Question about Car Audio & Video
Replace my door speakers in a 1999 camry xle v6
I want to replace the door speakers. can i doo this without removing the door panel?
  • 4 Answers
Im sorry but you will have to remove the door panel its the only way it's really not that hard
Posted on Apr 17, 2009
What are the front tie rod end specs for 1999 Camry XLE v6
Tighten the tie rod stud nut to 36 ft/lbs and the jam nut to 41 ft/lbs.
Apr 26, 2014 | 1999 Toyota Camry Tie Rod End Replacement...
What are the specs for my 1999 camry xle v6?
Search for diy wheel alignment. A trip to the alignment shop is bett
How to replace the rear speakers on a 2010 toyota camry xle
Try priseing the covers up with a screw driver then remove screws holding speakers down.
Mar 14, 2014 | 2010 Toyota Camry XLE
dude, in the deck under the glass? try going at it from the inside the trunk
How do i remove my 1999 toyota camary door speakers??
Remove the door panel and you will have access to the
speaker. The door panel has a couple of screws in the middle and
a couple on the bottom.
Nov 01, 2010 | 1999 Toyota Camry
1992 Toyota Camry XLE / air direction control issue
the control is opperated with engine vacumn, check for a hose cracked or come loose in the engine bay, the controller is in the dash,behind the adjustment knob, it may have a hose off or need replacement.
Apr 15, 2010 | 1992 Toyota Camry V6
Downshift problem in 2005 Camry XLE V6
Check your motor and transmission mounts.
Mar 05, 2010 | 1999 Toyota Camry Solara
My 1995 camry xle v6 driver door wont unlock.
i just had this same problem. it was the lock assembly. the spring had broken on it and the lock was halfway unlocked and locked. so it would not move, therefor the door was stuck shut neither locked nor unlocked, but with no way to open it. so we had to manually unlock the door with a stick between the door panel and the window. then we were able to take off the whole door panel and fix the problem. but by this time, its probably easier just to buy a whole new door. hope it helps
Nov 30, 2009 | 1995 Toyota Camry
1992 Camry v6 XLE: Started engine this morning,
Is it coming from the driver side, passenger side, front or rear of the engine? It could be a cam or crank seal if it is coming from the passenger side behind the plastic timing cover.
Oct 07, 2009 | 1993 Toyota Camry V6
Lost power to power windows, door locks and sun roof.. I can not find the correct fuse that i think has blown. I have looked everywhere and all of the fuses are just fine.. 1992 Toyota Camry V6 XLE
Most likely a broken wire in the harness from front drivers door...open up and cut off the rubber boot and fix broken wires...they tend to break after a few thousand opens and closes...then wrap with electrical tape to replace the rubber boot...Lee
Jul 30, 2009 | 1992 Toyota Camry V6
Car Audio & Video Logo
70 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
