No pic, just a black screen w/white grid on it. How do I get picture back on it.
I have a Curtis Mathes Tv Model # CM25101s My children were messing w/ the tv, and now all we can see is black screen w/ a white grid-4 squares. Is there someway for me to fix this problem, or is it a concidence that the kids were messing with the TV at the same time it breaks down? We can put DVD's in, but only hear them, not see the pic. Our Uverse is not viewable either.
  • 36 Answers
Sounds like they enabled some test mode of the TV. Can you activate the menu using the remote control and see if you can navigate to disable that? How about if you just unplug it from the wall for 60 seconds and plug back in and maybe it will reset.
Posted on Apr 16, 2009
I am trying to adjust the brightness on this circa 1980 floor model solid state tv
The contrast setting controls the relation between the light and black areas of the screen. If the light areas are too bright and are losing details, press the CVOL button; if the picture is gray and lacks contrast, press the VOLB button
The brightness setting controls the overall amount of light in the picture. If the picture is too bright, press the CVOL button; if the picture is too dark, press the VOL B button
The color setting controls the intensity of color.
Curtis Mathes CM19102 Owner Manual Returning To The Factory Settings...
Apr 09, 2016 | Curtis-Mathis Televison & Video
I hooked my jvc dvd player to my curtismathes tv movies only show in black and white why
Try contacting the folks at the link below:
http://www.curtis-mathes.com
They probably have a member on their site that can help you with the problem you are having with your JVC DVD player only showing in back in white on your Curtis Mathes television. They love helping folks and they do it for free :)
Dec 10, 2013 | Curtis-Mathis CM27101S TV
Screeen color is green
This fault is called one color predominant screen. The cause might be to its video output card itself. There will be some loose solder terminals around the Green video output transistor. Check this card for any loose solder terminals. Just re-solder all the suspected solder terminals by applying a little more solder, without making any solder bridge short in between adjacent solder terminals. This card can be located at the neck of the picture tube [a rectangular board], will be directly plugged on to the back of the picture tube.
Dec 27, 2012 | Curtis-Mathis CM27101S TV
Standard television spot after bright screen
A explanation that may tell you what is happening:
Some of their sets had this issue. The picture tube has a metal screen inside directly behind the stripes that make up the phosphor coating on the inside of the picture tube.
It is called a shadow mask. It has perforations that line up with all the stripes on the screen (look close--red-green-blue stripes all outlined in black--tiny).
What is wrong is not fixable even if the tube is replaced----the metal used in these sets for the mask contains iron which causes it to expand in areas with real bright scene changes--
No need to remove question as I saw it and answer questions for most TV area problems.
I actually ten years ago worked for Circuit City--saw at least 5 sets (all larger Toshiba sets) with this issue. On seeing first one called our support staff and someone explained to me the issue---that set was under extended warranty and since the customer was angry the set was "exchanged" for a brand new set and the old one was disposed of.
Jun 01, 2012 | Curtis-Mathis Televison & Video
Picture on my CM25101S has gotten larger, can't see tops of head and the bottom of the sceen
The problem you are describing is a vertical deflection problem often caused by one or two open capacitors near the vertical ic.
Mar 18, 2012 | Curtis CM25101S 25" TV
Need code to program Zenith remote control
Try these codes for your remote and TV. The are the Zenith codes for a Curtis Mathes TV.
CURTIS MATHES.....002 103
............................. 112 502 506
..................... 512 601 701 704
These should work.
Regards,
Mike
May 09, 2009 | Curtis-Mathis CM25011 25" TV
Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Jul 03, 2008 | Curtis-Mathis CM32010 TV
Curtis mathis TV
With the price of this screen size below $150.00 (well known makes and models) no you can't get it fixed for less.
Jul 11, 2017 | Curtis CM25101S 25" TV
Curtis Mathes 27" TV
better to replace a/v jacks as you have already soldered it
the problem is due to jack only.
Oct 14, 2007 | Televison & Video
Televison & Video Logo
221 people viewed this question
Top Televison & Video Experts
Electro Med Services...
