Question about Midland 1001Z 40-Channels Base CB Radio
Wont change channels...stuck on channel 8
I bought a brand new midland 100z CB. When i hook up the power the display screen for the channel only lights up on the left side by a number 8. I try changing channels but nothing happens????
  • 40 Answers
On this radio you have to put the norm and channel 9 switch to normal or up if it is on ch 9 positon it will not change channels.
Posted on May 16, 2009
Midland 75-822 frozen on channel 19.
radio is out of lock .Replace the I C and it should unlock or you could try to do it your self but you would still have to replace the I C .
Oct 12, 2016 | Midland Radio Midland 75-822 Handheld...
Why wont my midland cb change channels
make sure the channel 9/19 switch is off / set to normal
Jun 09, 2014 | Midland 4001 40-Channels Base CB Radio
Midland 75 785 noise problem
change channels maybe it will go away. How is you power hooked up? does it go to the fuse box ,cigarette lighter or directly to the battery? Try hooking the power up differently .If that doesn't work try asking a friend to hook it up in their vehicle to see if it still does it. once you find the problem then install it. Could the nb/anl switch be in the off position ? Good luck.
Feb 07, 2013 | Midland 75-822 40-Channels Handheld CB...
Brand new Midland 5001z blows fuses immediately after its turned on. I tried the power cord on Cobra 25 that has the identical plug configuration and its Ok. I don't have the receipt as I got it a
bad final also check for any burned resistors in the area. If the final caused the resistor to burn the just replacing the resistor it would burn the new one also.
Feb 05, 2012 | Midland 5001 40-Channels Base CB Radio
Stuck on channel 9 wont change
Try pressing the emerg. or Cha.9 button....hope this helps...
May 06, 2010 | Cobra 18 WX ST II 40-Channels Base CB...
I need help please
Make sure you have the CTTCS codes the same on each radio! Also PMR446 radio's wont be able to talk to GMRS radio's
Aug 30, 2009 | Midland 75-822 40-Channels Handheld CB...
First, try resetting the faceplate CPU by shorting the proper pins on the faceplate to radio connector on the back of the faceplate with a piece of wire... They are marked on the connector, if this fixes it for you, enjoy!
If that doesn't work, then remove the back cover of the faceplate and check the faceplate connector itself for bad solder joints. As a matter of fact, check the entire radio for bad solder joints before looking any further.
I bought one of these radios a short time ago; Everything worked except for LSB.
I was told by the radio shop I bought it from that I'd have to wait until June to get it fixed, so I opened it up myself to see if it was something easy to find/fix, since I felt that if it was anything major it wouldn't be able to get AM or USB either.
In my case, I found bad solder joints on the faceplate connectors and a bad solder joint on one of transistors attached to the heatsink.
Once I fixed those two things, it's been a great little radio.
Be sure to reset the faeplate after resoldering and assembling, to clear any errors from the CPU.
Apr 05, 2008 | Midland 79-290 120-Channels Base CB Radio
CHANGING FROM FREQUENCY TO CHANNEL MIDLAND 75-822
Some models of the 75-822 do not offer this as a feature. Instructions for it are not included in the manual. I recently encountered a refurbished model packed with a manual such as this. Pressing and holding the "F" button toggles between Channel number and Frequency number display.
Jun 17, 2007 | Midland 75-822 40-Channels Handheld CB...
Midland 1001Z 40-Channels Base CB Radio Logo
444 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
