Question about Bosch 24 in. SMU40 Built-in Dishwasher
Opened door on cycle, will not continue cycle after closing door
I opened the door of my bosch smv4403gb/18 dishwasher during a cycle. i must have forgotten to close the door again and a couple of hours later i noticed the door slightly open. so i shut it expecting the cycle to continue. this did not happen and has been like this for over six hours. please help
  • 423 Answers
The most common problem for a dishwasher to not restart after the door being closed is a failed door latch interlock switch. Adjusting / repairing it is not too difficult.
Of course this assumes that the Dishwasher power circuit from the circuit breaker remains powered up.
Post back here if you are looking for more details.
Good Luck!
Posted on Apr 16, 2009
How do I fix the heater in my Bosch shu5306uc / u12?
SHU5306UC-12 BOSCH DISHWASHER Manual - Sears ...
www.searspartsdirect.com > Kitchen Appliance Parts > Bosch Parts
Download Manual for Model SHU5306UC-12 BOSCH DISHWASHER.Sears PartsDirect has parts, manuals & part diagrams for all types of repair projects.
Aug 01, 2015 | Bosch Dishwashers
Bosch dishwasher door pops open during cycle
Latch needs adjustment or replacement.
Jul 07, 2015 | Bosch Dishwashers
Bosch dishwasher trips power supply when door fully opened after cycle completes
The dishwasher will have a wiring harness which passes through one of the corners or in the centre of the door. I would suggest that the harness has perished or weakened and exposed a live wire which touches the cabinet when the door is opened and it shorts out. Opening and closing the door after many years of use weakens the wires where they get continually bent back and forth during door opening and closing. Ive seen wires rejoined but the only sure fix is the replace the wiring harness.
Feb 23, 2015 | Bosch Dishwashers
Bosch smv4403gb 20
if the is an electronic unit it sounds like a burnt relay on the control board if the is the case the control will need to be replaced
May 24, 2014 | Dishwashers
Bosch dishwasher beeping during cycle
Take the front kick panel off and see if anything under the machine is wet.
Jan 06, 2014 | Bosch Evolution 800 SHE58C02UC 24 in....
Bosch Logixx won't start - Stuck on "Close the door" even though door is closed.
Open the door, look along the top stainless on the door and you should find the ENr number (model number) etched into the stainless, may need to give it a wipe and look at an angle to read it. Post the ENr and that should help with diagnosis.
Mar 15, 2013 | Bosch 24 in. SGS69L02 Logixx Built-in...
Bosch dishwasher shx46a06uc-30
the unit will try to complete the last command it was engage in before it went in the overfill safety mode. you must perform a cancel drain cycle to reset unit to default setting. Remember the drain cycle is 2 min and must be completed to reset main control. however if it went into a overfill status you have a leak and it generally comes from the pressure chamber on the lefthand side of unit where the water enters tub
Apr 17, 2012 | Bosch 24 in. SHX46A05UC Built-In...
Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
May 30, 2009 | Bosch Evolution 500 SHE45M06UC Built-in...
Washer will not start. Lights come on, but nothing else happens.
I have a Bosch Dishwasher, SHU6805UC/U06, During a cycle it was interrupted by opening the door. It was left open for an hour. When the door was closed again the lights came on but the cycle did not continue. The motor did run but no water was rushing. Power interrupted to the machine did not enable it to reset or restart. How do we get it going again?
Mike,Laurie,& Dory
Apr 15, 2009 | KitchenAid Dishwashers
Bosch Aquasensor Detergent Dispenser door wont open during cycle
Behind the dispensor door there is a small selanoid you will need to replace this, test to see if its open circuit, alternatively you can just place the detergent in side the machine before you put it on a wash cycle is this would have the same effect. the only cycle you can not do this on is the one with the prewash, I think its number 1.
Nov 17, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwashers Logo
393 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
