Question about EliteGroup P4VXMS (P4VXMS-R) Motherboard
The biggest cpu that will fit in my p4vmm2 motherbord
Hi i have a p4vmm2 motherbord and im looking to upgrade my cpu to the best i can get for it can you help me regards tomomi
  • tomomi Sep 16, 2007
    i have been looking for Pentium processor 3.0Ghz 533 400/533 FSB non Prescott for a while and i cant find it would you know a part no. or where could i buy it
    regards
    tomomi
  • tomomi Sep 17, 2007
    thank you you were a grate help
    Sergeant:
    Champion:
  • 293 Answers
You can go up to 3.0Ghz Pentium 533 Non Prescott. It has a 400/533 FSB
Posted on Sep 16, 2007
  • Anonymous Sep 17, 2007
    actually thats a 2.8Ghz model OC to 3.0Ghz its also rare though. What you would normally find is a 2.4Ghz it could sky rocket to a 2.6Ghz and up.
SOURCE:
Want to upgrade my video card, whats best
Hello there!
I suggest you to check your mainboard and what VGA you could upgrade for it. When you find that out, select what best fits to you wallet, and enjoy!
Sincerely
Aleksandar Adzic
Apr 16, 2010 | EliteGroup P4VMM2 Motherboard
Motherboard P4VMM2 has 4 slots, 2 are empty, 2 have memory cards of 128 MB RAM each. What is the maximum RAM that it can support?
2 GB of memory, You can configure those anyway you'd like, however, the best pratice in memory is to match your chips for best proformance.
Good Luck,
Mark
Feb 17, 2010 | EliteGroup P4VMM2 Motherboard
What are the processor compatible with this mother board pvmm2? my current proc is celeron 1.8ghz. im planning to replace it with p4 proc? i tried p4 2.26 ghz but it wont work?? pls give me adviced for...
http://www.ecs.com.tw/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=272&MenuID=69&LanID=0
Note that a faster front side bus(FSB) or system bus as listed on the above page will make a slower cpu faster the a cpu with higher Ghz and slower FSB.
Also RAM is your best upgrade, fast and easy.
Jan 10, 2010 | EliteGroup P4VMM2 Motherboard
I need a motherboard that can use the same case and everything els as the p4vmm2 My case is the ATX with Intel celeron 2,4GHz
you can use any ATX mainboard into an ATX case, they are universal. Your cpu will only fit boards with the same cpu footprint so you need to know what socket your cpu is.. lga775 is most common now. I would advise a Gigabyte EP45-UD3LR board. Excellent board and well worth the outlay.. no issues with windows xp or vista and you can expand drives and ram as you wish..
Nov 02, 2009 | EliteGroup P4VMM2 Motherboard
I looked, but didnt come up with what I was looking for. I have an older compaq presario CPU intel 5321SR pentium 4 1500Mhz 1Core BIOS ver compaq 686Y2 v1.05 9-6-01 What would be the biggest CPU for this...
Hi, just looked at your system on the Compaq website.This pc does not support further cpu upgrades.The only upgradable item is the memory. If I can help further contact me on http://www.motherboardsrus.net and use the contact us link Chris the computer doctor 07926-106150
Jun 07, 2009 | Compaq CPQ/Presario5006EA uWave2 K7...
Hi guys, I'm new in this forum and I really need some help. I have a p4vmm2 motherboard with Intel Celeron 2.0 Ghz CPU and I want to upgrade it with Intel Pentium 2.4 CPU motherboard. I have already tried...
Whenever you try to upgrade motherboard and CPU's with Windows XP, you're probably going to have to format your drive and re-install XP. When you originally install XP it detects the motherboard and IDE controlers for your hard drives and installs the drivers needed but it doesn't install all drivers for motherborads and IDE controlers. When you swap out motherboards and the system tries to fire it doesn't have drivers available for the new motherboard and can't complete the boot into windows. Every once in a while you get luck and the new and old motherboard can use the same drivers but this is very rare. So when upgrading motherboards plan on backing up your hard drive of all files you need to keep and being prepared to format and re-install windows.
May 15, 2009 | EliteGroup P4VMM2 V8.1 Motherboard
My gateway G6-350 supports a second processor...how may i determine which processor to buy as second one...must it be the same one...thank you for your time
hi,
according to gateway 450mhz is the largest that can be put into your system. The biggest performance gain will be found in a RAM upgrade. The difference between a 350MHz & 450MHz CPU will be minimal & maybe not even noticeable. But if you already have another CPU or can pick one up for a few bucks, it wouldn't hurt...I wouldn't spend more than $5 though.
Your best bet would be to try to determine the make/model of the motherboard, then find out what the max CPU is it can handle. See if a local computer shop has any used parts or if you have a flea market in your area, you might wanna look there. good luck and appy computering!
Mar 30, 2009 | Dell 2.8 GHz Second Processor for...
IBM 25P2590 P4 micro motherbord
i found nothing but items referencing updates and patches to existing servers and software to accomodate the situation you describe.. if you're still nervous try looking around on ibm.com/support or lenovo.com/support
Dec 29, 2008 | IBM (25P3294) Motherboard
CPU upgrade not showing correctly
Check the installation instructions; it may be necessary to change some small jumpers on the board if it is not designed to auto-detect the processor.
If you don't have the info on the board, check with Safemanuals.com or retrevo.com or Elite's website for a download.
Sep 21, 2008 | EliteGroup ECS P4VMM2 Supports Intel...
Possible cpu upgrades for p4vmm2 motherboard
I see that you have already had this answered at Techspot.com They were right when they answered you, you need to check your MB manual to see if it is capable of upgrading to the CPU that you want to use, not all MB support all CPU's just because they both have 478 pins. I looked on the ASUS website and they don't even list your MB model on there.
Mar 20, 2007 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
EliteGroup P4VXMS (P4VXMS-R) Motherboard Logo
105 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
