mount the phone, the pins were not included.
The back of the phone or the back of the mounting plate for the phone will have standard wall mount slotted holes to hang the phone on a wall mount outlet that has the pins sticking out to recieve the phone or mounting plate.
Jan 18, 2011 | Panasonic Lands Phones
We just purchased new Uniden phones, Model no. DECT1480-4. I was told at the store that I could wall mount it. There was no plate for wall mounting. Can I get one and if so how much is it and where can...
Did you find your solution? You need Uniden wall mount adapter GBCT2B5319Z, but their site lists it as "back-ordered." (I am looking to buy this phone set but, like you, want it wall-mounted, and have not found this mounting adapter in stock on the Web yet.)
Sep 23, 2010 | Uniden Cell Phones
Re:D-Link dgs-1005d mounting plates
For this as per my knowledge there are no extra mounting plates comming commercially. But itself having some mounting tools such as wall plug, screw etc. in it's package....and for permanent installation if you need it very much you can order such thing in turning workshop...but try to use it in friendly environment....because those are heat and hazard sensitive for heavy duty.....All the best.
Oct 20, 2009 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
I have sound but no picture on my 32 inch LCDHD TV/DVD. Picture flashes for a second an then the screen goes blank. Thanks Bill
This problem is caused by one of thee problems.
1) The inverter board(s) is bad.
2) Power to the inverter board(s) is off.
3) The CCFT(cold cathode fluoresent light) is bad.
Since the picture flashes for a second you may also check for loose connections for the above items.
Here is a simple test you may also try. With the TV on take a bright flashlight and press it against the screen. Look for an image around the edge of the flashlight. This will verify that an image is being sent to the screen.
Mar 12, 2009 | Televison & Video
We would like to mount our L37 HDTV 10A on the wall.
a wall bracket plate must be installed.
check with your local radio shach.
Jan 11, 2009 | Vizio L37 Television
Lands Phones Logo
223 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
