Question about Microsoft Xbox 360 Console
Will not load games
Driver does not spin when a game is put in but will play dvd's and music cd's. The error says enter an xbox 360 game or does nothing at all just says open console. I have cleared all profiles and re booted, i have taken the console apart and made sure the wheel is not sticking and have used an expensive laser cleaner system to try and rectify this problem but it continues to get worse and is now not loading games 100% of the time.
Search the web for "360 rubberband fix" Your laser is moving to far back to read the disks . Its an easy fix and there are videos out there to help you along "youtube"
Posted on Oct 04, 2007
My x box will play cd's and dvd's but not games. do you know what i can do to fix that. when i put in a game it says to put disc in an x box 360 console.
Here's how:
1. Carefully open the Xbox by removing the torx screws and then releasing the clips that hold the case together. The clips and molding pieces all come off easily; pry them open carefully.
2. Load the flash firmware disc into the DVD drive and power off the Xbox.
3. Disconnect the DVD drive from the SATA cable and note the brand of drive used in your Xbox. Currently Microsoft uses Hitachi, Phillips and Toshiba DVD drives in the Xbox 360. Only the Toshiba and Hitachi drives have firmware updates.
4. Connect the DVD drive to your PC with a cross-wired SATA cable interfaced to a compatible SATA port. Confirm that the video cable is connected to the Xbox so that it won't turn off during the flash process.
5. Hold the two loose wires of the cross-wired cable together and press the "Start" button on the Xbox. Separate the wires immediately when the green light begins to flash on the front of the Xbox. The light will begin to flash quickly and the drive will begin to spin as it enters mode "B."
6. Turn the PC on and allow it to fully boot from the DVD drive. If Windows appears to fail the boot, eject the DVD and it will finish booting. You've successfully flashed the drive.
7. Reassemble the Xbox and enjoy playing the backup of your favorite game. Sources: http://www.ehow.com/how_2316522_flash-xbox-dvd-drive.html
Mar 10, 2010 | Buck Legendary: The Box for Xbox 360
The xbox 360 will not read game discs or give me the option to play the game it only gives me the option to play a cd
Hi
By the problem you have described, i beleive you have a modded Xbox 360 used to play copied games, if yes you need to check what game are you playing.
If it is a latest game, then you would require a Wave 4 patch to play copied games on a modded Xbox 360, you can google on the web to find out the list of games that require wave 4 patch to run before you play the game on Xbox 360
What you need to do is first burn the Wave 4 patch on a Dual Layer DVD and load the game disc first and you would see "play CD" option, now take out the game disc and enter the Wave 4 patch disc you just burned and again you would see "play CD" option.
DO NOT PLAY the CD, just take it out again and re-insert your copied game CD in your Xbox 360 and you should be good to go.
Regards
KreativeGeek
http://gamingbox.wordpress.com
Feb 27, 2010 | Microsoft Xbox 360 Console
I put a new disc drive in my xbox 360 but it dosent read games
Why you replaced the dvd drive i do not know, The problem is if you have installed a non microsoft xbox dvd driver it will not work! If your original dvd driver is broken as to why you have replaced it, contact microsoft or your local games shop for another xbox 360 or drive. You can also by a addon driver, you can see it here
http://www.amazon.com/Xbox-360-HD-DVD-Player/dp/B000JHO4L0
Jul 19, 2009 | Microsoft Xbox 360 Console
I put in 360 game into 360 console, message pops up to insert game into a xbox 360 console...that is what I'm putting it in!!!!
try putting a DVD movie, or A music CD in.
this will eliminate a faulty DVD Drive, or laser fault.
Mike @ compurepair.
Jun 19, 2009 | Microsoft Xbox 360 Console
Disk reading error
this is a possible laser read problem.
Try an official DVD Movie. And also a music CD.
if it reads nothing at all, i,d suggest a laser head cleaner.
Or a replacement DVD Drive.
Mike @ compurepair.
Mar 26, 2009 | Microsoft Xbox 360 Console
Wont read games
Though i fixed the Disc Read Error myself within anhour but please test the below method at your OWN Risk. Please alsonote that microsoft is no longer providing Extended warranty for E74Error.
Check out this DIY Video Guide,that explains step by step instructions to fix Disc Read Error yourselfwithin an hour. It also provides the money back guarantee in case youare not satisfied. As i fixed my Xbox myself so i thought to share itwith you guys.............
Mar 03, 2009 | Microsoft Xbox 360 Console
Xbox 360 plays dvd but not games
you probably didn't flash the drive correctly. you can find guids how to online. its a pretty in depth process though.
May 24, 2008 | Microsoft Xbox 360 Console
Xbox Does not play original games
Error Codes XBOX360
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Feb 25, 2008 | Microsoft Xbox 360 Console
Xbox 360
That's weird, if the Xbox needs a driver it should be installed or come on a Cd.
So the games don't play ?
Call support and threaten that you'll bring it back, it'll get them to help better.
Dec 21, 2007 | Microsoft Xbox 360 Console
XBOX 360
Try using a cd lens cleaner in the XBox 360 dvd drive, and make sure the game cd does not have scratches.
Nov 06, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
90 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
