Question about Briggs & Stratton Garden
I have a Murray lawn tractor powered by Briggs & Stratton, I am looking for either the manual for the mower or the engine, mower model # is 42576x92 engine model # is 313777 type 0134-E1 can anyone plz help
  • racngmichael May 11, 2010
    have you tried doing a google search for manuals for murry mowers most of the time you can find what you are looking for i did it for wire diagrams for murry and found what i was looking for i had to look but i found it
  • 7 Answers
SOURCE: is there an oil filter on a Briggs/Stratton riding lawn mower. Model#42A700
Yes there is a spin on oil filter. Depending on the date code when the motor was built there are two possibilities. The easiest way is to measure the length of the filter, If the filter is 2 1/4" long the Part Number is 492932.
If the filter is 3 1/4" long, the Part Number is 491056.
Posted on May 25, 2009
Techjoel
  • 79 Answers
SOURCE: Diagram for Lawn tractor instalation belt
managemyhome.com has many manuals for yard machines/mtg lawn tractors.
The information you need may be generic and therefore almost any manual may help re-install the belt. This manual is for the 660-679 series. Once at the site you can check different model numbers for one that may be closer to the machine you have.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0403122.pdf
Good luck,
Techjoel
Posted on Jun 05, 2009
  • 8 Answers
SOURCE: briggs a stratton 35 lawn mower
Turn the mixture screw on the carburator slowly counter clock wise till the idel stabalizes.
Posted on Jul 01, 2009
panilling9
  • 284 Answers
SOURCE: how to adjust valves on briggs and stratton 17.5
Remove spark plug
Remove cover from engine that covers the flywheel
Remove rockerarm cover or valve cover
Find TDC (top dead center) by rotating the flywheel by hand and your finger over the spark plug hole as you rotate the flywheel you will feel pressure against you finger at some point then stop.
This is the compression stroke it is called now find a long slim round piece of plastic or plastic ink pen to stick in the spark plug hole (If you are careful a slim screwdriver can be used ) and find the piston top, then slowly rotate flywheel again (cw) as the piston is moving up pushing the plastic up as you rotate the flywheel slowly.
a max. piston up or tdc as you turn you will feel and then the piston starts to go the other way,at that transition this is tdc (piston is on top of stroke) leave it there,,both valves should be closed at that point.
Have a feeler gauge and set the exhaust valve at a loose .002 and the intake a loose .004 be sure engine is cold when valves are adjusted
Feeler gauge goes in between the rocker arm tip and valve stem top for each valve setting.
Note the rocker adjustment at the push rod side of each valve by tightening and loosening to make adjustments,lock your adjustments in place and rotate flywheel a few times and recheck settings
Posted on Sep 20, 2009
  • 6 Answers
SOURCE: i have a Briggs and Stratton Model 28V707 on a
first check to see if fuel line switch is off located on the side of engine then take the carb apart and soak it in a carb cleaner sold at your auto part store soak
n a carb cleaner for appro 2hours then rinse with water then dry put it back should work fine the carb is clauged
Posted on Oct 11, 2009
Murray lawn mower model number m20300 trying to locate carberator
Murray M20300 is produce by Husqvarna (HOP) group. Its product number should be 96114002702. It uses a Briggs and Stratton engine model number 9T602-5019-B1.
The carburetor PN is 795475 which include the 795083 diaphragm and gasket. This diaphragm and gasket is most problem found when the carburetor fails to operate. Considering the cost of the carburetor kit it is just cost effective to purchase the whole carburetor replacement kit.
You can purchase from online vendors that sells Briggs and Stratton parts or purchase local from a local shop that deals with Briggs and Stratton engines.
Mar 26, 2015 | Murray Garden
42 murray mower deck TROUBLESHOOTINGmanual
It sound like pto or safety switch may be shorted. Hope this helps.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Jul 31, 2013 | Garden
I am looking for an owners manual for 425000X8 Murray riding lawn mower
andrew?so you need a manual for 425000x8A this is a 2003 model I found this manual for free at murray.lawnmowerguides.com/murray-lawn-mower-manual.html when you see your model number on your mower it look like this 425000x8 the A tell you the year it was made the 2004 model is 425000x8B BOTH MOWERS LOOKS THE SAME AND THEY HAVE THE SAME FRONT GRILLE.
Sep 17, 2011 | Briggs & Stratton Garden
Scotts model 46572x8 need to see a drive belt diagram
The lawn mower you have was manufactured by the Murray Company, which has been purchased by Briggs and Stratton. For parts and service, you can contact the Murray Division of Briggs and Stratton at 800-258-5011.
Hilary @ Scotts
Aug 21, 2011 | Garden
I have a Scott's riding lawn mower with a Briggs & Stratton 17 hp INTEK OHV model #311-777. I am needing a repair manual for this engine. On starting - engine will turn and stop. Then if you...
These mowers were manufactured by Murray, if you contact the Murray Division of Briggs & Stratton at 800-258-5011 they should be able to assist you further.
Mar 27, 2011 | Briggs & Stratton Garden
I can't find any thing on my my riding mower
This machine was made by Murray who is no longer in business. Briggs and Stratton purchased a majority of the company and a lot of the parts can still be purchased through Briggs. I do not see a parts diagram for the (b) series but I was able to find one for an (a) which is a year older machine. I have included a link for the parts diagram of it. Murray 425614A Murray 42 Lawn Tractor 2002 Diagrams and Parts List...
If you need further help, reach me via phone at https://www.6ya.com/expert/john_73617967471ec7c4
Jul 14, 2010 | Briggs & Stratton Garden
I need a manual for a Murray self propelled lawn mower Model No. 20905X8C. When I went on the Murray website, I had to have the manual to look up the part numbers. This particular manual is not on-line so...
You need a rear wheel part# 71133MA. A place to look up this model would be at www.precisionope.com. Look up OEM parts section, in may be under Murray or Briggs & Stratton. Briggs bought out Murray out several years ago.
Hope that helps.
Sep 25, 2009 | Garden
How do i route the drive belts on my murray riding lawn mower model # 465306X8B
You can download a manual for your Murray here:
Murray manual
This is in .pdf format so you must have Adobe Reader or equivalent available.
FYI: Murray remnants have been bought by Briggs & Stratton so engine parts are no problem, everything else is sketchy.
Aug 25, 2009 | Garden
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
370 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
