Question about GE Dryers
No heat but drum turns - GE Dryers
  • Michael Masters
    Michael Masters May 11, 2010
    hi, is this a gas or electric dryer?
  • 594 Answers
The most common reasons of no heat is oe of 2 problems. either your heatinf element is out or your limit switch is out not allowing the heating element to switch on. your limit switch is on the heating element. it will have 2 wires on it. it looks like a button on the side of it. tht is the fastest and cheapestway to go first. if that does not work thqn i would check the heating element.
Posted on Apr 16, 2009
Why won't it start?
check for the operation of a small micro switch at the door hinge
if that is out of adjustment then the unit will not start
Jan 05, 2016 | Bosch Dryers
My dryer has heat but does not dry
is the drum turning? if not you must replace the strap that turns the drum. if it is heating and the drum is not turning , that could cause a fire.
Sep 30, 2014 | Estate by Whirlpool EED4100XQ Estate...
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
CTD00 drum does not turn,heating OK,belt OK,motor OK
you have a bad motor,most likely.
Mar 03, 2010 | Dryers
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
NO HEAT FRON DRYER , DRUM OK
either your heating element,hi-limit switch,cycling heat switch, thermistor,control panel, or you don't have 240 volts supplying the dryer,120volts will still let the drum turn or the timer count-down, its the way there wired
Nov 01, 2009 | Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Motor not strong enough
The problem dosen't sound like the motor. Check to see if the drive belt is loose and slipping. This is the usual cause of the problem you describe. If not, the bearings for the drum may be going bad. The heating elements should turn off shortly if the drum stops so there is little danger of overheating.
Ray
Dec 15, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
56 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
