Question about Poulan Garden
Trying to change fuel line and filter.
I have the replacement parts. I took off the cover to expose the air filter. What do I do now.
It is a little difficult you have to remove the old one. then fish the new one through the hols and then get a angled object to push on the new filter as you are pulling on the new fuel line. then after it is in place feed the retainer ring over the new line and filter end as you are pulling on the fuel line to keep it in place. a Bent pare of needle nose players works good for installing the retainer ring good luck.
Posted on Apr 18, 2009
Echo PB 251 won't run. replaced plug, gas, fuel filter, air filter. took carb a part, and cleaned with carb cleaner, used the compressed cleaner to clean out venturis/ports.
Wow! with all you have done it should run. Be sure the switch is on but if you are getting spark, it should be on. I would take it to the echo place for service.
May 14, 2015 | Echo Garden
Bulb doesn't release even with fuel lines disconnected. Completely took carb apart and everything looks good.
If you took off the fuel lines and the primer bulb will not re-inflate than the problem is not the Carb, it is in the lines or in tank fuel filter. Fish the filter out of the tank with a piece of wire to see if that is the issue. Also take each of the lines off of the bulb clean them and try to put some air though them. If they do not let air in easily then that is the problem. The next issue would possibly be the diaphrams located inside the carb, there are two of them and are easily replaced. All the parts to replace those pieces are usually easily found at a local hardware store. Hope this helps.
Aug 06, 2013 | Garden
Brand new PP4620AVX, filled it with gas,tried to start but no gas is getting to carb.
It's not getting fuel, either the fuel lines are plugged or they may be broken. Take off the air filter cover and the air filter. Check the fuel lines going into the carburator. Wiggle them a little, they may be broken and need to be replaced. Also check the fuel filter, use a 6-8", bend a hook on one end and fish out the filter from the fuel tank. It might be best to take the saw into a repair dealer if you can't figure how to get to the various parts on the saw.
Nov 28, 2011 | Poulan Pro Chain Saw 46cc 20"
I need to replace my Egr valve. A friend wants to do it. Should i allow him or take to mechanic? Also, are there other parts i should replace while i have the valve exposed? Pep Boys wanted to replace...
hi it shoudnt be 2 much of a problem for your friend to do it providing they have some mechanical know how also check all vacuim lines 4 any spilts specaily were they plug on to fittings.its a good idear 2 change the fuel filter also replace the air filter
Sep 11, 2011 | 1996 Acura RL
Can't find 1995 Honda airinatake filter location?
Take off your side covers, unbolt the drivers seat (one bolt each side of bike), turn off gas,unplug fuel line from fuel petcock, remove the rear tank mounting bolt, lift off the fuel tank pulling toward the back of the bike, this will expose the top of the air cleaner. Remove the top cover of the air box, the filter is underneath.
Apr 16, 2011 | 1996 Honda VF 750 C Magna
How do you replace a 2001 Mazda 626 Fuel Filter
Fuel Filter On all models except the Millenia, the fuel filter is attached to a bracket located in the left rear of the engine compartment, next to or beneath the brake master cylinder fluid reservoir. On the Millenia, the fuel filter is located beneath an access cover in the trunk. Access to the cover is achieved by removing the trunk mat to expose the cover.
REMOVAL & INSTALLATION Except Millenia
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Properly relieve the fuel system pressure.
  3. Remove or disconnect the following:
    • Negative battery cable Fig. 1: Exploded view of a common fuel filter and related components 7923mg68.gif
    • Air intake hose and/or filter housing, if necessary
    • Fuel line clamps, if equipped
    • Fuel lines from the filter and plug the openings
    • Filter clamp bolt/nut by loosening them.
    • Fuel filter from its mounting bracket
    NOTE: Note the direction of the flow arrow on the filter so the replacement filter can be installed in the correct position. To install:
  4. Install or connect the following:
    • Fuel filter in its mounting bracket, making sure the flow arrow is pointing in the proper direction
    • Fuel lines to the fuel filter
    • Air intake hose and/or filter housing, if removed
  5. Pressurize the fuel system and check all connections for leaks.
Millenia
  2. Insure the ignition switch is OFF.
  3. Relieve the fuel system pressure.
  4. Remove or disconnect the following:
    • Trunk mat
    • Service hole cover
    • Fuel lines from both ends of the fuel filter
    • Fuel filter and bracket
    • Fuel filter from the mounting bracket.
    To install:
  5. Install or connect the following:
    • Filter in the bracket. Tighten the nut to 70-95 inch lbs. (8-11 Nm).
    • Fuel lines to the filter
    • Trunk mat
  6. Run the engine and check for any fuel leaks.
Oct 17, 2010 | 2001 Mazda 626
I have a 2005 ford f150 lariat supercrew with a 5.4 engine, my truck bogs at accelaration. I clean the throttle body out,change the fuel filter,spark plugs,but the problem still remains. Thank you for your...
try cleaning the maf (mass air flow sensor) it is located just out side the air cleaner box just before the large air hose heading to Intake use electrical parts cleaner and toothbrush or a cotton swab to clean this, but be carefull part is fragile and expensive to replace, look for two exposed small wires located on the bottom of the sensor that would be exposed to ingoing intake air this is what needs cleaned, soot or dirt will cause a improper air fuel mixture generally lean causing power loss good luck
Mar 22, 2010 | 2005 Ford F-150
I need to change the fuel filter. where is it located. do i need special tools ?
The fuel filter on most Mazda cars can be located on a bracket in the left rear of the engine compartment, next to or beneath the brake master cylinder fluid reservoir or as part of the fuel pump assembly.
The filter on Mazda 3 models is part of the fuel pump assembly.
The fuel filter on all Mazda cars can be located on a bracket in the left rear of the engine compartment, next to or beneath the brake master cylinder fluid reservoir or as part of the fuel pump assembly.
How to Replace a Fuel Filter
Parts:
  1. Fuel Filter - $175.45
Tools:
  1. 3/8 in. drive ratchet - $7.55
  2. Hose pincher - $4.07
  3. Flare nut wrench - $5.53
  4. Flat Head scredriver - $3.14
  5. Socket Set
Steps:
Open the hood and locate the fuel filter. If the fuel filter is not in the engine compartment, follow the fuel line from the tank until the fuel filter is located.
Tip: Safety Tip:Always wear safety glasses when working on your vehicle. Wear other personal protective equipment (PPE) when necessary, for example latex gloves or safety shoes.
  • 2. If the fuel filter has a clear case, inspect the filter element for dirt.
  • 3. If the fuel filter case is not see-through, remove it from the fuel line. Drain the fuel from the filter into a container and inspect the condition of the fuel.
  • Tip: Caution: Before removing fuel lines or fuel related parts, make sure that the fuel pressure is relieved from the vehicle fuel system. To relieve the pressure in fuel injected systems, remove the fuel pump fuse and run the engine
  • 4. Install the new fuel filter making sure that the flow is in the correct direction. The arrow on the fuel filter is the direction of flow from the tank to the engine.
  • 5. Secure the lines back onto the fuel filter. If applicable, reinstall the fuel pump fuse.
  • 6. Start the engine and check for fuel leaks.
  • 7. Test drive the vehicle to check for a rough running engine, hesitation, or lack of power.
  • Good luck (remember rated this help).
Nov 09, 2009 | 2004 Mazda 6
Garden Logo
75 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
