Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Adobe premere i used to download videos from youtube.com & convert it to .avi by "total video converter".........but when i tried to import them to adobe premere ,it fails.......it is showing a message that there is some unsupported compression in video file.........what does it mean & how should i correct it........?? plz tell......i have to complete my projects....thanx in advance........!!
    Sergeant:
    Champion:
  • 293 Answers
Have you tried different types of videos like .mpg?
Posted on Sep 16, 2007
  • Anonymous Sep 16, 2007
    if still fails try here >>> http://www.4filehosting.com/file/28436/A...
    its an Apex Movie Converter v3.82
    Hope this helps
SOURCE:
How can I import video to edit in FCP
It's very difficult for you to convert video files to ProRes codec.Here i recommend you an easy-to-use Video Converter for Mac to help convert videos to FCP,like mp4,avi,mov,mts,etc.you can follow our article:
http://www.iorgsoft.com/Video-Converter-for-Mac/
more detailed information:
http://www.youtube.com/watch?v=IssAzss5BAo
Nov 16, 2012 | Total Training Final Cut Pro 5: the...
Tip
Guide to import/edit Flip videos in Premiere Pro with several simple steps
Overview of Adobe Premiere and Flip Camcorder: Adobe Premiere Pro is one professional, real-time,timeline based video editing software application. Flip cameras store their video in a high-definition MP4 format. However, you will likely not be able to edit the video by importing it into Premiere Pro without converting it. The best solution to make Flip Slidehd/Ultra/Mino camcorder mp4 videos edit on Adobe Premiere Pro version 1.0, 1.5, 2.0, CS3, CS4 and CS5.
Best solution - Flip to Adobe Premiere Converter Flip to Adobe Premiere Converter is a magical app for Premiere Pro fans to import and edit flip video in Premiere Pro AVI, MOV, MPEG (MPE,MPG), AIFF, MP3, WAV, WMA, etc. Flip Video to Adobe Premiere Converter easily convert flip camera videos to Premiere Pro with no quality loss. Under the help of the Converter, you can import the output video and edit it in Premiere Pro with ease, no matter which Adobe Premiere Pro version you possess. Furthermore, it can also support you to import Flip video to Windows Movie Maker/WMM.
Guide to import/edit Flip videos in Premiere Pro with several simple steps.
Part One: Convert Flip Video to Adobe Premiere Pro Format AVI, MOV, MPEG etc. Step 1: Load files
After download and run Flip to Adobe Premiere Converter, Press "Add File" to import flip .mp4 video to the program.
Step 2: Select the output format and its destination
Select the output format in the drop-down list of "Profile", like DV-AVI. Specify its destination when click the "Browse" button.
Step 3: Click "Convert" button to start converting flip camera video to target format.
After successfully convert Flip to Premiere Pro supporting formats, you can import the video to Adobe Premiere.
Part Two: How to import output video clips and other files into Adobe Premiere Pro? Adobe Premiere accepts you to import a single video clip, multiple clips, or an entire folder of clips. You can also import a variety of audio and still image files, including sequences of images and layered Photoshop files.
Select File > Import from the main menu.
Tip1: To import a single file: Locate and select the file, then click Open.
Tip2: To import multiple files: Hold down the Control key to select multiple files, then click Open.
Tip3: To import a folder of files: Locate and select the folder you want to import, then click Folder. A new bin is created in the Project window, containing the contents of the folder.
Tip4: You can also import files and folders by dragging them from "Finder" into the Project panel.
Why not download Flip Pro to have a try?
on Jul 20, 2010 | Cameras
Tip
How to Convert AVI Video to Youtube
What is AVI?
AVI stands for Audio Video Interleave. It is a special case of the RIFF (Resource Interchange File Format). AVI is defined by Microsoft. AVI is the most common format for audio/video data on the PC. AVI is an example of a de facto (by fact) standard.
What is FLV?
FLV stands for Flash video, initially known as Shockwave Flash and popularly called simply flash, refers to both Adobe Flash Player and Adobe Flash Professional multimedia authoring program. If you obtain a video from YouTube, Google Video, Yahoo! Video, it will be likely a Flash video with the file extension of *.flv. With the wide availability of Adobe Flash Player in most common web browsers, Flash video has been the most popular video format for online delivery.
Step by step Convert AVI to FLV
Step 1: Free download simple-to-use Best Video Converter, install and launch.
Step 2: Import video files
Click "Browse" to import avi files including standard and high definition files or drag the files to the file list window directly. all the supported imported formats are listed as below. You can just drag videos into the application.
Step 3: Settings of output video format
Select your desired output format from the categorized output formats list in "Profile" drop-down list, specify the output directory to save your converted files in "Browse" to select you want to save you files location. Here we selected .flv as output video format.
And you can click "Edit Profile" button to edit you video/audio files.
Step 4: Start to convert AVI to FLV
After setting the output format, you can start conversion by clicking "Convert Now" button, and all the tasks will be done at fast speed and high quality.
on Jul 14, 2010 | Computers & Internet
Need help converting mp4 to avi
Just download a professional MP4 to AVI converter to easily convert mp4 to avi.
May 25, 2012 | Audio Players & Recorders
I cant download freedi youtube downloader for samsung s8530 wave2 because there is an error message unsuported content,please solve this promble
Just try to use Leawo Video Converter.
Home Page: http://www.leawo.com/leawo-video-converter/
Leawo Video Converter is an all-in-one best video converter for downloading to convert videos among popular formats like AVI, MPEG, WMV, MP4, FLV, RM, MOV, Xvid, 3GP, etc., transform audios between MP3, WMA, WAV, M4A, AAC and AC3 audios, and create fascinating photos from video files. With this video converter downloaded and the video converted, you may easily get the specific video format watched on TV, played on portable media players
Feb 10, 2011 | Health & Beauty
By passing total video converter license key
I'd recommend that you use another video converter named video converter asoftech, which helped me before, download from
http://www.asoftech.com/video-converter/
The program is very easy to use, and works well for me.
Feb 06, 2011 | Magic Software Magic Total Video Converter
Total video converter 3.61 registration code
Actually I suggest you to try Leawo Free FLV Converter.
Leawo Free FLV Converter is an easy-to-use and totally free FLV to video Converter. With this Free FLV Converter, you could easily convert FLV to video in popular formats like AVI, MP4, MPEG, WMV, MOV, MKV, etc. for entertainments on portable devices such as iPod Touch 4, iPhone 4, Android Mibile etc.or internet.
Oct 06, 2010 | Computers & Internet
How do i import a video?
dear you need to convert your file into a format that is supported by the premiere like avi or smthng else(check out documentation for the formats supported by your software).
To convert your files from one format to another you need a video converter software like Total video Converter or ImToo MPEG Encoder.
you can find tvc here
http://thepiratebay.org/torrent/4667561/Total_Video_Converter_v3.21___Patch_By_ChattChitto
http://isohunt.com/torrents.php?ihq=imtoo+mpeg+encoder&ext=&op=and
for more download links mail me at [email protected]
Nov 23, 2009 | Adobe Premiere Professional 1.5
I want avi converter for china mobile
hi this is ajay i have a chinese mobile which runs .avi ther is a solution for this download xlisoft 3gp converter then make the settings as shown make the video format mjpeg then frame rate as 8 and video size 160*128 audio codec pcm_s16le and sample rate 8000 and channel mono(1) then convert it will work perfectly. happy converting
Apr 26, 2008 | Adobe Photoshop 7.0 for PC
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
64 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
