Question about Kenmore 23822 Top Load Washer
Only motor runs.nothing else. - Kenmore 23822 Top Load Washer
  • 594 Answers
If that is all that is running and nothing else like you say than it is most likely the belt on the washer has broken.
Posted on Apr 16, 2009
Motor does not run properly
What motor are you talking about the fuser motor, paper draw motor, the finisher motor, the transfer motor, the drum motor, the developer motor, corona wire transfer cleaning motor. I can go on.
Replacing developer and toner has nothing to do with the motor running,
Aug 06, 2014 | Sharp AR-5320 Black and White Copier
Beater bar motor quit, now the main motor quit. Replaced the on/off switch. still nothing
see this causes and fix it. God bless you
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Vacuums
Turn table wont turn motor is good
you should only get voltage to the motor when it is running. if when running the motor doesnt turn but is getting voltage then it is the turntable motor. if when running the motor gets no power youre probably looking at a control board problem
Jul 24, 2012 | GE JVM1443 Microwave Oven
Delta x5 unisaw 3 hp. couple days ago it was running strong never had a problem before. push start motor tries hard to spin but nothing besides a hot motor barely touch it hot. 10 min later saw starts...
The motor has a component called a clixon (there are other names for it, too). The clixon has a step up coil and a capacitor that gives the motor an extra bit of juice to get started turning. When it fails, you get the kind of thing you're talking about. If you keep trying to use it without this component working, it overheats the windings and shorts the motor out, killing it. You're most likely going to end up replacing the motor now.
Sorry I didn't have better news for you.
Jul 09, 2011 | Delta X5 3Hp Left Titl Unisaw with...
The motor runs but NOTHING moves, not even the bobbin winder
If the motor is actually running but nothing moving at all even the winder then either the belt is loose or it has come off.
Nov 06, 2009 | Brother XL-2600I
Can hear motor running but nothing happens in dishwasher
Hi, you need to test voltage to the water inlet valve. If you are getting voltage (120V) replace the valve. If you are not getting voltage check the water level switch located in the front corner of the tub.
If I can assist you any further with parts or part #'s, please let me know.
Thanks
Vic
May 16, 2009 | Dishwashers
Dryer wont run/push power-sounds like it wants to start/nothing
i get this all the time,yes it is the motor,what happens is the motor gets so weak that it will no longer turn the drum it just hums,a motor on ebay runs about $65,your model number if you want to tackle it is inside the dryer door-mike
Apr 24, 2009 | Dryers
Blower stopped working.
Heater blower motor resister is bad, or blower motor its self is bad. Run 12 volts from an outside sourse to blower motor, if it runs its resister if not its blower motor.
Mar 08, 2009 | 1995 Dodge Dakota
GE Dishwasher not working...
Sounds like you have a one of four possible issues. More info to diagnose would be helpful. (age, which mid cycle) If the motor runs when you turn the timer dial than it is a belt/motor pump issue. If the motor does not run than a bad motor start switch or the water level switch. More than likely the motor/pump assembly as this is usually the problem on these models. If newer check with whirlpool the manufacturer to see if it is covered by warranty.
Nov 06, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Kenmore 23822 Top Load Washer Logo
27 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
