Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
No washing after water fills up
Hi Guys:
our dishwasher motor was making a lot of grinding noises and then it finally seemed to die - stopped washing, no grinding noise. So the repair person we called said we should replace the motor and pump assembly. We did it our selves. However, once the water fills up - it doesn't start washing, sort of acts like the old one we just replaced.
So the questions are did we make some sort of mistake or is there another part we should replace.
Thanks for your help.
Russ The sad thing is its only a little over a year old - but passed its warrenty
  • Whirlpool Master
  • 19,396 Answers
Before replacing the impeller the technician will test the pump by energizing it. If the problem was not the impeller, then check timer control board and wiring harness.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on Apr 28, 2009
Washer makes grinding noise but isn't doing anything else
Remove the cap off the agitator, flip back the top of the console, remove any nuts keeping the tub in the console. There will be a clutch ring that needs to be replaced. I have an older top load washing machine. I agitates, fills, and drains, but it won't spin. It sounds like it is spinning, but it doesn't. It might be the coupling. That is a 3 piece kit that goes between the transmission and the motor. I found the directions how to do it over the internet, got the part and fixed it myself.
https://www.structuredsettlement-quotes.com/
Nov 08, 2013 | GE GSM1800NWW Spacemaker 18" Built-In...
My MDB5600AWW isn't cleaning the dishes. Even easy stuff like wet pasta sauce. I watched/listened and discovered the water is not staying in the tub during wash cycles. It fills, then slowly (1-2 mins)...
Check the drain hose... it sounds like it has fallen down too low and is not looped high enough to keep the water in the tub....this will let the water drain right out as it fills like you are saying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Oct 12, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher water level low and making strange noise.
Hi, This d/w is designed to run with low water level. The noise you are hearing might be the wash motor. Do you know if this has the single or dual motor setup?
The dual motor style are not the greatest. The wash motor is known to go bad. You can remove the housing below the spray arm and see if anything has lodge in the in impeller. Please let me know if I can assist you further.
Vic
Jun 12, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Grinding
noise probably not from there when reassembled the plate will not be direct contact with screen noise is probably from wash motor itself..suggest checking owners manual for warranty info
Aug 10, 2008 | Dishwashers
Maytag dishwasher mdb56000aww
It seems that your motor on the dishwasher is going out, like mine has just done. My explanation is that it sounds like something is grinding on glass or as if a bunch of mice are making noise. Eventually, the motor will not run any more. What will happen is that the dishwasher will fill up, then make a loud humming noise, while the heating element is making the water near the heating element sizzle. Now what you have is a possible fire hazard which compounds the problem with the dishwasher. Get rid of it, take the loss and live like my grandmother used to, without having a dishwasher. That is the best advice I can give you.
May 08, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
221 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
