Question about HP PSC 2510 All-In-One InkJet Printer
My paper is cutting off the word on the right hand side of th
I am trying to set up the margins that fits all the content on the paper, because information is being cut off on the right hand side what should i do
  • 385 Answers
Go to the Application your working in,
Click tools or edit, view, page layout, margin's,
you can manipulate the margin's,
1.5 all the way round, usually for standard printing
or, check printers properties setup too...
Hope this helps.
Regards.
Posted on Apr 16, 2009
When printing the document info is cut off on the left hand side op the paper
printer tiflon is damage please contact the shop kapeer and repair tefon paper
Apr 13, 2012 | Canon LBP6000 Laser Printer
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
Bulk mail inde
Put spaces in your type to move it over if you cannot move the margins. You might also be able in print options page setup to indent the margins or paragraph so it prints inside the page.
Aug 31, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Left margin of text is cut off
Check your margin settings in your printer set up.
Jan 09, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Optra T610 Print Problem
Your paper size settings for Tray 1 is probably wrong. Make sure it is set to Letter and the type is Plain Paper. If your Paper size is Universal, then either the paper guide in the tray is set wrong or the paper size sensor is broken. If the sensor is broken, you can disable auto paper size sensing so the printer will allow you to specify a paper size. To disable paper size sensing, you need to go into Config Mode. The other way is to send a PJL command to the printer to disable the function.
Nov 07, 2008 | Lexmark Optra T610 Laser Printer
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
My margin gets cut off on one side whenever I make copies
Are you copying onto the same size of paper or onto another size like A4? If changing size you will have to tell the machine what sizes are in use.
If you are using similar sizes, try setting off a stack and as the machine feeds a sheet in, turn off the power. Lift the lid and see iff the page is running in the correct position and not off to one side. If the page is off to one side, you need to check that you have the paper guide (where fitted) pushed up to the correct position etc.
Let me know if this helps any.
Oct 11, 2007 | Office Equipment & Supplies
Margin printing problems
Check your application's print settings (for e.g. MS Word). Then check the printer's properties and print settings. If nothing works you also try re-installing the latest printer driver. If you use MS word should check the page setup option, for paper size errrors. If the color of your margin is red and the red ink is out then you won't se the margin line.
Oct 09, 2007 | HP Color LaserJet 2600n Printer
Will not print 4 x 6 prints
try to find the margin settings of the application that you are printing  with. If margins are setup in a wrong way it will print anywhere it likes.
Aso see the paper size. e.g. A4, A3 etc.
I think you should take a normal a4 paper and print it and see the size of the image and the size of the document that you have created.
Another way to test it is to copy the image(content) only and paste it in some other application like MS Word or something else and try to print it in 4x6.
If it is an image and you can copy it to MS Paint then do it and cut everything else (crop the image accordig to its' size), then print.
Remember to place the paper on the right hand side of the paper tray. (You can do the reverse also if it required.)
Sep 25, 2006 | Canon S520 InkJet Photo Printer
Paper margin problem in pagemaker application
Do you mean the left margin is too large so all the content is shifted to the right and off the page? If this is the case, it is probably a setting in Pagemaker. In the file menu, choose "page setup" or "print setup". Check the paper size. Check the margins.
Jun 24, 2006 | HP Color LaserJet 2600n Printer
HP PSC 2510 All-In-One InkJet Printer Logo
263 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
