Question about Averatec 5110H Notebook
Recovery problem I have a averatec 5100 series laptop that has lost its operating system. I have received 2 recovery disc from averatec but keep getting a error 0004 failure message - need some help getting this fixed. Anyone have any ideas???
  • 2 more comments
  • moneymakeral Apr 17, 2009
    This error is error 0004 - this error comes up before any install occurs
  • Roberta Smith
    Roberta Smith May 11, 2010
    make sure the install discs are spotlessly clean... and you are starting them in the correct order
  • cmacelis May 11, 2010
    Can you post the exact error message, also when do you get this message. Is it when the OS is installing, before the Install, etc?
  • Roberta Smith
    when exactly do you get that error message ?
Averatec 7100 laptop factory recovery disc
Most times the recovery discs don't work. Why not just get an operating system disk and reinstall the operating system?
Have you tried doing a System Restore? System Restore will let you select a Restore Point (date and time) before you started having problems. System Restore will not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the Restore Point you selected). System Recovery on the other hand will delete everything and set your system back to the point when you first purchased it.
To start System Restore click Start/Programs or Start/All Programs. Click Accessories/System Tools/System Restore. When it opens you will have the option to select another restore point (date and time) than the one shown.
May 22, 2012 | Computers & Internet
Please help me....if how to reset the HDD password of my netbook (averatec N1140 Series)...
You can reset netbook password by Smartkey Windows Password Recovery, just do as the following steps,
Step1: Download Windows Password Recovery Enterprise and install on any available PC.
Step2: Burn Windows password reset CD/DVD or USB to reset lost Windows password.
Step3. Set your locked pc BIOS to boot from CD/DVD-ROM or USB Flash Drive.
Step4. Reset lost Windows password to Re123456 together with the burned CD/DVD or USB Flash Drive.
May 21, 2012 | Averatec 1000 Notebook
Lost Installing CD cant install to windows XP my computer is averatec 3200 series
here they are , I could not find free cd:
Averatec 3200 XP Windows Driver Recovery CD Restore DiskThis is an automated 3200 XP drivers recovery cd. The 3200 drivers are supplied in a special windows friendly format. This means that your Averatec 3200 XP Laptop will automatically find and install all the drivers for your system, with hardly any user interaction. If you have installed a new windows operating system and half of your Laptop just wont work (with errors like no sound no internet or bad graphics) then this is exactly what this CD has been designed to fix repair. You can also use this CD Disk If you just need to return you.....lots more averatec 3200-series drivers information here.
http://www.user-guides.co.uk/Averatec/AveratecDrivers/Averatec.asp?keywords=Averatec+3200-Series+Drivers&recor=1
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
I am having problem loading operating ysyem
this is the problem if the system files have gone corrupt. you will have to do system recovery on the computer. recovery is the process of reloading the operating system with the recovery discs. by from the number given 678-715-3329. give the information they need of your computer and they will ship you the right set of recovery cd. put the first cd inside and shut the computer off then restart the computer and follow to put the rest cd as the instruction comes on the screen.
May 13, 2010 | Averatec 3200 Notebook
Averatec 5100 series. the disc drive makes some clicking and other noises, but will not play disks. They are spinning some when I open it up. I am trying to play the recovery disks and can't
It is NOT NORMAL for a CD-ROM to experience any of the below symptoms.
  • No noise
  • Clicking during accessing the CD-ROM.
  • Noises when the CD-ROM is not being accessed.
If you are exhibiting any of the above issues it is likely that the CD-ROM drive is defective and it is recommended that it be replaced.
BEST REGARDS MICHAEL
Nov 11, 2009 | Averatec 5110HX Notebook
I have an Averatec 1000 Series notebbook computer. It had came up with some corrupted system files and I need to bring it back to the original state. The recovery disks do not work. I need a set of system...
hi
to get your system files back follow these steps.
  1. get an OS disk- XP or vista whichever your OS is.
  2. put it in the CD drive.
  3. and select option for repair.
  4. it will get all your lost files back
if you find the solution helpful dun forget to rate me carefully
thnx
Jun 23, 2009 | Averatec 3200 Series Notebook
Averatec 3200 Series Laptop
Your operating system is corrupt. You need to reinstall the operating system.
Thanks and please take a moment to give this solution a rating of fixya, even if it's not what you wanted to hear. Thanks :c)
Feb 04, 2009 | Averatec 3200 Notebook
Hello
I don't know why, but some do and some don't with Acer, even on the same models. In my opinion they all should. I would recommend making a set of back up discs with all the drivers and any of you files that you would want to keep, just in case something happens.
Jul 24, 2008 | Acer Aspire 5100 Notebook
COMPUTER PROBLEM
You're computer is still good and will work fine after an operating system reload. You can order a set of recovery discs directly from Acer, or you can purchase an operating system disc from Walmart or Bestbuy, either way will work. Keep in mind that if you order recovery discs from Acer that the operating system and the drivers for your machine will be included. If you just purchase an operating system disc, then you will have to go to Acer's support site and down load any drivers that you need after the install. Also, check in the set up to see if the machine is still recognizing the hard drive. If it doesn't, you may have crashed the drive during the interruption.
Jul 22, 2008 | Acer Aspire 5100 Notebook
Averatec 3150hd-01
Yes, you should instead use a windows installation CD or DVD in that case.
Jun 27, 2008 | Averatec 3150H Notebook
Averatec 5110H Notebook Logo
130 people viewed this question
Top Averatec Computers & Internet Experts
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
