Question about E-Machines T3025 PC Desktop
No monitor signal and hard drive not spinning? (eMachines T3025)
The problems are obviously related... I have P6 plugged into the HD...I would need a diagram to check if this is right...I can't seem to find the P4 tho...When I turn the power button on, the fans start up, but the hard drive doesn't spin. I need a wiring diagram anyways, so if anyone has a link, that would be helpful.
  • 4 more comments
  • yamancool63 Apr 17, 2009
    Well, I got the HD to spin, but I found out that one of the boot sectors was corrupted, so it stopped about 2/3 into the boot. I was just wondering if the connectors had diff. voltages or current, because sometimes they do.
  • yamancool63 Apr 18, 2009
    Update: BIOS is bad. I need some instructions on which pins to short out for a reset.
  • yamancool63 Apr 19, 2009
    All I see is a Jumper 3 and a jumper 4...
    That would only clear the CMOS, but I tried it and it didn't work anyways.
    How do I flash it if I can't even get to the BIOS screen?
  • yamancool63 Apr 20, 2009
    I got the HD to spin on another system, mind you. I can't get to the BIOS screen, so a boot disk didn't help. I'd love to find the jumpers, tho. I can get the fans to run after I turn on the computer, and my keyboard lights flash, but it stops there.
  • 298 Answers
Wiring diagram? Usually you just plug in the 4 pin molex connector. If its not spinning the HDD is damaged and needs to be replaced.
Also I can tell you the Wires are Yellow=12v Black=ground RED=5v and orange=3.3v
Posted on Apr 16, 2009
  • 2 more comments
  • Mike  Petrowsky
    Mike Petrowsky Apr 18, 2009
    jumper 21 its normally near the bios and or battery
  • Mike  Petrowsky
    Mike Petrowsky Apr 19, 2009
    if its a jumper within 1-2" of the bios chip or the battery then that's the one. Or you can unplug it, push the power button to discharge the system and remove the battery.
    Leave it unplugged and the battery out for a few minutes, that can reset it also. Make sure you press the power button on the front to discharge the psu.
  • Mike  Petrowsky
    You could also download your bios file and flash it.
  • Mike  Petrowsky
    How far can you get this system to boot, first the HDD wasn't spinning, then your got it working but have bad sectors, then the bios is bad. Does the system post at all? If it does post but doesn't read the HDD you can flash it. Normally flashing is done from a floppy drive, but now you can also make a Flash drive/thumbdrive bootable and flash from those also.
    If the system doesnt turn on or even post then I'd say its time for a new board. Or you can purchase a new bios chip with the lastest Bios pre flashed on it from reputable sellers on eBay (I had to do this once before, his personal site was biosman.com.)
Changed power supply in my desktop compaq persario evo forgot how to plug cords back in and there not labled with words only p2 p4 p6 sttuf like that
Pls. let me know, you are having problem for connecting power,reset,sound,usb connectors? or even HDD,dvd drive and motherboard connections too?
Jul 21, 2014 | Computers & Internet
P6 and P4 error messages
P6, High temperature protection of condenser. P4 Ipm module protection. something is wired up wrong or bad connection. here is a site with the wiring diagram. aitons.com
Jun 28, 2014 | Klimaire Heating & Cooling
Kitchenaid microwave error f6e0
1. Unplug oven or disconnect power.
2. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step 6.
- If they are plugged in, go to step 3.
3. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to
P2-5(UI). All the measurements made should be less than 5 ohm . If any of
these measurements exceeds 5 ohm, go to step 5.
4. Replace the appliance manager. Ensure all connectors are properly inserted.
5. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
6. Replace all parts and panels before operating.
7. Plug in oven or reconnect power.
8. Observe for longer than 1 minute to determine if error has been repaired.
9. If error does not appear, initiate a bake cycle. Let the cycle run for at least
1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step 1.
At step 4, replace the lower oven user interface board if appliance
manager has already been replaced.
- If both are replaced the problem has been repaired.
May 15, 2013 | Cars & Trucks
P4, P5 and P6 cables are unconnected. Where do they connect
Not necessarily. Most computers have extra power connector for modifications and expansions.
Feb 21, 2013 | HP Pavilion a1600n (882780776265) PC...
How can I tell if I have a P4, P6 or P8? My PDA is stuck on "waiting." Can I get a replacement antenna?
turn aqualink and PDA off then turn aqualink back on then PDA if same thing happens open the case on the antenna to see if red and green lightsare flashing also check to see if the red 4 pin plug is connected inside the top panel then make sure cable to antenna isnt broken
Jul 08, 2011 | Jandy Aqualink Pda P8 Wireless Pool or Spa...
Im not able to instalthe primavera p6 on my new hp lap windows 7
Before installing primavera p6, check whether any SQL databases with the same name exists. Uninstall the SQL if the databases created during the previous failure installation of primavera p6(go to add or remove programs to uninstall). After uninstallation of SQL express, try to run installation files for primavera p6 will solve your problem.
Revert back for more assistance.
Dec 26, 2009 | Computers & Internet
P6 P4 P8
what problem are you having with the system?
Nov 09, 2009 | Compaq Presario 5000 PC Desktop
Hello.problem is.were are se place of cable p3,p4,p5,p6 on se pc acer e500?
they are usually number given to the power cord in the computer with power supply..
Jun 28, 2009 | Computers & Internet
E-Machines T3025 PC Desktop Logo
565 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
