Question about Whirlpool Clothes Washer Timer Knob - 8544945
Whirlpool Washer Model:LSN1000KQ0,SER: CM4267948, Type: 111 - Need nylon gear in transmission gearbox.
  • buddah009 Apr 17, 2009
    Thank you for your help. It's funny how they always sell the STEEL pinion with the PLASTIC gear. Pinion fine. Gear all chewed up. Thanks again.
  • 88 Answers
From the information provided, it sounds like you need WPL 285362 (gear and pinion kit) which you can find at appliancehelp.com for $59.95. You can type in your washer model and see the diagram of each part before ordering so you get exactly what you need.
Posted on Apr 16, 2009
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Isnt extracting water on spin cycle
If the water in the tub just stays in the tub no matter what,then the water pump is most likely bad.If not ,there is a piece of clothing in the pump,witch has stopped the pump.Check the drain hose also,to make sure that the hose is not restricted with anything,or the hose is not crimped.I hope this answers you question,and if so,please let us know ,thank you.
Nov 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have kenmore washer ser#cs3726779 type 111 and it won't spin and has an oil leak uner it--can it be fixed economically or not?
if this is an older machine, it may not be cost effective. This sounds like the transmission is leaking and it will eventually fail.
Aug 29, 2009 | Kenmore Washing Machines
Model 238322100 ser cm4768086 type 111
Check the following.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 22, 2009 | Kenmore Washing Machines
Washing Machine wont spin/agitate
The most common problem is the lid switch. with a screw driver in hand open the lid and press down on the lid switch. sometimes the mounting screws will crack the switch housing and the striker can't move the actuator far enough. I am interested in the clicking noise, as this could indicate a pump issue or a sock seizing up the tub.
Jun 14, 2009 | Kenmore 12502 Top Load Washer
Replaced Washer Timer
Next time it stops cheak your lid switch.When it stops do not touch any thing just open lid and find a pen or somthing to push the switch down.If it comes on then you will need a lid switch.If not let us know good luck:)
Mar 30, 2009 | Whirlpool LSB6000PQ Top Load Washer
Whirlpool toploader gearbox/clutch removal
Last Night I took the machine apart to find clutch/brake assy ok gearbox was also ok then I noticed shaft coupling was different than new part I had in stock, new part made totally of nylon, old part fitted to machine has steel insert built into nylon. this was not fully located onto motor shaft and the first 1/4" of motor shaft had been stripped back to round ( no flat faces) also inside the steel lined bore of the nylon coupling had been worn to round.I replaced with new coupling of nylon and ensured both nylon parts fully pushed home onto motor shaft and gearbox shaft with any freeplay / gap being allowed in the rubber drive link. This has worked for now but expect trouble in future with worn motor shaft.
Oct 17, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer LSQ9659LW0 will not spin.
If the washer will agitate and drain but will not spin you either have a bad gearcase or the nylon finger that engages the brake is bad. you need to remove the gearcase and check the brake assembly and if that is good replace the gearcase
Jul 25, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Clothes Washer Timer Knob - 8544945 Logo
651 people viewed this question
Top Whirlpool Hardware & Accessories Experts
Joseph Mueller
Joseph Mueller
Are you a Whirlpool Hardware and Accessory Expert? Answer questions, earn points and help others
