Question about Sony STR-DB1080 Receiver
Protector keeps coming on on a sony str-db1080
Also now right front and right surround sound distorted
SOURCE: protector fan
i have the same problem , help me umbertknot@hotmail.it
Posted on Jun 28, 2008
  • 71 Answers
SOURCE: sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Posted on Mar 15, 2009
CAYPIANAN
  • 227 Answers
SOURCE: Sony str-DE435 Flash Protector
this is not a reset problem, you have a defective audio output, is either the outputs transistors or the drivers IC's ( integrated circuit) and sometimes if you are lucky is just loose connections on the drivers IC;s.
good luck
Posted on Jun 18, 2009
smarthome2
  • 1114 Answers
SOURCE: Sony STR-GX800ES receiver "protector" blinking - no sound
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 13, 2010
  • 5 Answers
SOURCE: Sony STR-K670P Surround Reciever. No output from
This is a common problem that a lot of people have with this system. The problem is in the connection of the Left and Right Speakers to the receiver. I had this problem too.
What you need to do is actually open up the receiver using a screwdriver. Once it is opened up you will see a circuit board and lots of wires. Look for the red and blue wire that should be pretty easily visible. Cut each one, then strip the ends some, and reattach the ends but to the opposite color- make sure to solder it as well. On some models they messed up the connections and it got switched. Once you do this, the left and right speakers should work great. Hope this helped!!
Posted on Sep 22, 2010
I have a Sony STR-DE605 and all of the right side channels are distorted and have to be turned up 1/4 before you can hear any ot the distortion but if i turn if off switch to the left sounds perfect.Center...
Sorry for a dump question ,
have you changed the distorted Right speakers to LEFT to verify if speaker is OK ?
First try with just STEREO ,not on Surround and please contact me for further solution possibility..
Take care..
Jun 27, 2011 | Sony STR-DE605 Receiver
Sony STR-DE875 receiver has no sound from right channel front or back. Checked for loose connections & blew out dust, no change
Hy all. I bought a receiver at last week. But the front speakers not working. The rele is jumping just.
i repaired them ! the rele colour is blue. Three percent . left first -Center, between -Surround, between(right Hand)-Front.
I moved the front channel's rele(right hand) .Katt -it sad. Working, volume is back. Rele specification is (colour Blue) Deg Greatings-Ranger of Hungary.10_26_2012_6_50_16_am.jpg
Aug 23, 2010 | Sony STR-DE875 Receiver
5.1 Surround sound not working
Maybe the surround processor is having a bad day... My kenwood would do similar and a reset was necessary to correct. Have you tried resetting the system? On my Sony STR DE 597 this is accomplished by powering off. Then while holding the 2 channel button down (front face plate) power on. A reset message is displayed. Your model may be similar but check your manual or download the PDF of the manual from Sony's support website. Hope this helps
Sep 05, 2009 | Sony STR-DE685 Receiver
No subwoofer sound
This is almost never a real problem . go into the menu and turn on the subwoofer output.
Jul 12, 2009 | Sony STR-DB1080 Receiver
Sound only some out of 2 speakers at a time. I need all 4.
Here you go buddy:
http://www.docs.sony.com/release/STRDE685.pdf
May 19, 2009 | Sony STR-DE685 Receiver
Fuzzy sound from right front speaker output
The main issue is to determine where the distortion is coming from. Does it start in the front and and get amplified or does it appear in the output section only? This will require a fixed signal and an oscilloscope to trace. Check for leaky coupling caps or leaky transistors in at the diff-amp section.
Dan
Feb 02, 2009 | Sony STR-DE485 Receiver
Protector flashing on Sony AV receiver--Model STR-DG600
Me reicever rite protect some time ,i put the sytem off and a start again
Dec 31, 2008 | Audio Players & Recorders
I have low volume on two channels of my STR DE975 receiver
I been replied you in chat thread, please check and feel free to ask any question.
Aug 20, 2008 | Sony STR-DE975 Receiver
Surround sound distortion
Receivers like this will incorrectly decode rear channel audio and pass it on to the rear channels as distorted audio. Make sure the source being used really has rear channel information encoded into it. It could have other issues but check this first.
Dec 16, 2007 | Sony STR-DE625
Sony STR-DB1080 Receiver Logo
252 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
