Question about Epson Stylus RX500 All-In-One InkJet Printer
Ink smudging When I'm printing invitation envelopes, there is an extra deposit of ink, or smudge, at the edge of the envelope. Anyone know what causes this and how to correct the problem? I'm wasting a lot of envelopes!
  • Anonymous May 02, 2008
    Same problem. Smudging on envelopes and every one is smudging on the return address on the top left hand corner, less smudging on the actual address,
    Genius:
  • 2,985 Answers
Run a cleaning sheet through the printer- absorbant papaer- blotting paper. If this machine has had a lot of service it may be your waste tank is filling up and leaking out - have you had a service warning yet?
Posted on Sep 21, 2007
Ink spots on envelopes
Hi rebecca,
Go To Below official Hp Printer Forum Page For Your problem And Solve Your Problem Black ink stains envelopes when printing HP Support Forum 955951
Feb 24, 2014 | Canon PIXMA MX340 Wireless Office...
Where do i put envelopes in a lexmark X6570
Loading envelopesYou can load up to 10 envelopes at a time.
Warning: Do not use envelopes that have metal clasps, string ties, or metal folding bars.
1 Load envelopes in the center of the paper support with the stamp location in the upper left corner.
2 Make sure:
• The print side of the envelopes faces you.
• The envelopes are designed for use with inkjet printers.
• The paper guides rest against the edges of the envelopes.
Notes:
• Do not load envelopes with holes, perforations, cutouts, or deep embossing.
• Do not use envelopes that have exposed flap adhesive.
• Envelopes require more drying time. Remove each envelope as it exits, and allow it to dry to avoid ink smudging.
Apr 11, 2012 | Lexmark X6570 InkJet Printer
HP Photosmart Premium c309a series smudging wedding invitation envelopes badly. I can print the invitations and everything else just fine. Any suggestions? Thank you.
when you go to print your envelope and click the print command - a window will open with the name of your printer and a box that says properties. click on properties. Change the type of envelope stock to match what you are printing on in the next window. If you are using photo paper envelope with a glossy finish, make sure that is the print media you have set for your printer. If not, the ink will just keep smudging. it's very important to match the print stock (matte, glossy, premium ect).
Oct 09, 2011 | HP Photosmart Premium C309A All-In-One...
I'm trying to print wedding invitations on my Canon MP460. I'm using a cardstock thickness of paper and have set the ink levels for "Other Photo Paper" on my Mac. The paper has been going through...
Sounds like the ink isn't having time to dry and is rubbing along paper.
Paper may be too thick. If it prints OK on normal paper (test first) but not on thick card, then it doesn't support thick paper settings.
Jan 31, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Set the printer preferences so that there is an ink-drying pause, like it does for duplex printing, should be enough time to dry (go into preferences of the printer properties)
Apr 16, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Ink smudges off envelope
You will need to select in the drive that the media type you are putting in is envelopes this will adjust the printer fusing section to increase the heat.
Also you must select to go through tray one when doing this open the back door and the printed envelope will come out of the back and should be fine. If not try a lesser grade of envelope if still the same problem then the fuser unit is slipping and will need to be replaced.
Hope this helps you
Thanks J
Jan 02, 2008 | HP LaserJet 4250n Printer
PIXMA 830 Smudges when printing envelopes
On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
Another idea is to adjust the "ink drying wait time" to a higher level.
Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Print quality
hi
oftne the thicker papers (and envelopes) bulge up as they pass thru
make sure you tell the printer (in the settings) that you are printing envelopes so it knows and uses less ink etc
cleaning can be done with isopropel alcohol
make sure you remove it all and run a test page or 2 before using again
D
Nov 21, 2007 | Brother MFC 420CN All-In-One InkJet...
Epson Stylus RX500 All-In-One InkJet Printer Logo
600 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
