Question about Ovens
Neff B4472 My existing oven is Neff B1432,which I'm now replacing with B4472 pyrolitic oven. I want my husband to fit it and would like to know how straight forward this is as in the shop they keep mentioning that it needs a special ampage fuse and I would like to know if it is the same as the old oven. I saw my husband taking the old oven out when we were refitting our kitchen and to me it should be quite straight forward, after all it is the same make. I have read a review that the first time someone used the cleaning system the whole fuse box blew or the door glass cracked. To my brain it should be quite straigt forward and would imagine you can use the existing cables on the back of the oven, what do you think? unfortunately my husband is to proud to ask any question but someone has to :)
yalmer
  • 549 Answers
SOURCE: Loose Oven door handle
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Posted on Jul 02, 2008
aborcass
  • 2651 Answers
SOURCE: RBS305PDS Broken Glass on Oven Door
inner door glass part number 4449259.. youll need to remoe the door from the unit and lay it on the table, thats the hardest part, theres a few different ways the door releases, so refer to your manual if available, then its just a matter of removing the screws form the door until you get to the broken panel, might thake a little time but as long as your patient no need to call service man. probly save $150
Posted on Nov 23, 2008
  • 1462 Answers
SOURCE: Neff B1432 2002 Element blown
did you check the old element with a multimeter to make sure it is in fact faulty?
check continuity across the thermostat as well
Posted on Nov 29, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff B1432 Oven Not Heating; oven light flickering
If the fan is working o/k then you need a new element fitting.
Remove the panel at the rear of the oven, there you will see the element, remove the fixing screws and ease the element forward,taking care not to lose the wires, disconnect the leads and fit new element.
The light flickering is probably the bulb not screwed in propely or a bad contact, nothing to worry about.
Plz rate my solution.
Thanks
Posted on Dec 19, 2008
ginko
  • 19396 Answers
SOURCE: broken glass door
Depends on the model, check the link below to see if the glass alone is available, if it is not , that means that this is sealend inside the door.
In that case replace the whole door, or the oven wont bake evenly anymore.
See : Enter model number here to find assembly diagrams and parts.
Posted on Jan 01, 2009
HOW DO YOU REMOVE CONTROL KNOBS TO REPLACE THE ON THE NEFF B1451 OVEN
I have a Neff B1451 oven and have removed the thermostat knob just by pulling and wiggling it. Thats all you do. If then you want to rpelace the thermostat, there are two screws holding the unit onto the oven which are accessed by taking the silver metal shrouds off first.
Jun 24, 2011 | Neff B1432 Single circotherm plus Electric...
Tip
Common heating faults with Neff B1432 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff B1432 Single circotherm plus Electric...
B1432 door gasket wanted with rounded corners
I believe this is the oven door seal. You can purchase this online from Ransomespares.co.uk product code RS46105 cost £29.25. Easy to fit, each rounded corner has little metal hooks which fit into the pre-drilled hole on the oven itself, simply unhook the old one and replace with the new, simple.
Jun 20, 2011 | Neff B1432 Single circotherm plus Electric...
Hi there, Neff B1432 was working perfectly this afternoon, but this evening when cooking 2 racks of lamb it wouldn't heat up higher than 50 degrees. Sounds like the thermostat...is this an easy job to...
Could be a faulty thermostat, but I would check that element is getting hot before commiting to replace the thermostat.
Run it for a few minutes and feel to see if you can feel hot air blowing from fan at rear of oven. If no heat present, thei it will be the elemnt that is faulty.
Jan 06, 2011 | Neff B1432 Single circotherm plus Electric...
Oven not heating up
If the oven fan is working o/k, then all you need to do is replace the oven element, a straightforward repair, and cost effective, if no fan, then could be expensive.
Please rate my solution.
Thanks.
Sep 22, 2009 | Neff B1432 Single circotherm plus Electric...
Damage to lining of Pyrolitic oven
I have a hotpoint, am currently on my fifth oven and this too needs replacing. The pyrolitic lining is flaking off and going onto my food. It's coming off the roof as well as the walls so is not just from impact with trays.
Jun 11, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Thanks
Dec 19, 2008 | Neff B1432 Single circotherm plus Electric...
Nov 28, 2008 | Neff B1432 Single circotherm plus Electric...
Ovens Logo
56 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
