Question about Akai PDP-42TD1 42 in. EDTV-Ready Plasma Television
Poor picture quality in new Akai plasma TV
Our picture is fairly good except for this: there are turquoise blue hues that show up on the screen, especially on faces, white colors. Also, small red dots all over the screen on dark colors and blacks.
  • Anonymous Jan 12, 2009
    i have42 a akai pdp4210 and i can't get rid of the red dots on the darker colors need some hlp
  • Anonymous Mar 25, 2009
    I have the same problem with pink dots which escalated into a flickering picture, and eventually just large blocks of color across the screen. My TV is AKAI 27" HD.
    Problem Solver:
  • 8 Answers
Try putting a fan on the back of the tv to see if it is getting better. If it does then you probally have a board that is overheating. If that is the case then CAREFULLY !!! remove the back and place where you can turn on and safely access the open back NO TOUCHING STUFF !!! Mabey lay it face down on a glass table or lay it on a table with 25% hanging over the edge to see the screen. Then take a COLD blow dryer and blow it on the boards to find out which one makes it get better. If one does then it will probally be your problem board. Make extremely sure that is the one before removing it by blowing from all angles on the boards around it without air hitting the suposed problem board. Then try a little hot air to see if that starts the problem on that board so you can be sure. Of course check the surrounding and offending board several times to be sure before removing.
Posted on Jul 12, 2008
    Problem Solver:
  • 17 Answers
This might be caused by bad interconnections maybe try using a different cable i hope your not using analog.I was told that the red dots are usually caused by interconnects such as analog.
Posted on Sep 16, 2007
Red hues all over the images on screen
The TV is a plasma screen. There are several circuit boards that will go bad over time that affects the picture quality. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get the parts here and replace those boards yourself.
Apr 10, 2017 | Panasonic TH-42PZ700U 42 in. Plasma...
Akai PT5598HDI Rear Screen Projection TV With Blue Shadowing
If the ghosting is like a 3D effect its your convergence ICs , but if its like a blue Halo around objects that usually means your CRT coolant has congealed and will need replacement. The blue is the first tube to congeal for some reason, followed by green. Red seems to be not quite as prone to this. It is a normal occurrence n sets about 4 years old to need the coolant changed.
Jan 25, 2008 | Televison & Video
We have 42" plasma akai
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
Jan 31, 2011 | Akai LCT2715 27 in. LCD Television
I have a Panasonic Viera TH-50PX60U Plasma Picture Problem. The TV picture screen is showing up as purple. If i unplug the blue cable, the tv shows in black and white. If i plug in the cable, the...
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 24, 2017 | Televison & Video
I have a Sony, 54" Projection Screen HDTV that I bought in 2002. I believe it is a 1080i. When I am waatching TV, I notice that when the screen is mostly black, for instance a night scene, the black areas...
Confirm the actual model number as the one indicated in the title is not HD.
Some of these sets had bad picture tubes that on a black screen or blank video input may in your case show faint curved lines and or some color (red,green or blue) present in the background.
If this is the case there is a fairly simple way to attempt to adjust something for this--not in the customer menu but fairly easy to get at and try.
Most of these sets were KP51ws500, 57500 etc.
SD TECH
May 11, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
No picture anymore
I found one of these at the dump with the same issue. Bought a Z sustain board for $75 , replaced it and it works great. I plan on installing some PC style cooling fans in the cabinet as heat is what destroys these sets
Sep 08, 2009 | Akai PDP4273M Television
Sony Trinitron picture turning green hues
Nowadays CRT's do not have good quality shadow masks anymore. After heating up a little they can give a so called "blooming" effect giving a blue an yellow leaf effect large over the screen. Reason nonparallelity in deformation of the shadow mask.
Apr 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv only has top right corner showing picture
Hello the picture was good 2 days ago.I took a picture of the plasma ..could please help me with some ideas...thank you..
Mar 24, 2009 | Akai PDP42Z5TA 42 in. Plasma Television
Repair Akai TV
the snow is just because of poor quality signal
the signal coupler which is in the tv might be bad or your dish needs to be reset cause of the wind
Mar 12, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Akai PDP-42TD1 42 in. EDTV-Ready Plasma Television Logo
219 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
